SOURCE: my pentair controller will not shut the filter pump off
Chances are that you have a bad relay, but the problem could be the main logic board. If there is a spare relay in the box switch all the wires from the pump relay onto the spare. Remember to shut off the breaker, and also you will need to change the wires on the top of the relay too, or you will have to do some reprogramming.
SOURCE: Compool TimeMaster with this control panel
The first thing that I see is if you have a service panel, make sure that it is in "auto", not "service" and that all switches are set to off. That is the panel by the pool/spa, not the main panel.
Gary
Testimonial: "So Far so good. I had already made sure it was set to AUTO, but had not set the individual switches to OFF. I assumed the AUTO switch overrode others"
