Question about Toshiba SD-3980 DVD Player
How to clean lens on durabrand portable dvd player
We have a Durabrand portable DVD player, the issue we have is once we place the dvd in, the screen reads loading, then reads no disc. We have tried several discs. Any free troubleshooting suggestions?
hello
use a cd/dvd lens cleaner kit or if that does not work, you will need toopen lid, access the lens pickup, and clean the lens directly, using isopropyl alcohol with cotton sticks.
anyway if these all dont help you need to replace pick up with a new one. i recommend original spare parts as those sold on ebay mostly chinese production with low quality and durability.
kind regards
Feb 20, 2011 | Durabrand PDV-709
Tip
I have a durabrand portable dvd player and all it dose is skip i'm playing...
One fix to return DVD player to origional setings, is to go in to the menu and find the factory reset option the will return the setings back to fresh from the factory.
Regards Tech Guy
on Jul 27, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
When you put a dvd in it it says no disc I used all dvds it tells me the same thing the player is about 2 years old
try to use cd cleaner first. usually len has a dirt thats why you player was unable to read year disc. if same thing happened after you cleaned the lens. then it might be a lens problem
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 25, 2010 | Durabrand PDV-709
WHEN DVD IN IT SAYS NO DISC
Optical lens problem. I assume ure not a pro in repairing it, so send it for repair to local tech. Before u do that, get a lens cleaning kit and clean your optical lens. Usually the optical lens cleaning kit comes with a cd and solution. Use it according to the instruction manual. If still the same, then send it to tech for repair.
Jan 18, 2010 | Durabrand DUR-1700 Portable DVD Player
After loading it reads no valid disc
Either the laser lens eye is dirty and needs to be cleaned with rubbing alcohol and cotton swab or the lens unit is faulty and will need to be replaced
Aug 01, 2009 | Durabrand DUR7 Portable DVD Player
Portable durabrand dvd wont read disc
If it is reading a burned movie from the internet make sure you set you brun software for captability mode.
If this is a orginal disk make sure its free of dust and scratches.
1. buy a lens cleaning kit from walmart or any other eletronics store.
2. Make sure the disc is free of scratches.
3. change disc's and see if it works on any others.
if these steps do not help then the laser would need to be replaced. Durabrand is a Wal mart brand i had mine for 2 years and i had to clean the lens 3 times with a cleaning kit.
Thanks
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Durabrand DUR7 Portable DVD Player
Displays "No Disc"
It can be several reasons
1. Disk is upside down
2. Lens is durty. CD/DVD cleaning disk will help
3. Disk is in different formate (for instance NTSC for US but you trying to playback disk in PAL)
4. Disk has different region code (look is the dvd player and disk have the same code, or ALL Regions code)
Good Luck
Dec 26, 2008 | Durabrand DUR7 Portable DVD Player
No Valid Disc
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
Jul 25, 2008 | Durabrand Portable DVD
Dvd problem
I had this once you should get dvd cleaner dvd lens cleaner
Dec 04, 2007 | Durabrand DUR7 Portable DVD Player
Toshiba SD-3980 DVD Player Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
