Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
17 HP Briggs & Str lawn mower engine that is smoking a lot -
I think it's a burnt valve but I am not sure?
  • 508 Answers
Compression test it can either rent or buy one should be over 90psi!!!
Posted on Jun 28, 2009
Just got used john deere riding mower model L118 with briggs 22 hp v-twin,runs rough and spits back through carb
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 07, 2017 | John Deere Garden
Which valve is the intake valve on a 17 hp briggs engine?
look at the valve s one is smaller than the other one this is the intake the big one is the exhaust valve
Jun 11, 2014 | Briggs AND Stratton Intek Briggs &...
I have a briggs & strat 17 hp ohv intec model 311707 on my craftsman lawn m. it was running then with a large puff of smoke it quit. now the starter runs it with no compresion, removed the s p (oi
does the engine when it is turning over sound normal? does the engine have any compression at all or is it just not as much? sounds like a burnt valve
Sep 07, 2012 | Measuring Tools & Sensors
MTD J/130
check the oil and see if it smells like gas if so the needle valve in the carb is bad
May 09, 2012 | Garden
Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
5 hp briggs and stratton mower is hard starting when hot.
Most times the briggs engines start hard when hot because the exhaust valve is leaking at the seat.If you hear a hissing noise from the muffler when you are trying to start instead of a good crisp pop it that is a good indication the valve is burnt.To be sure you would have to have a compression or leak down test done on engine.A valve job is not an easy job if you don't have the right tools.
Jul 29, 2009 | Troy Garden
Engine shuts down
check compresstion.if good check valve if good check beather on engine.but first check
sparkplug.let me know if this help you.ok
Jul 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
674 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
