Question about GE GBS22HCP Bottom Freezer Refrigerator
No defrost in GE model GBS22HCPAWW. I've checked
I've got no defrost in a GE model GBS22HCPAWW bottom freezer. I've had to manually do it using a hair dryer 3 times now. I checked the connector upstream of defrost terminator (one lead to d.t, other to defrost element) and it shows 31 ohms. Don't know what that indicates, and if I should remove shrink tubing from element connections to test element itself.
  • 72 Answers
SOURCE: locate defrost sensor
Remove all of the racks and drawer from the freezer, take the back wall off from the inside of the freezer, defrost limiter/thermostat will be attached to the evaporator near the top, it will be a metal cylinder with two wires coming out of it. It opens on warm and closes on cold
Posted on Jun 17, 2009
aasc
  • 1606 Answers
SOURCE: GE Side by Side Freezer Side Not Defrosting
You have a bad element .
Posted on Jul 18, 2009
woodchuck789
  • 4070 Answers
SOURCE: I have a GE bottom freezor model#GBS22HCPAWW.The
The fill tube at the ice maker will freeze up when you have a leaky water inlet valve. It's on the back where the water source is connected to the unit. You can disconnect the water line that goes up to the ice maker and watch and see if you have a drip. This water will go to the fill tube and gradually block the tube as it is frozen when it reaches the cold air in the fill tube. You may be able to clean the valve out or just replace it.
Posted on Nov 18, 2009
daryl441918
  • 1280 Answers
SOURCE: Refrigerator Problem: Model
That means your drain line is plugged up or iced over. You need to find it and clear it.
Posted on Dec 07, 2010
woodchuck789
  • 4070 Answers
SOURCE: GE Top freezer #TBX14SPGRAD i have replaced
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Part 622 is the drain trough in this DIAGRAM
Posted on Mar 07, 2011
How do I fix my GE refrigerator?
Ge uses a glass heater and it is common for the heater to go out replace the heater and it should cure your trouble
Dec 27, 2015 | GE Refrigerators
My GE model GSH25KGMB BB side by side refrigerator is not cooling on fresh food side. Freezer and ice maker side working fine. How should I troubleshoot this?
On your model I would go straight to the defrost heater and defrost thermostat and check them first after defrosting the evaporator first with a hair drier. Both parts need to be replaced=> WR51X10055 Defrost Heater Assembly 25953576-emtx2i4tcmlh0qfjbwwrn2z1-2-0.jpg and the=> WR50X10068 Defrost Thermostat APPLIANCE 911
Nov 11, 2015 | GE Refrigerators
GE model # GSS25JFPHWW looking for the defrost timer on this one is it behind the ice maker in the freezer
Defrost is controlled by the mother board, behind small rectangular panel on back of refrigerator. Part # WR55X10942 . (you can not use the board to manually defrost) If you are having a defrost problem, the most likely cause is the defrost heater (WR51X10055) and while you're at it, you might as well replace the defrost thermistor (WR55X10025) located at the top of the cooling coils. Manually defrost freezer by unloading freezer, removing shelves, and removing back panel inside freezer, then use hair dryer to melt frost. (you have to take those parts off anyway to get at the heater and thermistor)
Mar 31, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
As of six months ago, my GE fridge starting leaking from where the air blows into the refrigerator part of the machine. I was getting a 16 oz cup of water out of it every 36 hours or so. Now the freezer...
If this is a top freezer model,remove the bottom and back freezer panels. You will find the defrost drain line frozen over.
It must be defrosted manually. A hair dryer will help melt the ice.
May 25, 2010 | GE Refrigerators
Nine y/o GE side by side not getting cold enough
More likely a defrost heater. Look inside the freezer at the back wall. Any frost there? If so, turn off refrig., unload freezer, take back panel off inside freezer, and use a hair dryer to melt off the frost. Replace the defrost heater located at the bottom of the frosted coils. (New heater may appear different than original, but instructions are included) If you don't have the defrost heater on hand, just manually defrosting the coils and re-starting the refrig will get is cooling again for at least a week before problem will re-occur. (this give you enough time to get the replacement part)
Mar 21, 2010 | Refrigerators
I have a ge externa refrigerator that does not cool on top shelves of the fridge or the freezer. it cools at the bottom just not the top. model # is ESS25KSTSS. Fan is workin fine and has freon. If anyone...
If the fan is working fine the next thing to check for is heavy frost on the back wall of the freezer section toward the middle to bottom area. If you have frost there you will need to remove the panel and with ref. off use a hair dryer to defrost the ice from the coils. After the ice is defrosted you will see a defrost heater at the bottom of the evaporator coils. This will be your problem Part number 51x10101 at about 64.00 or less. Hope this helps and good luck. Rick
Mar 09, 2010 | GE (ESS25KSTSS) Side by Side Refrigerator
Locate defrost sensor
Jun 17, 2009 | GE GBS22HCP Bottom Freezer Refrigerator
How do you unstop the drain line
Remove the freezer back wall and lower panel. Remove the visible ice. Use a hair dryer to defrost the drain hole in the rear trough.
Mar 13, 2009 | GE Refrigerators
Fridge does not get cold
I had the same problem. The problem was my freezer was not defrosting itself and for a while i opened up the back and manually defrosted the freezer with a hair dryer (to make it defrost faster) and lots of towels (to soak up all the water). I replaced the defrost heater in the freezer and no more problem. Go to searspartsdirect.com and put in your model # then look for the part. Hope this helps.
Nov 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GDS18LBP Bottom Freezer
Check to see if the evaporator fan is running (the fan inside of the freezer behind the back panel). If it is, pull the interior back panel off of the freezer to see if you have a defrost problem. If there is a large amount of frost/ice, test the heater and defrost thermostat with a multimeter. If they are good, replace the defrost thermostat. Be sure to defrost the ice manually with a hair dryer before you put the freezer back together.
Mar 27, 2008 | GE GDS20KBS Bottom Freezer Refrigerator
GE GBS22HCP Bottom Freezer Refrigerator Logo
146 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
