Question about Dell Inspiron XPS M2010 Notebook
I have the same problem with my XPS One
The problem started last week. I continuously powered it on and off until it booted correctly. Last night the screen was blank again. Powering it on and off does not work. I called Dell Tech Support and they told me reseat my video card and memory. They also had me try hitting F2 and F12 on startup, but that didn't work because the screen is not coming on. They then told me it is a "NO POST" situation and they are going to send out a service tech to my home with a new MOBO, Video Card and Power Supply. Also, I had noticed the fans were running at full speed all of the time. I wonder if this all started when I updated my BIOS a few weeks ago???
Did you finally get your computer fixed and what was the problem?
  • Dell Master
  • 2,045 Answers
Ugh-ogh... are you such an advanced user to re-flash BIOS?
Posted on Mar 27, 2017
  • 479 Answers
SOURCE: Dell inspiron 6400-runs slow on AC power but not on battery
uninstall any energy management software provided by dell and then check.if the issue is not resolved then the issue is with the converter board as it is heating up.
Posted on Jan 29, 2009
SOURCE: Acer Aspire one using linux on powering up will
Please reinstall linux once again
Posted on Jul 14, 2009
ArmenianTech
  • 24 Answers
SOURCE: Dell XPS M2010 Starting Problems
Ok. Here is the thing. I hope everybody sold their problem, but I will just post for others who may experience the same thing.
1st believe it or not : there is nothing wrong with motherboard, as when you press the power button, computer will shut down. with defective motherboard it will just continue running untill you will unplug it.
2nd believe it or not : it can not be battery issue or hard drive issue, because it does not make any scenes in any way. I have to agree that hard drive on the right is semi-correct answer.
REASON:
IT is video card that messing up everything. And it is located right under right hard drive. That's why when somebody removed hard drive he/she accidentally corrected the cooling system of video card , which returned M2010 to live.
CONFIRMATION:
1. First remove the top cover from the computer. There are 2 sides the plastic things. If you look at the back of your laptop you will see 2 small holes , one on every edge of the back. You stick something there it will loose the front cover.
2. unscrew all the screws hat have ">" or "<" signs next to them. there are something about 15-16 screws in total: this will allow you to open the cover under wich you can find the motherboard and stuff. When you open the cover pry to start the computer, and you will see that fans will not start even after 1-2 minutes after you hit the power button.
3. Remove the right hard drive and under it you will find screws A, B, C, D (silver) and also 1,2,3,4 (black) unscrew the black ones first, them remove video card with the cooling mechanism. now try to turn on the machine. you can see that after like 20-30 seconds fans start working which means that motherboard is fine and it was the video card that was giving problems.
SOLUTION:
1. I am not sure what causes the issue but I have fixed it this way:
uscrew silver screws and disconnect cooling part from the actual video card.
2. clean both, video card and cooling system not touching sky blue foam ICs. That staff is needed to cool the chips on the video card.
3. let them dry for an hour or so after cleening, than apply some Thermal compound, thermal paste and re assemble the video card with the cooling staff. (mek sure no screw is loose or something)
4. put it back and turn on the computer. If it works , whell .. it works now :)
if not then either you levae some liquid on the video card or screws are loose. try to play a bit with screws. but my personal suggestion is just to wait for a minute or two until video card gets hot and fixes liquid problems itself :)
Try it. It worked for me perfectly ...
Posted on Oct 08, 2009
SOURCE: Dell D600 wont go into bios mode
Hi ,
if you wanted to get the bios setup you have to press Fn+F1 then you will go to the bios setup
Posted on Feb 27, 2010
  • 1481 Answers
SOURCE: toshiba a210. Wont boot. stays in startup screen,
boot files / Win files corrupt....
re-install OS
visit my site
www.sureshayyar.110mb.com
get all details on installing Win XP
pls leave a feedback...
reg
Posted on May 10, 2010
I have a HP Compaq model NX 6110 laptop,which was working well until last week when it started to freeze but when you press on it especially above the touch pad it works,that trend continued until last...
That sounds like you have a bad connection in that vacinity.
Removing the case and resetting the contacts may fix it but it could be a crack on the motherboard.
Good luck.
Dec 29, 2010 | HP Compaq nx6110 PC Laptop
My Dell Inspiron 1525 will not start up all the way. It was fine last night but all I get now is a black screen the the mouse showing. I can't turn it off unless I hold down the power button. I don't know...
boot computer when it first starts up push F8 for advance menu. in advance menu select last known good configuration. hit enter . if the computer ges to desk top do a system restore . to before the issue started. if this fails you will need the windows disk to do a system repair. your configuration may be corrupted.
Nov 16, 2009 | Dell Inspiron 1525 Notebook
HP nx7300 no boot
I guess your battery needs to be flash.
Apr 10, 2009 | HP Compaq nx7300 Notebook
Dell m1330 will not boot
Try and get into safemode by continuosly pressing f8 on restar then selecting safemode
let me know if you can do that
Jan 13, 2009 | Dell XPS M1330 Notebook
Car alarm
iook out for any windows that are just open.no flies in side the car,make sure that the battery is fully charged.or the last bit to look at is the boot and hood pins are adjusted correctly.
Jul 17, 2008 | 1988 Mazda 929
Mach speed
Unplug the the dsl & any other device except the keyboard & mouse. Double check the video cable at both ends monitor & PC. Boot up system. If the system starts shut down & connect 1 device. Boot the system. OK? continue to do this. On the dsl there is a reset button. With it unpluged from power use a pen & hold in the reset for about ten seconds. Reconnect the power & reconnect the Rj45 to the PC. Boot system.
Jan 26, 2008 | Mach Speed VENOM MSA2-6100V Motherboard
Dell Inspiron XPS M2010 Notebook Logo
115 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
