Question about Toshiba TP55H60 55" Rear Projection Television
My 1 year old daughter runs to the tv and hits it she has broken the 1st 2 screens but the tv is still watchable but it also gets a blue and red area across the top and bottom of the screen when this happen i also see a double image if i turn it off it will be ok but it is starting to happen more and more frequently whats wrong and can i get repalcement screens?
  • 508 Answers
When you get fixed buy piece of plexiglass at hardware store size of tv tape to front of tv to keep her from doing again!!!
Posted on Jun 28, 2009
Tv wont boot up
This is a prime case of bad capacitors in power supply. You may have only had it a year but how old are the parts that are in it?
Oct 30, 2017 | Televison & Video
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
My new (used) Sony Trintiron recently took a fall and the screen was damaged. The damage appears to be a gash approximately 4-41/2 inches long and 1/4 inch wide. Is there a way I can fix this or get a...
The tv CRT-(tv tube) screen itself is broken now or dying already and tv PCB board broken require replacing too,tv will still work after replacing PCB board or repairing it but tv will not be watchable becauuce tv screen will all mess up like screw up picture colors will have black and blue colors be all over the tv screen.Tv now will not be worth repairing if require replacing CRT-(tv tube) will cost the same as a new tv if tries replacing CRT-(tv tube) if u still can buy it.Can't buy analog CRT-(tv tube) anymore.Sorry time to buy a new tv.
Apr 14, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Hello i have a samsung 47 inch hdtv model # Hcn4226W And i have a black area at the bottom of screen about 2inch high from the bottom of the scree..It double lettering on the screen and a little blurry . I...
Convergence issues again, try using the manual adjust with the remote.
you can only adjust the blue and red, if the green is wavy or the Red and Blue won't more then you will need the ICs or CBA changed again.
Jul 25, 2009 | Samsung Televison & Video
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Panasonic DMR ES20DEB blank screen but sound
THE CONNECTION HAS BEN CHANGED FROM AV CONNECTION (RED, WHITE, YELLOW ) TO COMPONENT CABLE (RED, GREEN, BLUE) YOU WOULD HAVE TO SOMEHOW RESET THE DVR TO DEFAULT SETTINGS TO GET IT BACK TO NORMAL.
Nov 11, 2008 | Panasonic DMR-ES20EG DVD Recorder
DEC Super Multi-system TV Unlock code
Just hold down the display button for 10 seconds. Boo-yah! Lena xxx
Nov 01, 2008 | Televison & Video
Ds3224
push reset on remote twice quickly
Jan 05, 2008 | Sanyo DS32224 TV
Toshiba TP55H60 55" Rear Projection Television Logo
95 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
