Yes. Go to HP's site:
http://h20564.www2.hp.com/hpsc/swd/public/readIndex?sp4ts.oid=1846090
and they have drivers for Windows 8 and Windows 10.
SOURCE: Fussion Error
This has been very common lately. Sounds like the fuser is starting to fail. If the printer is under warranty you may want to claim this.
SOURCE: i have hp laserjet 3005dn printer . today morning
First delete old documents.after tyr again print.
SOURCE: HP LaserJet 3005dn drivers free download
You need to download the printer drivers from the Compaq/HP WEB support/download page. Make sure you select your model printer and the XP or Vista Windows version of the drivers you require and install them.
Click on this link to download the drivers: -
www.hp.com/#Support
SOURCE: I am getting problem with
Printer error code "49.4c02" is one of them. It occurs when there is corrupted data. This may confuse the printer, and it stops functioning. In other cases, the data is corrupted while being transferred to the printer. Some printer models are naturally prone to this error because of their driver, while others can display this error while printing a specific font. http://www.fixya.com/support/t6031482-hp_laser
SOURCE: 49.2f9d error hp laserjet 3005dn
Most times a 49.xxxx error on an HP printer is caused by either the print driver, firmware or the print job itself.
If it happens when printing a PDF file try sending the file to the printer as an image.
Upgrade the print driver and the firmware.
You may need to disconnect the printer from the pc or network, power it off and pull the plug for a couple of minutes to clear the error.
If it's a network printer it would be a good idea to check the printer queue for any jobs still in it and delete them before powering the printer up again.
Yes it does
