Question about HP Photosmart C4180 All-In-One InkJet Printer
My HP C4180 printer will not turn on. I notice that a flash of light occurs when I plug it in different outlets, but the on/off button does not respond. It was working fine the last time I tried to use it before I shut down the computer for a trip. When I came back and booted the computer, the printer wouldn't come on, and it won't come on regardless of whether or not it is connected to the computer or any outlet I've tried in the house.
    President:
  • 3,085 Answers
You probably have a bad AC adapter. Check eBay to buy a new one.
Posted on Jun 28, 2009
    President:
  • HP Master
  • 1,447 Answers
Yes it is the problem your printer AC adopter or motherboard is demage
Posted on Jul 05, 2009
C4180 All in One. Paper Jam error will not clear
The used leaked cartridge is not the problem, but please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00651302&cc=us&lc=en&dlc=en&product=1141647
Apr 10, 2010 | HP Photosmart C4180 All-In-One InkJet...
My HP C4180 when powered up shows on the display screen the following: 83c00020 and does nothing else. The only way that I can power it off is to unplug the printer from the wall outlet.
press cancell (red x)button adn power button at same time then release.you will see enter special key combo on screen. then press blue button once then green button once then gray button once. it willshow some support url... then press blue button 2 times you will see reset menu.press ok on it. then press blue button 2 times agaiun you will see semifull reset. press ok.then pritner will turn off.turnm it back on it will get resolved.
Dec 16, 2009 | HP Photosmart C4180 All-In-One InkJet...
Hp psc 1401 printing slow problem
Reset and relocate the productA power reset drains power from the product and returns the product to the same settings after restarting. To eliminate any potential power deficiencies that might hinder a successful alignment, HP suggests you move the product to another location and plug the product directly into a wall outlet. Follow these steps to reset and relocate the product.
  1. Press the On/Resume button to turn on the product.
  2. With the product turned on, disconnect the power cord from the back of the product.
  3. Relocate the printer to a different power outlet, preferably an outlet in a different room.
  4. Plug the power cord directly into the wall outlet. Do not use a power strip, extension cord, or surge protector. CAUTION: Do not reconnect the power cord to the back of the product at this time.
  5. Load letter or A4 size unused, plain white paper in the tray.
  6. Reconnect the power cord to the back of the product.
  7. Press the On/Resume button to turn on the product. The product automatically prints an alignment page.
Oct 13, 2009 | HP PSC 1401 All-In-One Printer
My printer is not turning on.
the first option is trying a different power outlet and the next step if that doesn't work is to replace the power cable or ac adapter of the printer, see if that will do the trick.
Jul 13, 2009 | HP Photosmart C4180 All-In-One InkJet...
My printer shows error C4EB8401 when switched on and wont print?
Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
Wait 30 seconds.
Plug in the power cable to All-in-One and also to wall outlet.
[Now turn On the printer and check the functionality
if the above does not rectify it
3. Now turn On the printer.
is this is still not working then it is due to the print cartridge cradle packing up.
and you might have to face buying a new one, but I hope the above will help
Jan 17, 2009 | HP Photosmart C4180 All-In-One InkJet...
C4180 Won't Power On
Make sure the plug is all the way into the AC adapter. Then, you will need someone to verify the output of the AC adapter. You should have a 16VDC and a 32VDC output from the adapter. If that is good, you have an internal problem with the printer. If the output voltage(s) are missing you will need to replace the AC adapter.
Here are the specs:
  • Input voltage: AC 100 to 240 V ~ 1 A 50–60 Hz, grounded
  • Output voltage: DC 32 Vdc===940 mA, 16 V===625 mA
  • HP part# 0957-2146 Call 1-800-227-8164 for availability.
  • Nov 19, 2008 | HP PhotoSmart C4180 All-in-One Color...
    Lights flashing
    Try the steps mentioned bellow
    Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One. and wait for atleast 1Min
    Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
    Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
    until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
    Then check and see
    Good Luck
    Sep 09, 2008 | HP PSC 2410 All-In-One InkJet Printer
    Starting up
    1. Plug the printer directly to the wall outlet.
    note : do not use any power surge. just plug the unit directly to the wall outlet
    2. Reset the printer by unplugging the power cord at the back of the printer while its still on. Plug the power cord after 30 seconds
    Aug 08, 2008 | HP Photosmart C4180 All-In-One InkJet...
    HP Photosmart C4180
    Try the steps mentioned in the link bellow:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01369982&cc=us&lc=en&dlc=en&product=1141647
    Try connecting the All-In-One directly to different outlets without any surg protector.
    Even if this does not work then try with a new Power cable and Power adaptor and check.
    Good Luck
    Jul 23, 2008 | HP PhotoSmart C4180 All-in-One Color...
    HP PhotoSmart C4180 All-in-One... Problem:
    Try the resetting the printer to factory defaults.
    Steps:
    1.Turn the Printer OFF, unplug the power cabled from the back of the printer and from the wall outlet.
    2.Then, Press and hold the ON button for 30 -60 seconds
    3.Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold CANCEL and COLOR COPY button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
    Please let me know, the status. GoodLuck cheers!!
    Thank you ...
    Feb 15, 2008 | HP PhotoSmart C4180 All-in-One Color...
    HP Photosmart C4180 All-In-One InkJet Printer Logo
    203 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
