Question about AO Smith Plumbing
My water pump is locked and is making a hum noise. What do you recommend doing.
    Scholar:
  • 89 Answers
IS IT AN ABOVEGROUND OR SUBMERSIBLE (INGROUND) PUMP. USUALLY THIS IS CAUSED BY A BAD CAPACITOR OR BURNT POINTS ON THE PRESSURE SWITCH. THE CAPACITOR IS EITHER IN A RELAY BOX AT THE WELL OR IN THE MOTOR CASING. HOPE THIS HELPS. JODY
Posted on Jun 29, 2009
  • 1 more comment
  • Bob Butcher Dec 24, 2010
    When my pump did this, it was burnt contacts on the motor start switch. This switch is located on the end of the motor shaft inside the metal cover on the back end of the pump motor. It is designed to be closed when the pump is off, connecting the starting capacitor to the motor windings. When the motor gets up to about half speed, the switch is supposed to open, disconnecting the starting capacitor. If the contacts are burnt or if the unit is worn, sometimes the switch does not close as it should, and the motor will just hum and not start.
  • gandara Jan 16, 2011
    Can these parts (capacitor or burnt points) be purchased and replaced or does one just have to buy a new motor?
  • Bob Butcher Jan 16, 2011
    I got it working at least for now. I cleaned the contacts with a fine file, which is not recommended since they are plated. Then I had to adjust the contact spacing by tightening the mounting bolt enough to collapse the U shaped metal spacer. The original problem was that the parts had worn to the point that the contacts were barely touching when the motor was off. I found instructions on adjusting the switch on the internet.
    New starting capacitors are cheap and easy to find. The motor starting contacts on the other hand are a bit pricey. I have found several sources ranging in price from about $60 to about $90, which is a lot considering that a new motor can be had for under $200.
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
WHY IS MY FRIGIDAIRE FRONT LOAD WASHER MAKING ODD NOISE AND NOT SPINNING?
Hello Friend, thank you for your post!
Often when a washer does not spin, it is because your washer cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair washer.
Best regards! - Z
Jul 11, 2014 | Frigidaire Washing Machines
Won't spin out water
Good Morning Bernice, thank you for your post!
Often when your washer does not spin, it is because your appliance cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your appliance.
Best regards!
Jan 31, 2014 | Frigidaire GLTF2940ES Front Load Washer
Works OK but the water will not pump out
Good Morning Jim, I am happy to assist you. Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Aug 15, 2013 | Frigidaire FWS833A Top Load Washer
EIFLS55IIW The washer is humming and starts to
Hello Chad, I am happy to assist you. Often when a unit does not complete a cycle, it is because the unit cannot properly drain and dispose of the water and detergent solution. Since the unit is making a humming noise, there is a possibility that the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. The burnt smell can be due to a faulty potential wiring failure. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Aug 09, 2013 | Electrolux EW1000i Front Load Washer
I TURN ON THE POWER AND SELECT A WASH CYCLE AND ALL I GET IS A HUMMING SOUND.
Hi Jo - Often when a unit is making a humming noise, it is because the unit cannot properly drain and dispose of the water and detergent solution. Either the drainage hose or pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Jun 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Figidaire FTF630as0 won't agitate. The door locks and water drains but won't agitate or spin
Hello Tina Kaha - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Apr 19, 2013 | Frigidaire ATF6000ES Front Load Washer
Wont spin
Hello Patricia,
Mar 24, 2013 | Frigidaire ATF6000ES Front Load Washer
Washer wont drain
Hello shirley_dods - Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs cleaning. Try setting the cycle to spin cycle only. Will water pump out? If it does not, then the washer could possibly be experiencing a communication error with the control board, faulty pump, timer or door lock assembly. At this point, I recommend connecting with a professional to accurately pinpoint any potentially more serious issues.
Mar 04, 2013 | Frigidaire FEX831CS Top Load Stacked...
Fridgidaire Washer wont drain
If lid lock is bad the tub will not spin properly. Unplug, remove front and look at the lid lock closely. Let me know, Thanks, Sea Breeze
Jan 08, 2009 | Frigidaire GLWS1233A Top Load Washer
Plumbing Logo
456 people viewed this question
Top AO Smith Plumbing Experts
David Baisa
Lawrence Oravetz
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
