Question about Ovens
Neff oven film strip has become dislodged so not showing temp.
Model U1551N0GB/01
  • 157 Answers
Replace it is the only way goto
bshappliancescare.co.uk
Posted on Jun 30, 2009
Neff H5972N0GB combination oven. Its a new item that was panel damaged at the back. On plugging it in, the panel on the right does not light up to show the settings - normally red back light. With a...
most likely the backlight bulb is broken. It depends on the type of display if it is a easy fix or not. All models after 2010 have LED backlight. But who knows maybe there is only a connector dislodged. I who say disconnect the mains and open up the frontpanel.
Feb 01, 2015 | Neff Ovens
Front cool touch facia model Neff | B1262W0GB/01 | Built-in Oven | white needs to be replaced please help source and how to fit
Part number is 289510, I have checked with Neff and unfortunately is is no longer available. The part was 230 quid!!! and that was just for the front portion as the fascia comes in three parts. I have added the link so you can check yourself, just enter B1262W0GB/01 in the search box and click on Page 2
http://www.neff-eshop.com/eshop/neff/gb/sparepartsearch1.htm
Feb 19, 2013 | Neff Ovens
Oven temperature on Neff 195305317 circotherm oven
hi remember that electric can kill you even if it is unplugged, if you don't know what components are likely to hold charge or have large inductance get someone else to fix it.
you need to get the service manual as tis will have fault finding charts, part numbers, location of sensors etc. If you can't get manual then:
Not likely to be temp limiter as this cuts out if temp is too hot. Find temp probe, may be ntc, mercury vapour switch etc. take probe out disconnect leads and measure resistance, heat, or cool, probe measure resistance if not significantly different (ie 10k to 100k or 100k to 300k) then probe is shot. Take probe to spares place, get replacement and refit. Be very careful to refit leads exactly as they came out, don't want insulation to melt and oven to become live. test with oven or meat thermometer as new sensor may need calibration. Should be accurate to within 10C or so
hope this helps
Nov 10, 2012 | Neff Ovens
Top oven temp display shows 4444
Control panel needs to be replaced. It may also be an error code for the repairman.
Jul 22, 2012 | Neff U1661 Double circotherm super...
My neff oven's handle has become loose. I cannot see any screws. how can i tighten handle ? the model is U1422 oven.
You need to remove the inner glass panel, should be 2 screws at top and 2 at bottom and remove. The screws for the handle are behind this
Mar 02, 2011 | Neff U1421 Double circotherm Electric Oven
How can I remove the fascia panel from my Neff double oven? I have a Neff U1552 oven. The display-film strip showing the temperature for the fan oven broke. I have bought a replacement part from Neff and...
did you manage to fix your strip, i have the same problem, all4 strips have broken in the last 6 months on my U1552. how much was the replacement?
Jan 02, 2011 | Neff Ovens
MY NEFF DOUBLE OVEN IS ABOUT 8 YEARS OLD I HAVE CHANGED ELEMENT 2 OR 3 TIMES ONE RECENTLEY 2MTHS AGO NOW OVEN IS STILL TRIPPING OUT REGULARY ANY SUGGESTIONS PLEASE HAVE ALSO CHANGED RCD AND HAD ELECTRICIAN...
it sounds to me that the fan is not working properly. as the oven gets older the fans become weaker and then doesn't blow air over the element at a rate that can the temp down enough..
regards
Richard Saupe
http://www.saupe.co.uk
Oven Specialist
Mar 02, 2010 | Neff U1721 Double circotherm Electric Oven
Oven not heating up
If the fan is working, then it is pretty safe to assume that it is the element that is faulty..
If the thermostat was faulty, you would normally get the oven heating, albeit at the wrong temp.
If the temp indicator lights up, that shows the stat is working.
Plz rate my solution.
Thanks.
Jan 10, 2009 | Neff Ovens
Neff U1422 oven overheating
Hi
Yes it does sound like faulty thermostat.
You will have to remove the oven from the oven housing, and remove the top cover, and possibly the front console.
Then you will have trace the sensor back to the main oven, and unfasten sensor in oven
You will probably have to remove the rear
panel as well to get the thermostat sensor out.
One other possibility is the sensor may have become detached inside the oven, this will then affect the oven temp.
Good luck
Hope this will prove helpful.
Nov 22, 2008 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
128 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
