Question about Toro Lawn Mower With Toro Power Tools
My Toro LX425 keeps on blowing 20 amp fuses when I am mowing the yard. Why is it doing that?
    Sergeant:
    Champion:
  • 320 Answers
A fuse will blow if: a positive wire is being grounded to the frame or two much current is being passed thru it.
Posted on Jun 29, 2009
Toro lx 420
sounds like short to groung earth check wire back its possably chaffing on metalwork some were
May 25, 2014 | Garden
I have a Scag zero turn mower and the fuses keep blowing 20-30 minutes into mowing my yard. It will die in the middle of mowing. I changed 5 fuses the other day withing my time of mowing. We checked all...
Does the scag have the control switches in one of the control arms? Have you tried taking a test light going to battery positive and hooking that into the feed supply side of the fuse( the side of the fuse that does not have battery power to it) if the test light is on this would mean that is shorting to ground somewhere within the harness at that time you'll need to wiggle each part in the harness while watching the light to go out or blink showing your close to the source of the short a close examination then you should locate it. Bare or chaffed wire.
Jun 11, 2013 | Garden
My toro keeps blowing fuses when i turn the key i have a toro 14-38hxl wheel horse rider
its either getting to many amps which will blow fuses
you might have a short (positive wire touching metal)
fuses are not right ie: 10 amp when should 15amp
trace the leads from the key switch (turn it on) to your coil check that they are good
the coil might be faulty
hope this helps
Sep 30, 2011 | Toro Lawn Mower With Toro Power Tools
Lx425 has grinding noise but won
replace the starter gear. the starter is probably fine and alot cheaper if you just relplace the gears.
Jul 14, 2010 | Toro Garden
New Poulan gas mower blowing white smoke
if its new carry itback theres a number of things it could be but it sounds like the crankcase is full of gas check the oil and see if theres gas in it.
Oct 25, 2009 | Toro Lawn Mower With Toro Power Tools
How do I get instructions on replacing both upper and lower drive belts on a LX425 Toro Lawn Tractor?
You can go to Toro.com and look at the lower left side for "Homeowner" or "commercial" parts. If you enter your model number you can get an owners manual online. I tried your LX425, but didn't come up. Maybe a different number?
Oct 25, 2009 | Garden
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro lawn tractor
There is a switch on the seat and one on the brake pedal
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Frozen blade spindals
Yes apply some heat and it will break it lose and the system will spin just fine
Feb 13, 2009 | Toro Lawn Mower With Toro Power Tools
Toro lx425 rider mower wont start
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
Oct 05, 2008 | Garden
Toro Lawn Mower With Toro Power Tools Logo
1,146 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
