Question about Shanling CDT-100
Noisy at very low volume!
Hi my shanling cdt-100 which i bought second hand has an audible disc spinning sound which you can hear at low volume levels, is this normal? any suggestions would be greatly appreciated, i believe the unit is unmodded.
many thanks in advance gary
I had the same problem... if it's mechanical... this is the solution....under the lid is a free floating magnet clap which centers and sits on top of the dics when the lid is closed.This rides to low when the lid is down and rubs on the inside lip of the lid which prevents the clap from falling out... solution... cut a piece of scotch tape the same size (circle) as the inside magnet surface of the clap... stick it on...now the clap with magnetic clap as before but will be a few 1000ths higher...mike
Posted on Mar 28, 2008
Give me @ LEAST THREE problems of CURRENT DIVISION THEOREM with solution
a 30 ohms resistor is connected in parallel with a variable resistance R. The parallel combination is connected in series with a 6 ohms resistoe and connected across 120 volts source, find the minimum value of R, if the power taken by R is equal to the power taken by the 6 ohms resistor.
Mar 04, 2011 | Shanling CDT-100
Can the audible volume be turned up louder on a
I think the only solution for you my friend will be too invest in a headset of some kind which should plug into your unit which will help you to hear better.
May 03, 2010 | Garmin nuvi 650 GPS Receiver
Noise at maximum volume
NEVER turn the volume up to maximum if you suspect there is ANY signal coming in.
Is this an academic question, or does it really bother you at normal listening levels with a signal present? What you're doing isn't very real-world.
My own excellent system has audible hash noise present when I turn the volume up to max on a dead input, but it's still less than normal ambient noise in the room so I don't worry about it.
Feb 18, 2010 | Audio Players & Recorders
Where can I get a new CDT-100 remote control battery compartment cover?
E-mail:shanling@szonline.net
or goto http://us.shanling.com/en/contact.asp
For any question in purchase, application and care & maintenance ofyour products, you can dial the service hotline +86-755-26887661 tocontact us, and you will be offered detailed and satisfactory answersas well as excellent services. For more after-sale support information,please click the Service Center button on the menu bar.
Jan 19, 2010 | Shanling CDT-100
Sometimes cd wont turn or play. CD seems to catch the lid when spinning. Is there problems relating to the lid position after time? Any ideas/history. Thanks
That usually happens when you get the reading lense scratched (from inserting dirty cds with dust, grease or finger prints). So, since the cd content cannot be read, it just don't give the command to the chip that converts the input data (whatever the content of the cd) into output data (what you listen or what you see from the cd). Hope it helps, good luck,
Jan 03, 2010 | Shanling CDT-100
My new Acer Aspire one D 250 laptop has a very low volume output . All the volume controls are up including wave output but with no success
Right click on the speaker icon in the task bar, lower right hand corner of the screen.
Select "Adjust Audio Properties."
In the popup box, go down to "Speaker Volume." Click "Advanced"
In the new pop-up, make sure that "Laptop speakers" is selected. Click all the OKs you need to in order to establish that setting and clear out of "Adjust audio properties."
Now you SHOULD have much better sound from your speakers.
For some reason, my D250 keeps defaulting to "Stereo headset" which produces much lower volume sounds when a headset is not inserted. So low that you can't watch and hear a video through the speakers and understand what is being said. Once you switch to "laptop speakers" you'll be able to hear stuff. It won't be high volume, these things just don't put out high volume, but it will be reasonably audible, if this was the problem.
Nov 25, 2009 | Acer Computers & Internet
My Shanling CDT200 CD player does not spin when I put the down lid or press play. Can you please help? The problem began by first what sounded like a clicking sound & interrupted play. The player is...
This is the case in most CD Players. . .
when you close the lid, it will try to read the CD.
If it recognizes and reads the cd, the cd will spin-up.
If not, it would say no disc.
try to clean the cd-player's lens by using a commercially available lens cleaner. if it still persists, it need a new optical mechanism.
Oct 23, 2009 | Shanling Audio Players & Recorders
Shanling CD-T 1where can i download the user manual
Oct 19, 2009 | Shanling CDT-100
Transport malfunction
In my opinion, spindle plate is pressed and when top cover lowered there is not enough / required gap between optical lens and CD so laser is not being focused to read data properly.
Please hook a flat screwdriver under spindle plate and turn it very carefully so spindle plate pushed upward little bit as shown below picture....hope this will work.
Nov 28, 2008 | Shanling CDT-100
Shanling CDT-100 Logo
246 people viewed this question
Top Shanling Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Shanling Audio Player and Recorder Expert? Answer questions, earn points and help others
