Question about Dishwashers
We had a LE code (leakage) which we fixed ourselves. The problem was a cracked hose. How do you reset the dishwasher and remove the LE flashing code?
  • sassy_susan Jun 28, 2009
    Samsung DMR57 Series
    President:
  • 744 Answers
Hi, you can reset this code by switching the breaker of for a half hour...reset the breaker and you should be good to go...this resets the microproccessor..if the code comes back you still have a problem. Hope this helps...good luck!
Posted on Jun 29, 2009
    Sergeant:
  • 326 Answers
May i know the exat model of u r dishwasher
Posted on Jun 28, 2009
I have a Samsung dishwasher DW80J994 series with an error code5C that sometimes appears.. Cleared drain hose and drain, but the dishwasher won't reset. What Can I do to reset it?
Repair and or check: Check for water leak under the dishwasher. Check the hoses, drain pump and tub. Replace any leaking components.
Parts Needed: Hoses or Drain pump
I am going to show you a video on how to check for these issues as well. This may not be your particular model but it will give you an idea of what you are going to need to do
https://www.youtube.com/watch?v=CIcQdApm6l0
Samsung Dishwasher LE leakage code FIX
We Are Here to Help !!!
Aug 09, 2017 | Samsung Dishwashers
Tip
LG Dishwasher Fault Codes
Failure Code > Condition : Check/Repair
  • 1E Water inlet problem > Condition : Not reached to the normal water level in spite of 10 minute water supply. Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
  • OE Drain error > Condition: The drain hose kinked or blocked. Wiring connections. The drain outlet of sump is blocked. The drain pump/motor or circuit is troubled : Remove kink. Check wiring. Measure the resistance of drain motor (20-40ohms) Replace the drain motor or repair the circuit.
  • E1 Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.Replace the connections of hose. Check the point of damages and repair or replace the related parts. Correct drain connections. Replace the impeller of the washing pump.
  • FE Excess Error > Condition : Excessive water is supplied than normal water level (automatically drain pump operated. Possible cause: The inlet valve is troubled,or the controller.Possible cause: The inlet valve is troubled,or the controller. Replace valve or the controller.
  • BE (Thermal error) > Condition: the resistance of the thermistor not normally out put. Possible cause the inlet water temperature is very high(over 194°F) Wiring connections. Thermistor problem.Check temps to dishwasher 120°F needed. Check thermistor 11-14kohms at 77°F. Replace the PCB.
  • LE( Motor error ) > Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.Correct wiring connections. Replace the cause of resrtiction. Replace the washing motor. Replace the PCB.
on Feb 26, 2011 | Dishwashers
What is wrong with my lg dishwasher it is flashing E1
see http://www.appliancepartsquick.com/LGDishwasherFaultCodes.html and
http://www.fixya.com/support/t193162-error_code_e1_lg_dishwasher
Jun 23, 2014 | LG 24 in. LDF 7811 Stainless Steel...
Samsung Dishwasher error light "heavy" or leakage error
I had the same problem, SAMSUNG did not want to tell me how to fix so I jumped in with research I found that after you remove the power supply, i.e. plug, 1) you need to remove the dishwasher and turn it upside down. 2) There is a white sensor tray; 12x12 approx. on the bottom held in with two screws, remove the screws and use a flat head screwdrider to undo the clips holding the tray in place. 3) Dry the tray and sensor tips with a towel and replace the tray. Bammmm, you have just fixed the LE(leaking error) code error.
Feb 19, 2013 | Samsung DMT400RHW Builtin Dishwasher
DIGITAL DISPLAY SAYS LE
Hello, W/D here.
The LE code indicates that the dishwasher thinks that there is a leak, and the leak detector shut the machine down and displayed the LE code.
If you in fact have a leak, it should be repaired either as warranty work or by a reputable repairperson. The LE code can be reset by turning off the circuit breaker controlling the power to the dishwasher for several minutes, then resetting it.
If you have a stainless dishwasher, it is guaranteed for life (usually) against leakage. Samsung will require a service call by their tech, and if the unit is unrepairable, will depreciate the unit before offering a refund. Not great. The good news is that these are fairly robust machines, and leakage might be no more than the door seal. Check the seal and reposition it if necessary, as they not only tend to flatten out, but they also tend to pull out of their grooves holding the seal in. It seems that in making the "tall tub" types, there is less space between the racks and the seals. Larger objects, especially on the upper rack, can bump the seal and pull it out of position a bit, creating a leak. It doesn't take much.
If you bought your machine from one of the major hardwares, and you got the extended warranty, they will make three attempts to repair the unit, then replace it if unsuccessful.
Hope that this was helpful to you. --W-D--Please feel free to rate this solution. Thanks.
Feb 21, 2011 | Samsung Dishwashers
A screw fell inside the tub I took the bottom sreen apart it was uder the base were the impeller is, took that apart, put everthing back together and went to start the dishwasher up and the LE code...
try this. I have a similar problem and now have the LE code flashing. I saw this advice and am going to try the fix now.
You are barking up the wrong tree. Here is the real fix for the LE problem.First disconnect all power ( power supply, circuit breaker, wiring etc) to the machine. Disconnect all tubing to the machine ( drainage pipe and braided hose feed) Then you need to take out the dishwasher, turn it over and then remove the large white sensor tray that will expose the leakage sensor held on by 2 screws. Remove the screws and dry up the sensor tips (4) with a dry towel and dry up the tray all around as well. Replace the tray and re connect all tubing and power. You're problem should be solved and you just saved yourself a pile of money in service repair bill. M.D.
Dec 22, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Had something in pump had service guy fix it he cant get code le out i dont want to pull it out cuting power di not fix can you help
LE error code is a water leakage underneath the sump pump. There is a sensor with 4 wires. Could be corrosion on it or there is actually a leak underneath. You best bet would to go take the underneath appart look at the sensor and look for signs of leakages. Also take the small pump off, put some of that white tape plumbers use(I forget the name right now) and put it back on.
Dec 03, 2009 | Samsung Dishwashers
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
The panel has a LE ERROR.
LE is an ie .. water inlet problem. ... manual says to check for clogged, kinked, or frozen water inlet hose. check water supply.
OE. Drainage problem
FE excessive water supplied
E1 water leakage problem
HE heater circuit failure
TE thermistor failure, or very high inlet water temp
PF. power failure.
Jun 05, 2009 | LG LDS4821WW 24 in. Built-in Dishwasher
Dishwashers Logo
202 people viewed this question
Top Dishwashers Experts
