Question about Ricoh Office Equipment & Supplies
Hi I have Ricoh Alficio 2032 copier. There is C545 error message
Hi I have Ricoh Alficio 2032 copier. There is error message C545. what does this mean and how can i solve the problem. Thanks Alex
    Scholar:
  • 175 Answers
I'm assuming it's SC545. It pertains to temp not being correct in the fuser. Possibly a thermistor, thermal fuse or lamps are bad. It's one of the codes that need to be troubleshot and replace whatever is needed before clearing the code. This is to prevent further damage to the machine. Thanks Colin
Posted on Jun 29, 2009
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
Can send Fax but not receive error message 0-22 on the fax report
The error message means you have received an fax but there were problems because of poor line condiotions. Ask to resend. Here is lonk to manual.
Ricoh FAX5600L Operator Manual Error Codes
Jan 30, 2015 | Ricoh Aficio Office Equipment & Supplies
My alficio 1035 is having a paper jam on the drum area and immediately report error SC395 this problem started after a toner hooper change. the second problem is that it is losing toner and som is falling...
SC 395 Development output abnorma.
Remove the development unit and clean the gears.If necessary change the developer.Remove the OPC imaging unit and clean the cleaning blade.
Apr 10, 2013 | Ricoh Aficio 1035 Copier
Possible causes of your sc545
• Hot roller thermistor is out of position or most likley dirty
• Fusing lamp broken -- not likley
• Thermostat broken -- could be tripped check with a meter for 0 ohms
Once we are sure all fuser components are ok then reset the code by entering sp mode
execute sp 5810
if there is no 5810 then just turn off the machine while in sp modes
Apr 14, 2010 | Ricoh Office Equipment & Supplies
How to solve error SC471 on my Ricoh alficio cl7000
This is a transferbelt home position error.
Book says:
1. Turn the main switch off and on.
2. Reset the transfer belt unit.
3. Clean or replace the transfer belt
sensor.
4. Replace the transfer belt contact
motor.
5. Check the contact and release
mechanism of the transfer belt unit.
My guess is cleaning will solve it.
open the front door and sing don the green lever
locate the 2 screws at the top and bottom of the unit and remove them.
remove the cleaning unit 1 screw and a thmb lever slide the unit out (its on rails) wipevacum and/or blow clean the unit and re assemble
also clean the connector that it plugs to in the back of the machine
(q-tip)
if it still appears belt or unit will need to be replaced
Apr 04, 2010 | Ricoh Aficio CL7000 Laser Printer
How can I turn off the warning beep on the Alficio MP4000?
You should be able to find this under user tools -system settings
Feb 22, 2010 | Ricoh Aficio 450 Copier
Error message on a Ricoh 2000 SC441. What does
SC441 mean scanner or laser unite problem.Open it and clean laser mirror,or clean scanner door sensor.
Dec 09, 2009 | Ricoh Aficio CL2000N Laser Printer
Error message on Ricoh Aficio BP 20 PCL 6 printer
Flashing orange means low toner.....solid red should be a paper jam
Feb 20, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
220 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
