Question about Yard Machines Red Edger
Need a diagram for edger pulley system 1 belt 4 pulleys
  • 155 Answers
Try this site its called pats small engines just look up your model and it will show you an exploded view.
Posted on Aug 04, 2009
How to put on new belt
https://www.partstree.com/parts/troy-bilt/edgers/tb516ec-25a-516-966-troy-bilt-edger-2011/general-assembly/
Zoom into the diagram, remove (item 45) belt cover to expose the belt and pulleys. Take note of how the belt is routed.! you will need to follow the same route with the new belt. You may need to remove the Blade guard (item 40) if the belt doesn't fit over the head of the guard. There may also be a sprung idle tension pulley, which will take up the slack in the belt once replaced. Looks pretty straight forward.
Apr 19, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Replacing a belt
Replacing the Drive Belt
IMPORTANT: To aid in reassembly, note the orientation
of the drive belt on the two idler pulleys and the engine
flywheel pulley prior to performing the following steps.
Refer to Figure 10.
The edger drive belt is subject to wear and should be
replaced if any signs of cracking, shredding or rotting
are present. To replace the belt, proceed as follows:
1. Working in front of the edger, loosen the flange
lock nut on top of frame, allowing the idler pulley
assembly to pivot slightly out from the frame. See
Figure 10.
2. With your other hand, carefully reach under the
rear of the unit and remove the belt from around the
engine flywheel pulley.
3. Remove the spindle sheaves belt guard by removing
the two self-tapping screws which secure it to the
blade plate assembly. See Figure 10.
4. Carefully remove the belt from the pulleys,
again making sure to note the orientation of the belt.
Discard the belt.
Install the replacement belt (Part No. 754-04032B) in the
same configuration that the original belt was routed as
follows:5. Working from the front of the edger, place the belt onto
the spindle sheaves, route it back onto the two idler
pulleys, and then place it onto the engine flywheel
pulley.
IMPORTANT: Make certain that the "V" side of the belt
is seated into the top pulley and the flat side of the belt is
seated into the bottom pulley.
6. Reinstall the spindle sheaves belt guard with the self
tapping screws removed earlier.
7. Make certain that the drive belt is on the engine
flywheel pulley and idler pulleys, and retighten the
flange lock nut on the top of the frame.
IMPORTANT: Make certain that the drive belt is seated
correctly and that it is riding smoothly on the spindle
sheaves and is not pinched between them. Repeat the
first three steps if the belt is pinched.
You don't want the belt pinched between those spindle sheaves...trust me ;)
the manual
Oct 13, 2012 | Troy-Bilt tb554 lawn edger
Apparently the serpentine belt was thrown off my 1998 Mercury Mystique. It appears in good condition. Should it be replaced or can it be reused? Also, do you have a belt diagram? Thank-you.
You can reuse it. But you need to find out why it was thrown off. Check all the pullies by grabbing them and checking for side to side movement, With the exception of the power steering pump pulley (which has some in and out play) they all should have no play. Just turn in nice smooth circles. Sorry I don't have the diagram, but there should be one under the hood. Sometimes on the bottom of the hood.
May 22, 2011 | Mercury Mystique Cars & Trucks
Need a belt diagram for a 03,f-150 4.2l w/ac
2002 with a/c, best I can do.
Item Part Number Description 1 10344 Generator pulley 2 8678 Belt idler pulley 3 8509 Water pump pulley 4 19D784 A/C clutch pulley 5 3A733 Power steering pump pulley 6 6B321 Crankshaft pulley 7 8678 Belt idler pulley 8 6B209 Drive belt tensioner 9 8620
May 04, 2011 | Ford F-150 Cars & Trucks
Serpintine belt diagram
what engine? Please rate if it helps
3.L v6
snorkelbobby_26.gif Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 2E884 A/C clutch pulley 4 6316 Crankshaft pulley 5 6B209 Drive belt tensioner 6 10344 Generator pulley
2.0L Zetec 4 cyl with A/C
snorkelbobby_27.gif Item Part Number Description 1 10344 Generator pulley 2 19A216 Belt idler pulley 3 3A733 Power steering pump pulley 4 6C301 Drive belt 5 2E884 A/C clutch pulley 6 6B320 Crankshaft pulley 7 8509 Water pump pulley 8 6A228 Drive belt tensioner
Jan 12, 2011 | 2002 Ford Escape
How do I change the belt?
I do not have a diagram but i changed the belt on mine today. The belt will loop over the back left pulley then inside the middle pulley with the back of the belt towards the bottom pulley and the v shape in the top of the pulley you then pull the belt over the front pulley( next to the blade) with a screwdriver and thats it.
Jun 22, 2010 | Yard Machines Red Edger
Need diagram for a 2005 mustang 4.0 liter for serpintine belt
Hope this helps ya.. Cobra.. :-)
Item Part Number Description 1 10300 Generator pulley 2 3A733 Power steering pump pulley 3 2E884 A/C compressor pulley 4 8509 Coolant pump pulley 5 6B321 Crankshaft pulley 6 6B209 Accessory drive belt tensioner pulley 7 8678 Accessory drive belt idler pulley 8 8620 Accessory drive belt
Jun 14, 2010 | 2005 Ford Mustang
Serpentine belt diagrm
Not sure if you have the 3.0L 2V or the 3L 4V so heres both. Hope it helps.. Cobra,, :-)
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 2E884 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6312 Crankshaft pulley 8 8509 Water pump pulley
Item Part Number Description 1 3A733 Power steering pump pulley 2 8509 Water pump pulley 3 2E884 A/C clutch pulley 4 8620 Drive belt 5 6312 Crankshaft pulley 6 6B209 Drive belt tensioner pulley 7 10346 Generator pulley
Jun 05, 2010 | 2000 Ford Taurus
Belt diagram
2 valve
Item Part Number Description 1 8679 Belt idler pulley 2 10344 Generator pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6312 Crankshaft pulley 6 8509 Water pump pulley 7 2E884 A/C clutch pulley 8 6B209 Drive belt tensioner pulley
4 valve
Item Part Number Description 1 19A216 Belt idler pulley 2 10300 Generator clutch pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6316 Crankshaft pulley 6 8A528 Water pump pulley 7 19D692 A/C clutch pulley 8 6B209 Drive belt tensioner pulley 9 19A216 Belt idler pulley
Oct 26, 2009 | 2003 Mercury Grand Marquis
Serpentine belt diagram for a 5.9 diesel with air and 9 pulleys
5.9L DIESEL
196759.jpg The 5.9L diesel engine accessory drive system (with a/c) consists of :
  1. Generator Pulley (1)
  2. Water Pump Pulley (2)
  3. Idler Pulley (3)
  4. Power Steering Pump Pulley (4)
  5. Radiator Fan Pulley (5)
  6. Crankshaft Pulley (6)
  7. Automatic Tensioner (7)
  8. A/C Compressor Pump Pulley (8)
CAUTION: When installing the accessory drive belt, the belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. Refer to or for correct engine belt routing. The correct belt with correct length must be used.
1. Position drive belt over all pulleys except water pump pulley. 2. Attach a 1/2 inch ratchet to tensioner.
196757.jpg The 5.9L diesel engine accessory drive system (without a/c) consists of :
  3. Idler Pulley (3)
3. Rotate ratchet and belt tensioner clockwise. Place belt over water pump pulley. Let tensioner rotate back into place. Remove ratchet. Be sure belt is properly seated on all pulleys.
Sep 13, 2008 | 2008 Dodge Ram 3500
Yard Machines Red Edger Logo
463 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
