Question about Pasquini Livia 90 Espresso Machine
When i clean my machine, the release valve isn't working as it should. the pressure builds up in the head and water just trickles out of the release valve. i've had my machine for approx 1 year. Could the filter be stopped up? Is there a way to take out the filter in the water reservoir?
Correct me if I'm wrong, but this is what I think you're doing when you clean your machine: You place a blind filter in the portafilter handle, along with about a ½ teaspooon of approved cleaner (Puro Caff, Cafiza, etc.), then lock the portafilter into the group head and press the brew button.
Since the blind filter has no holes to allow the hot water to pass through, the pressure keeps building in the line until it the 3-way valve opens to release the pressurized water into your drip tray.
Sounds like what you're saying is that the amount of water being released into the drip tray is just a few, slow drops, presumably indicating that if you keep the brew switch turned on the pump eventually reaches some high pressure limit beyond which it's not accomplishing anything (you'll still hear it try to vibrate, but since the fluid isn't moving anywhere, the vibratory movements aren't accomplishing anything other than to maintain the high pressure in the line. If this is indeed the case, then you should be getting quite a messy release of all that pressurized water if you were to turn off the brew switch and try to remove the portafilter from the group.
Now, if all these things are true, then it sounds very much like a stuck/plugged up 3-way valve. If the group has been cleaned (as described in the first paragraph) infrequently, if ever, then it's not uncommon that the line running from the group to that 3-way valve is plugged with old grinds that worked their way back there, one shot at a time, but never got flushed out.
In addition to backflushing with hot water (very frequently), you also backflush with a cleaner (maybe once a month?), and at that time you remove and clean the brass dispersion head and screen. You can see how much gunk builds up there even with a pretty regular habit of backflushing. Well, by design that backflushing pushes those nasty old grinds back up the line to the 3-way valve. So you can see that if the dispersion head & screen weren't cleaned regularly, or if the backflushing routine (with cleaner) wasn't being done properly (or at all), it wouldn't take long for that whole line and maybe also the 3-way valve to become increasingly clogged until the flow is reduced to a few drips, even under 1.5 bars of pressure.
If you don't regularly tinker with plumbing and electrical repairs, this would probably be a good time to take your machine in to a local authorized repair facility. They'll probably replace your 3-way valve and clean out the whole pathway from the group head back to that valve.
Posted on Sep 21, 2009
    President:
  • 3,433 Answers
There is apossible restriction, but, whatever actuates the rrelease valve is what is actually malfuctioning.Depending on you level of detertermination, you can follow my approach to the dilemna if mass production. Since it doesn't work, find out why! Worse case scenario is the trash can, the best, A better understanding and working knowledge of the appliance. Screws usually hold these things together. Expresso machines are not inexpensive and there is a reason for those big bucks. No glue! So always taking the electrical part into consideration, there is no reason you cannot disassemble the unit and entertain yourself while at the same time learn something. Always take the approach that someone assembled it and you can disassemble it. If it does have glue, rhen it was anever intended to be serviced or repaired by anyone. So give it a shot and if you run into a problem, Give me a holler and we will keep moving. My ph. # is 909-630-3192. You may have to send me a picture or two of our project, So have a camera ready.... Ned
Posted on Jun 28, 2009
What is wrong with my pressure washer when I turn in on there is no pressure to the spray
Dear Sir,
Most probably, you left the pressure on when you used it last. You could also have let it with soap or chemical in the system.
When you finish using a pressure washer, you should, after switching off and removing water inlet...RELEASE THE PRESSURE. Before this you can, pass clear water to clean and clear any chemical or detergent. Now to get to the problem. If you do not release the pressure and do not clean from detergent.....this will result in jamming the SPILL VALVE. This valve controls the pressure and controls the shutting down of flow, after gun is closed. Myself I prefer to renew the Spill Valve, than to service it. Now to get to the spill valve....this requires professional work. But if you have the right tools, you can get to it very easy. Usually you can spot a Spill Valve, by noticing a micro switch, with wires protruding out....on top or near the spill valve.
Also beside the spill valve.....there could be something that have locked a valve open. Thus pressure never builds up. To check this, the machine needs to be dismantled altogether. In a few words, the machine can get fixed, but if what I mentioned is too difficult for you, you have to get professional help.
Regards.
Fulltech.
May 24, 2014 | Karcher Garden
Whirlpool lbr5232eq1
assuming you have a decent flow rate and pressure to the machine from the fill hose I would suspect the hot water valve is faulty
Mar 04, 2014 | Washing Machines
I have an old whirlpool stylemaster no.907675 and the water is just trickling out! Is this a filter problem? I have no idea how to fix this!!! Help please!
Water trickling is a sign of clogged inlet screens or faulty inlet valves. First turn off the water, remove the two hoses inspect them for debris. If clogged use a tiny hook to remove the screens clean and install. If they are not dirty your inlet valves are bad. Also has your water pressure seem any less in pressure? Good luck!
Mar 19, 2013 | Washing Machines
I have a GW512. The cold water is only trickling into the machine. The hot works fine. I have checked and switched hoses and cleaned them etc. Still only trickles in to the machine. Would it be the inlet...
Hi dan, in all probability it is your inlet solinoid valve, due to high sediment build up in the main water supply can cause the inner diaphragm of the inlet solinoid valve to clog up and stick. you can pick up a new inlet valve anywhere from $25-$60 depending on the appliance spare parts outlet. If you produce your model number with the name of the machine to the spareparts store they will easily be able assist in your matter, even better supplying the spareparts store with the inlet solinoid from the machine, thumbs up if this helps thanks.
May 02, 2011 | Fisher Paykel EcoSmart GWL15
All hooked up dobble cked but water only trickles so ample supply
Make sure the hot water is turned back on. Pressure balancing valves won't work if both cold and hot water is not on. Pull shower head off and test to see how it flows out of the shower arm. If good, clear out shower head. Whenever water is turned off for a time, and then turned back on, restricting shower heads and aerators usually get clogged. In the future, always open up a tub spout before turning water back on. This releases the air and other debris most effectively before testing other fixtures in the house.
Apr 23, 2011 | Moen 3175 Legend One Handle Shower Faucet...
Cold water is trickling in want to clean filter/screen where and how too
There is probably a filter built into the inlet valve where the hose screws onto it. There may be a filter/seal where the hose screws onto the tap. If there is water pressure to the inlet valve, it could be that the inlet valve itself is faulty........Generally a simple job.......Good luck...Nomess
May 16, 2010 | Washing Machines
Karcher 3.97M Short cycles after trigger is released.
Dear csdamman,
There is a valve called the spill-valve. It is often called the control valve. This valve activates the micro-switch. When the gun is released, pressure builds up and compresses this spill valve. At the same time it puts off the micro-switch. This will then stop the machine. Now when the spill valve is faulty it cannot hold compreesion under pressure so it starts de-compressing and starts the machine again. This goes on in a cycle as you explained. So you have to change the spill valve. If the spill valve that operates the micro-switch is part of the upper head,...then the whole head must be renewed. Myself I rarely service Spill Valves. The best thing is to renew it. From your explanation it seems that you did not take notice of this Spill-Valve. Infact when you mentioned Pressure Switch, I do not know if you are refering to the spill valve. If you are....then saying that the Pressure Switch moves and operates freely, does not mean that it is OK.
In certain machines in the outlet...there is a small valve, coloured black and red or green and yellow. This sometimes when faulty, it gives the fault you mentioned. Sometimes an inlet valve gives the fault you mentioned. But from my expirience it is most of the time that the Spill-Valve is the fault.
Regards,
Fulltech.
Jul 21, 2009 | Karcher PSI Electric Pressure Washer
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
My Livia 90 dosn't build pressure
Clean out the shower screen and the diffuser under the grouphead, turn the head on without the screen and diffuser, if water flows strongly then the problem was in the diffuser and screen, if you have no flow, then the line to the haed is clogged.
Jun 18, 2009 | Pasquini Livia 90 Espresso Machine
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Pasquini Livia 90 Espresso Machine Logo
257 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
