Question about Tivola Electronic Publishing Masters of the Elements Full Version for PC, Mac
The procedure entry point FT_thunk could not be located in the dynamic link libary KERNEL32.dll.
The procedure entry point SetCurrentDir could not be located in the dynamic link library KERNEL32.dll
That's weird, Is it a legitimate copy of windows? or a pirated copy? another question would be, do you have any messed up programs set to load at the start up? because that could cause the error your getting.
Aug 31, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Kernell32.dll error on photoshop cs6
hi,
i downloaded Photoshop cs6 trial and when i click the Photoshop icon to open the software i get a window:
Photoshop.exe - Entry Point Not found
The procedure entry point GetLogicalProcessorInformation could not be located in the dynamic link library KERENEL.32.dll.
What can I do???
I have allready tried to reinstall....
still the same.....
HELP
Dec 16, 2012 | Adobe Photoshop CS6 Extended 65170137
Missing kernel32.dlll file
In most dll related problems. You can either have it totally gone or there is a version conflict...
1. Pinpoint the filename or which dll or ocx exactly fails...
2. Search for dll file from a site like http://www.dll4free.com or http://www.missingocx.com
3. Download and reinstall
4. That should done the trick...
Jun 03, 2012 | Sid Meiers Gettysburg
CoD2SP_s.exe entry point not found
the procedure entry point _AIL-3D-provider_attribute@12 could not be located in the dynamic link library mss.32dll.
Mar 03, 2012 | Activision Call of Duty 2 for Windows
The procedure entry point SMapLS_IP_EBP_12could not be located in the dynamic link library KERNEL32.dll
hi,
try to reinstall the IE because once that error occurs, it indicates that your IE is corrupted due to some improper installation or uninstallation of some programs or devices.
hope this helps, good luck, Godbless
http://www.onlinepcrepair.vox.com
http://www.onlinepcrepair.url-go.com
Dec 04, 2009 | Fisher Price Learning in Toyland...
Msvcrt.dll error message("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll")
to produce entry point _except_handler4_common could not be located in the dynamic link library msvcrt.dill
Apr 19, 2009 | Microsoft Windows XP Professional
When you clck on the tool too go on msn messanger it says "the producedure entry point SetDllDirectoryW could not be located in the dynamic link libary KERNEL32.dll. So what do i do?
http://support.microsoft.com/?kbid=142606
If you click "ok" does the system complete its boot? And does the error message include a program name?
And does this message display before or after you actually log in and before or after the desktop appears?
Post a HijackThis Scanlog if you can:
Download and install HijackThis using the "self extractor". Run it and select "do a system scan and save the log file". Then copy/paste the contents of the log to a reply
http://www.thespykiller.co.uk/files/hijackthis_sfx.exe
Aug 15, 2008 | Computers & Internet
Unable to log on to computer
BRING IT INTO BEST BUY SO THEY CAN RUN A DIAG ON IT, YOU MIGHT HAVE BAD HARDWARE, OR THE DISK YOU MADE WAS BAD.
Jun 11, 2008 | Computers & Internet
Pixe view TV Tuner CArd
you can grab the xp drivers here
http://www.prolink.com.tw/
and for watching tv, you may be able to use this
chris tv lite freeware
http://www.softpedia.com/progDownload/ChrisTV_Lite-Download-2301.html
Nov 15, 2007 | Televison & Video
Tivola Electronic Publishing Masters of the Elements Full Version for PC, Mac Logo
425 people viewed this question
Top Tivola Electronic Publishing Computers & Internet Experts
David Payne
David Payne
Are you a Tivola Electronic Publishing Computer and Internet Expert? Answer questions, earn points and help others
