Question about LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive
Fan keeps going, blue light always on, clicking noise
Ethernet Lacie EDmini i. e. transformer. Started with continuous fan and was not able to turn blue light off. Now makes clicking noise blue light is always on and computer no longer sees drive. The only way to turn off is pulling the plug. Is the problem in the hard drive?
  • 6,831 Answers
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Posted on Dec 08, 2010
Value of the memory capacitor on the PCB of the LACIE EDmini v2
If the voltage and the farads are higher than the original it won't make any difference what you put in. They are not much greater than 47uf, if you think it's 10uf than put anything above that in. It will really depends on the physical size of the replacement. Get one they same size as the one that's gone and you can't really go wrong.
Jun 19, 2012 | LaCie Computers & Internet
Hello. I have a LACIE EDMINI-V2 that won't start, no disk noises, no light from led in front button, nothing. I have dismantled the box, connected the disk drive to my PC and its ok, measured the 5V and...
I owned one just like this and the power supply failed at about 1 year. It turns out it's a fairly common problem. Since you have the device open, does the controlboard/motherboard look burnt at all?
If it is not damaged, you may be able to buy a replacement power supply here: http://www.lacie.com/products/range.htm?id=10030
If it is damanged, then you may still be under manufacturer warranty, contact Lacie here: 503-844-4503 sales@lacie.com
Please leave feedback for this answer, thanks.
Mar 09, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Hi, I cannot connect my Lacie "EDmini Ethernet 400 gb" on to my laptop (dell with windows 7) via the Ethernet option? The blue light goes on but the disk cannot be found by my laptop. Could you...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Feb 02, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I can't connect to Edmini via LAN nor USB. LAN computer doesn't detect then I tried to check edmini from browser then I get this message /www/cgi-bin/public/sharelist: line 246: cannot create temp file...
Just contact www.lacie.com great support. there answer for my drive was to upgrade the drive version and to reboot the drive. Maybe the last thing is enough. For me it worked.
If necessary update driver http://www.lacie.com/nl/support/drivers/driver.htm?id=10156
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Jul 29, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Lacie edmini 250 GB will not power up
sounds like a faulty power circuit within the external housing. remove all screws and the drive from its housing. you now hold in your hand an internal hdd. remove all jumpers, if any are present, and install this drive on the same cable as your master hdd. now when u boot up to my computer window, you will see two hdd named C: and D:
Jul 01, 2009 | LaCie (300770) 250 GB Hard Drive
No access to the disk, same clicking sound + constant light
It may not be getting enough power. Is there an external power supply you can plug in or another USB connector that can be plugged in to another port?
Jun 18, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
Lacie 500gb external drive
The disks inside the HD are not spining. The creaking noise is the HD trying to start. Next time when it does start transfer all the files ASAP cause your drive is about to die.
rmatheson@wowway.com
Sep 30, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Powering up my Lacie ethernet disk 250
When I had this problem it turned out to be the power supply unit. Lacie replaced it - if you are out of warranty you can buy them for about £25 - and this solved the problem.
Sep 01, 2008 | LaCie (300770) 250 GB Hard Drive
Open Questions:
See all LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive Questions
LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive Logo
853 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
