Question about Dell Dimension 4700C PC Desktop
Steady Amber LIght
I bought a new motherboard, new power supply, new hard drive. The new power supply works (fan is on), but computer still won't turn on. What else should I check?
  • 3MANDR Jun 28, 2009
    Where is it?
    Ok, I took the memory cards out and reinserted. I removed the battery and reinserted it. I unplugged the computer. I replugged it. Still steady amber light. Now what?
  • Dell Master
  • 13,433 Answers
Do you have the 4 pin cpu power plug connected?
So the computer Does turn on, but you just don't get a picture? cpu fan spinning and evertyhing?
what kind of video card do you have there?
Posted on Jun 29, 2009
  • Ekse Jun 29, 2009
    can you post some details about what parts did you purchase? motherboard brand and model and so on.
    Sergeant:
  • 326 Answers
Check the ram remove the bios battery for a while and reinsert it. remove the ram and reinsert it.
Posted on Jun 28, 2009
Computer has an solid amber light and wont power up
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
The leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty. Any bad or faulty power or data lead or connection can cause a computer not boot up.
Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. Make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard Make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs Power and Data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty power lead or fan lead can cause you problems computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ Make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Feb 08, 2013 | Computers & Internet
Dell 8400 dead
Can you tell if your hard drive is running? You can here it or feel it spinning. Are the fans running? If no, I'm 99% sure you need to replace your power supply and/or motherboard. This kind of thing usually happens after a power surge.
Sep 24, 2007 | Computers & Internet
Motherboard or possibly something less dramatic?
No! you have done everything you can, the motherboard is the issue and the only option is replacement.
Jun 01, 2012 | Dell Inspiron 518 Desktop Computer
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
My dell GX 270 computer has amber mother board light,No display,processor fan runs,power supply fan rotates.
hi ansilesh
If the power light is steady amber - The computer is receiving
electrical power, but an internal power problem might exist.
Ensure that the microprocessor power cable is securely connected to the
system board.
it might also be a failed mainboard already since you are experiencing a blackout.
hope this helps
janc30
Feb 11, 2011 | Dell (002TR) Motherboard
I put in a dynex 400 wps power supply a couple of years ago and it has been working fine. Got a wireless keyboard and mouse for xmas installed it and now get a steady amber power light and the blue hard...
Solid AMber power LED indicates a failure of the motherboard or an item connected connected to the motherboard. Disconnect all external connections except power and see if the indication changes. If yes, re-connect one at a time till the fault is found. If no, remove all PCI Expansion cards, see if any change, if yes, again try them one at a time till issue ID'd
If issue still occurs, failure is most likely the motherboard
Dec 26, 2010 | Dell Inspiron 531s Desktop Computer
I got the steady Amber light of Death in my dell.
As a hardware repair technician at a local university, I have seen the amber power light problem on quite a few Dell computers. If the machine is in warranty, Dell insists the power supply be the first thing replaced, even if it tests ok. If that does not do it, then they send me a new motherboard. Of the dozens of machines that have had this problem, only 1 of them needed a new motherboard. The power supply alone resolved the problem on all the rest. I have found this to be true on out-of-warranty systems as well.
Jun 28, 2009 | Dell Dimension 8400 PC Desktop
Computer will not turn on
  • Blinking Amber/yellow: Initial state of LED at power up.
    Indicates system has power, but the POWER_GOOD signal is not yet active.
    If the hard drive LED is off, it is probable that the power supply needs to be replaced.
    If the hard drive LED is on, it is probable that an onboard regulator or VRM has failed.
Apr 28, 2009 | Dell Dimension 4600 PC Desktop
Solid amber light on front amber on mother board
take the PSU (Power Supply Unit) from a known working computer, preferable to be the same model and test with it. when you do so make sure you disconnect any peripherals e.g ( Printer, CD-ROM, Floppy).
Look closely at the memory bay for any bent pins, and test with one memory at the time.
Let me know if this is still an issue.
Regards
Dec 23, 2008 | Dell OptiPlex GX280 PC Desktop
Dell Dimension 4600 Won't Boot Up, Steady Amber Light is on tower
I have seen with some of the small form factor dell's that there can be a motherboard problem; my expirence with the regular towers and the steady amber light have been power supplies. I have a dimension 9100 that is three years old now and I am on my fourth power supply. I am not sure that you would have one laying around, but in my past expirence its been teh power supply. On the ones that I have seen where it was the motherboard you could clearly see on the chipset where it was damaged from heat (it was burnt). Hope that helps
Nov 19, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4700C PC Desktop Logo
73 people viewed this question
Alun Cox
