Question about Toshiba 42H81 42" Rear Projection Television
My toshiba L875-S7308 screen won't turns on. How to fix it?
I have this laptop for two years. Last time using it, I just closed it, so when I tried to use it again, the screen didn't turn it on. It remains black since then. How can I fix it?
SOURCE:
  • 2427 Answers
SOURCE: Screen stays black after laptop comes back up from hibernation
Its software,, format and reinstall windows
Posted on Dec 31, 2007
  • 224 Answers
SOURCE: Toshiba 50hp66
I think that the pop you heard was an electrolytic capacitor blowing its top on the picture frame board. If you are able to check this for yourself by looking on the board for the one/s with a bulging top or are a brownish/black colour like something has caught fire. And also in this situation smell can be of great help as it will smell burnt out but PLEASE before putting your nose or anything else in the tv take all necessary precautions against electric shock and discharge any electrolytic capacitors in the vicinity. If you are not able to do this yourself find a competant technician. Hope this helps.
Posted on Oct 07, 2008
SOURCE: Screen remaining black after the TV is turned on
Some newer sets appear that way when there is NO signal to the set. That and my Sony looks like that when the bulb is burned out.
Posted on Dec 23, 2008
  • 17 Answers
SOURCE: screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Posted on Feb 22, 2009
SOURCE: Dropped Toshiba satellite a105 laptop, screen black
If you pull off the top part where the speakers are above the key board your monitor might be unplugged. i had the same problem with one
Posted on Mar 15, 2009
How to reset the bios password
In some cases its removing the CMOS battery inside the laptop and powering on with no main battery and no charger connected. Before putting it back together. The CMOS will not only loose the password, but it will also loose its settings including the time and date.
If you can load the laptop otherwise, Toshiba used to offer a windows tool for changing some CMOS options including unconditionally changing the password.
Oct 01, 2015 | Toshiba Satellite Computers & Internet
Toshiba laptop
If you mean the hdd password, unless you type the correct password, you cannot use the hdd again. If you mean the windows password, online programs will clear it for you but they are expensive.
Aug 26, 2014 | Computers & Internet
How to use webcam on satellite L875?
Usually, the built in web cameras are shown on the display and what you need to do is just pres the button to activate it. It must be on the side of your screen . If you can't find it that means that you have to contact the customer service of the manufacturer. Before you do that try to check the driver. You have the same problem as I do but I still have no web cam and sound even though my laptop is just a 2 years old. Good luck.
Jan 22, 2013 | Toshiba Computers & Internet
C675-S7308 user guide
Toshiba eSupport > Toshiba Satellite C675-S7308 Notebook PC > Main Support page,
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=3133815&rpn=PSC3UU&modelFilter=C675-S7308&selCategory=2756709&selFamily=1073768663
I invite you to click on the User's Guide tab.
[ Takes a few seconds before the first page comes up.
(It WILL come up)
This is because it is a PDF file. You are looking at an HTML version]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 25, 2012 | Toshiba Computers & Internet
I have a Toshiba Satellite R10 Model PSR10C-AN303E Laptop. I had lost the screen (went blank) last year. After googling I fixed the problem by opening the laptop and plugging backin the wires that came...
could be due to neighbours using WI Fi and interferring with your Wi- FI . Log into Wireless router and change the channel number from auto to the lowest channel number available plus 3 so it is different to all the people who use the auto channel mode.
Apr 04, 2017 | Toshiba Satellite R10 Tablet PC
I have a Toshiba satellite l355d-s7825 that, when booting up (before welcome screen) seems to go into some type of sleep or hibernate mode and the monitor flickers and goes out. If I open and close the...
hi
  1. Turn your computer on.
  2. Start pressing F8 on your keyboard about every second as soon as you turn the computer on until you see the screen shown below.03b7e06.png
1:Select "last known good configuration " using the arrow keys.
your laptop will be restored to the time it was working properly
still your problem is not solved then
2:instead of selecting " last known good configuration " now you select safe mode from here you safely turn Off the laptop.
3:if the above solution did not solve your problem do System restore
please rate me
Jan 02, 2010 | Toshiba VGA Board Graphic Card
Toshiba laptop screen
Can you see the toshiba loading screen when you first turn on the system? If yes, then load in safe mode and uninstall the driver and reload the video driver from toshiba's web site.
If you cant see video at all. (try) reseating the video cable to the motherboard, some laptops have a nasty tendency of having that cable come loose after beign opened and closed for awhile.
Jan 04, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite
I had two Toshiba laptops, one changed the mother board twice, went back to the shop 5 times. it is hard to find out why, that why Toshiba got suit a couple years ago.
Jul 10, 2008 | Toshiba Satellite A105 Notebook
Toshiba 42H81 42" Rear Projection Television Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
