Question about Oreck XL Professional Air Purifier
Red Light My machine is only 4 days old. I got the snapping noise and was advised to clean the Truman Cell. I, first, cleaned the wires as instructed with a q-tip. When I went to reset "Check Collector Cell" as instructed, red light remained on blinking. I then, removed the Truman Cell and cleaned and dried it as to the instructions. Resetting the light does nothing. It still remains red and blinking.
  • zdunskijoe
    zdunskijoe May 17, 2016
    had this happen to mine, bent the two prongs going to the truman filter and it stopped blinking. might be a bad connection.
    New Friend:
Slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Posted on May 06, 2013
    Scholar:
  • 70 Answers
Sounds like a bad unit.
Posted on Jun 28, 2009
Can you add a prefilter to an oreck truman cell to grab the larger dust particles and decrease the zapping?a humidifier in the room helps but when the furnace is going it can still be often.
it should have a prefilter already on it. they have a screen looking filter that goes on the front of the cell. If you don't have one you need to get one. You should also have a charcoal filter on the back side of the cell, if not then you'll need to get one of those also, the charcoal is for odors and not for filtering dust. Putting any other type of filter in front of the cell will just be turning this into a filter type cleaner and will be defeating the purpose of the reusable Trueman cell. You may as well just buy a different cleaner if you don't mind buying new filters instead of cleaning the cell. I would recommend cleaning the cell every 2 weeks to keep it working properly. This will also keep it from snapping, if yours is snapping it's already too dirty and needs to be cleaned, if it's snapping right after it's cleaned then you have a plate that is arcing in the Trueman Cell, I have posted a fix for the ProSheild Models to stop the cell plates from arcing.
Feb 19, 2015 | Oreck Air Purifiers
Red light stays on after cleaning
which model, do you hear arcing or snapping sounds when it's running? Check wires that run along the inside front of the cell, loose, sagging or broken wires will cause this.
Oct 02, 2014 | Oreck Air Purifiers
A red light flashing with clean filter
bad connection on plates or wires that run along the front of the plates in the cell. If you hear snapping or arcing then its the plates shorting out, look for bent plates and broken wires or loose sagging wires.
Aug 01, 2014 | Oreck XL Professional Air Purifier
How do I clean the Oreck Air 7
Hi There,
Here's how you can clean the machine, and I have copied the link to the owners manual below for your convenience.
Cleaning
The Cabinet
You can clean the air purifier cabinet with mild, non-abrasive cleanser and a
soft cloth. IMPORTANT: Unplug the unit from its electrical power source.
Do not spray cleansers or furniture polish into the louver or grill areas.
Collector Cell
Indicator light is green under normal operation and flashes red
when the cell requires cleaning. To clean, proceed as follows:
The red "WASH CELL" light will flash or illuminate when it is
time to clean your cell. However, it is recommended that every four to
eight weeks or if snapping sounds become frequent, clean your
electronic air purifier. Your electronic air purifier is still filtering the air
when the red light illuminates. Cleaning your electronic air purifier is a
snap too... and a must for efficient operation.
1. Turn the unit off and unplug it from the electric power source. If wall
mounted, remove unit from wall.
2. Remove front grill by unscrewing the retainer screw under the grill on
the cabinet bottom. (fig. 1)
3. Pull the cell out of the cabinet by using the two small handles on the
front of the cell. (fig. 2)
4. Snap off the charcoal odor absorber from the back of the cell. Change
as necessary for continued odor removal. (fig. 3)
5. Slide off pre-filter. This can be cleaned with the cell and reused. (fig. 4)
NOTE: Handle the electronic cell with care. Damaged metal plates
and/or broken wires will cause the air purifier to malfunction. (Do
not wash charcoal odor absorber; it is disposable.)
Cleaning with Assail-A-Cell® Cell Cleaner:
6. Using Assail-A-Cell® Cleaner, thoroughly saturate the cell and prefilter.
Be sure to spray between each cell plate and cover every
surface. Allow product to soak for a few minutes, not allowing it to dry.
Rinse thoroughly with water. For extremely heavy deposits, repeat the
process.
IMPORTANT: Dry the collection cell thoroughly outside of the
air purifier before reinstalling it into the air purifier. Ensure
that all areas including corners and areas that may trap
water are dry before reinstalling into the air purifier. DO NOT
process.
place a wet or damp collection cell in the air purifier.
Here's the link to the owners manual for your Oreck Air 7:
http://www.oreck.com/includes/customer-service/owners-guides/pdfs/3323-3018-AIR7-Rev-H.pdf
I hope this was helpful to you. If this helped, please be kind and rate the repair, or leave feedback for me. Thank you,
Chris Jones
GoVacuum.com
May 01, 2010 | Oreck Super Air 7 Air Purifier
Ionic Breeze GP S1830 - makes a sizzeling noise
Funny you should post this when you did as I just finished reassembling my S1730.
Mine was making very loud noise, arcing violently, smoking slightly and would give a good shock when you touched the plastic covers(yes dirty plastic will conduct electric current).
1. Unplug the unit
2. Take the plastic covers off, front has four screws and back has snap at bottom, both slide up when loose.
3. Wash the plastic covers
4. take the light out and clean it with windex
5. Vacuum the inside, be careful of the two corona wires
6. Find the bead on each corona wire and while turning them slight so the edges scrapes the wire, move them back and forth to scrap the white power off the wires
7. scrape the cone shape plastic that the corona wires runs into, this build up is the primary culprit of the arcing which is the noise you hear. be careful of the corona wires again. I used an exacto knife and gently scraped it, sandpaper has been suggested elsewhere, once done scrapping, wipe down to clean any residue. The top cones are only part accessible, after cleaning mine the noise still persisted but acceptably lower than before. I think if you completely take apart the unit you can clean this cones better.
8. Reassembly is the same is opposite of disassembling.
Hopes this helps you.
Aug 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Collector cell light always comes on
We purchased one of these in April 2009. Same issue appeared with us. Cleaned the cell and the "clean collector cell" still stayed illuminated. Checked the manual and the trouble shooting section stated to hold down the "air revitalizer button" till the "clean collector cell" light blinks three times. After this operation the light went out and all was fine!!!! Hopes this clears your issue!
Feb 02, 2008 | Oreck XL® Air Purifier
Red light when swith on power button ?
cell is dirty, or you have a broken wire in the cell.
Dec 22, 2007 | Oreck XL® Air Purifier
Oreck XL® Professional
clean your cell. Allso check for broken or loose tungsten wires in cell.
Dec 03, 2007 | Oreck (AIRCOM1WOI) Air Purifier
Ionic pro sizzles and crackles when I turn it on. it doesn't crackle constantly but, it like slowly pulses. it crackles for about a second every 4-6 seconds while it is on high, and a little less often...
"A blinking light indicates when the blades should be wiped clean with a damp cloth." I actually had a "handyman" contract last year to visit an elderly gentleman once a month and clean all 9 of his Ionic Breeze GP air purifiers. Before I did that for him, they would make hissing noises and he really didn't like that. Here's how to clean the operative compnents of these machines: First, unplug the machine and place on a work surface, such as a table or kitchen counter. Second, remove the metal blade insert from the top by gripping the release tab and lifting it up and out. Also remove the front and back grilles by pressing on the plastic tab at the bottom and lifting up on them. Third, use a damp rag or paper towel to wipe the three metal blades clean. Do not immerse this assembly in water, because it has to be completely dry when re-installing it in the machine. Fourth, use a small piece of damp paper towel to VERY GENTLY wipe clean the two thin wires inside the unit. These are located behind the two rubbery flat blades just inside the unit and can be accessed from the front side. You won't damage these rubbery flat blades by pushing your hand gently between them, but be VERY CAREFUL when wiping the wires clean. (This step is important, as the wires must be clean.) Fifth, using another bit of damp paper towel, carefully clean the wire attached to the inside of the front grille. Dry this off with a dry bit of paper towel, then clean any accumulated dirt off the front & back grilles. Check the metal contact near the bottom of the front grille (attached to the wire) to verify that it's clean and will make good electrical contact. Sixth, pick the unit up and turn it upside-down & right-side up about 6 to 8 times. The two wires inside have plastic beads on them that slide up and down the wires. This brushes any bits of leftover dust or lint off of the wires. (Again, these wires must be VERY clean.) Seventh, replace the front and back plastic grilles by placing them in their slots and sliding them down to snap into place. Verify that the assembly with the three metal blades is COMPLETELY dry, using a hair dryer if necessary to dry off damp areas, then slide it back into place from the top of the machine. Now the cleaning process is done, so plug the unit in and turn it on to test operation. If it makes ANY noise, then some component is not completely cleaned off, or still has a presence of moisture, which must be completely dried off before the machine is ready for operation. Hope this helps! ;)
Jun 17, 2007 | Ionic Pro 901P2RIP04 Air Purifier
The low button light is going out.
Oct 24, 2006 | Ionic Pro 901P2RIP04 Air Purifier
Oreck XL Professional Air Purifier Logo
3,510 people viewed this question
Top Oreck Air Purifiers Experts
brian kossman
Level 1 Expert
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
