Question about Nokia N81 Smartphone
My N81 8gb music player is not functioning. Whenever I go there, it takes a long time as though it is loading but does not because of that I can't play audio clips continuously. The only way I can play audio clip is by going to my file manager.
Try changing the buzzer but the sound will be slightly louder
Posted on Aug 11, 2009
Samsung Galaxy S YP-G70 8GB. When connected to Windows Media Player says it has 5GB. I've now filled this with music and even though there's another almost 2GB of internal phone memory I can't load anymore...
The memory is partitioned and is total memory. It is shared with other functions as you guessed. If you decrease the phone memory you might be able to load more music but I think the partition will prohibit you from doing this as it divides the memory with a partition wall that doesn't move.
Oct 18, 2013 | Audio Players & Recorders
MUSIC PLAYER OF NOKIA NOT ABLE TO FIND MUSIC FILES THOUGH MEMMORY CARD IS LOADED WITH MUSIC.REST ALL FUNCTIONS WORK NORMALLY.
hi...
you might have not updated your music library.
please update you library.
follow the steps..
1.Open 'music player'.
2.Open 'options'(left selection key).
3.open 'music library'
4.There wil be an option 'update library'
5.Please select it and it wil update the music player
6.Now you can use your music player
thanx
Jul 18, 2010 | Nokia 3110 Cellular Phone
I'm having trouble with my music play er pls. help !!! :(
Hello i hope u 'll be fine.... thanks for using fixya.
This problem is usually occur when music player don't load data of phone or memory card itself
  • Turn on your cell, when it 'll be on, Starting music player it 'll take some time to refresh
  • Now do in the options of music player
  • Second option 'll be music library open it
  • Go down there 'll be a last option Update Library,Press ok, it 'll take some time and hope it 'll load all your music and all music files 'll show in track list.
Enjoy
I hope this solution will work and helpful 4 u. Best of luck
Please do rate if if it is helpful
THANKS
Mar 01, 2010 | Nokia 3110 Cellular Phone
I have an M4304A MP3 player. Whenever I turn it
As told in the manual and setup guide, the power button has to be held for more than 10 seconds to reset the player:
Link to the manual , see page 25:
Player does not respond to key presses.
• If your player stops responding to key presses,
you can reset it by pressing and holding /
MENU for more than 10 seconds. Most of your
settings will be preserved; only the settings that
you have changed after your last power off will
be lost.
Link to the QuickStartGuide , see page 1 for English.
Need more help ? Just post a comment.
Dec 10, 2009 | RCA Audio Players & Recorders
Can't acces music player in nokia 3110 classic
well, first check your mem. card if it fits the specification e.g. <= 2 gb, good company, etc and having proper music files. if there are music files in phone memory, check their folder and put them in music files. this should work
if not, check a nearby centre
Feb 23, 2009 | Nokia 3110 Cellular Phone
My e matic audio mp3 player says sys error whenever I try to listen to music, even though I have recently synced many songs to it that says synced succecfuly. How can I fix it?
take the battery out for like 5 min's and put it bake in or if u still have the song on a cd take all of the songs out of ur mp3 then put them back in
Jan 06, 2009 | SanDisk Sansa e260 MP3 Player
Sansa m230
whenever i turn on my sansa m230 mp3 player, it displays the message, "not enough space for music DB, please free 8mb." And so i plug it into my friends computer and when i open the music folder on the device, its empty, even though it says that there is quite a bit of space used up. Do you have any answers?.
Sep 07, 2008 | SanDisk Sansa m230 MP3 Player
My brother just bought an mp3 player and it wontt let you put songs on it. Whenever wetry, the littlered triangle comes p and tells us tha there was trouble downloading the song onto the mp3. WEe've tried...
On some mp3 players, the songs cannot be copy-protected, even if the specs say they can take wma format. Also, the cheaper music subs don't give you transfer rights, even though they allow you to play the song on your computer. What music svc are you using? It makes a big difference.
Jun 25, 2008 | Audio Players & Recorders
Battery
The most likely culprit is not shutting off the MP3 player before you replace your battery. Whenever you cut the power source without giving the MP3 player a chance to save its settings, it re-syncs the music. Shut off the MP3 player completely before taking the battery out and it should not have to re-sync next time you start it up.
Jun 10, 2008 | iLO (2 GB) MP3 Player
I've had 2 crashed iriver X20
Hi. I just had solved my Build Library problem. Use my solution on your own risk.
The solution is the following:
1. open up a player (find 8 screws, not 6, 2 of them are on the left side of the player under the round stickers)
2. jently take off a circut board. (you need to access its bottom)
3. Find a memory chip. It is labeled like "samsung k9hbg08u1m"
4. find chip's key meaning start of pin numbering (small circle on the corner). There are 48pins. 24 on the left side (1-24) and 20 on the right (48-25) see chip's manual http://catalog.gaw.ru/index.php?page=document&id=11348 page 4
5. On the right side find pins 32-29 (find them as the second 4 pins from the chip's circle key opposite corner)
6. Connect them together with some metalic wire (don't touch two middle pins on the right side of chip, it is chip's power supply).
7. Holding those pins together connect USB cable to player's socket.
8. After a while player will show error on its screen, get metallic wire out of pins, and then the player will be available as flash storage on the PC.
9. Format flash storage with quick format.
10. Disconnect and assemble the player back.
11. Connect to PC and upload new music.
12. Feedback to fzymarev()yandex.ru
Oct 12, 2007 | iRiver X20 MP3 Player
Nokia N81 Smartphone Logo
120 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
