Question about Samsung Remote Control
My remote will only control the volume it wont do anything else,
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 70 Answers
Remove the batteries and hold down the POWER button on it. Then replace the batteries with fresh ones.
Posted on Jul 02, 2009
My panasonic up/down channel buttons on the side of the tv wont work
Try getting a Harmony remote control. It will operate your tv and anything else you can connect to it. When the TV gets too old to fix, the remote can be reprogrammed for the new TV, so it never gets obsolete. The remote is programmed from their website.
Mar 20, 2014 | Panasonic Televison & Video
Volume working
Code for NEO 1451 TV?(universal remote control)
Aug 14, 2013 | Samsung TV Remote Control
The volume stuck on max volume and will not respond to remorol or side panels
Some buttons on remote or on control panel is stuck. Look for it and try releasing them. Remove batteries from Remote and try adjustment from control panel. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Insignia Televison & Video
Will this remote work for any jensen pop My knob for the volume wont turn my volume up any more now im trying to see wil this remote help me?
carefully take batteries out of the remote locate any screws there might be holding it closed. pry open CAREFULLY with flathead screwdriver and separate circuit board from function strip with RUBBING ALCOHOL on paper towel gently wipe off if anything from front of circuit board do the same to magnetic buttons on underside of function strip put back together w/New batteries you should be good to go
Aug 27, 2010 | Jensen 143307 Remote Control
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
May 20, 2010 | Universal MX-900 Remote Control
My remote wont operate my sony TV volume
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Sony RMT-D155A Remote Control
Volume wont change
unfortunately these units require the remote to adjust volume visit www.remotes.com they have the remote for mvohd70 (the infrared headphones have volume on sides) if it is RCA cabled to your head unit you can control sound in car but if you are referring to the direct headphone jack remote is the only solution
Feb 15, 2009 | Liquid Video MVOHD70 Car DVD Player
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Dec 19, 2008 | Televison & Video
Harmony 890 channels and volume wont work
Sometimes you need to go into the menu page for the device that doesn't work and you need to "learn" the keys to the new remote. "Learn" meaning pressing the buttons on your original remote with the Infrared part of the remote facing the Infrared part of the new remote. This will help the Harmony remote duplicate the signal to the device you want to operate.
Apr 09, 2008 | Logitech Harmony 880 LCD Remote Control
Samsung Remote Control Logo
368 people viewed this question
Jerry Greenberg
Jerry Greenberg
