Question about Technics SL-BD20D Turntable
Turntable wont spin
Onkyo beltdrive cp1100a...platter does not spin but motor seems to be trying....does platter lift up to get at belt or do we need to undo screws on bottom...many thanks, Tim
  • Technics Master
  • 5,508 Answers
If the mat lifts up to reveal a hole then you might get at the belt that way. I would have thought that the platter will lift up anyway. It might be held by a clip washer, around the spindle, from the top, sometimes hidden under a glued plastic piece. If you can't get in that way unscrew the base.
Posted on Jul 12, 2009
How to put the belt on aiwa stereo full automatic turntable px e855
Lift off the rubber cover. On some turntables, you can pull the whole metal platter straight-up now. Put the belt on the outside of the bottom of the platter and drop platter back into the turntable base. Do NOT put the rubber cover back on yet. There should be one or two openings in the platter where you can see the pulley for the motor. Slowly rotate the turntable platter until the opening is over the top of the motor pulley. Now use a nail file to gently pull the rubber belt over the pulley. It should spin freely now. Now put the rubber cover back on and try it out. Belts are available from MCM Electronics and over online vendors. Let me know how it goes. Good luck.
Aug 16, 2014 | Audio Players & Recorders
Ferguson
Lift off the rubber cover. On some turntables, you can pull the whole metal platter straight-up now. Put the belt on the outside of the bottom of the platter and drop platter back into the turntable base. Do NOT put the rubber cover back on yet. There should be one or two openings in the platter where you can see the pulley for the motor. Slowly rotate the turntable platter until the opening is over the top of the motor pulley. Now use a nail file to gently pull the rubber belt over the pulley. It should spin freely now. Now put the rubber cover back on and try it out. Belts are available from MCM Electronics and over online vendors. Let me know how it goes. Good luck my friend.
Aug 12, 2014 | Audio Players & Recorders
Wont spin
Hello Bella, This is a belt driven turntable. Most likely, your drive belt has fallen off. It may be too stretched to stay on. To check this, remove the rubber platter mat. There should be holes in the metal platter, which if you rotate it, you will see the belt and the motor pulley. Remove the metal platter by grasping the holes. It should lift off. When the platter is off, try to slip the belt over the inside flat part of the platter. It should be snug. If it just falls off, the belt needs to be replace. For more information or parts, please go to my website, AUDIOSERVICECLINIC.COM. You can contact me through the website, and we can take this issue further if need be.
Thank you, Dave
Audio Service Clinic
Apr 13, 2014 | Aiwa PX-E860 Turntable
Onkyo Diagram
To replace a turntable drive belt.
Before starting ensure you disconnect the power supply.
1, Remove the rubber platter mat to expose the platter.
2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the center spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
7. Align the center hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
9. Replace the rubber mat and then run the turntable to ensure correct operation.
Remember, when changing between 33 & 45 rpm the platter must be rotating to ensure correct belt repositioning on motor pulley.
Job done.
Copyright, Styluscity.com
Apr 27, 2013 | Audio Players & Recorders
I received a SONY PS-LX250H turntable with the drive belt off. Where do I route the drive belt to get it back on?
The Operating and Install Guides are here...
http://www.retrevo.com/support/Sony-PS-LX250H-Turntables-manual/id/752ag608/t/2/
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C310321&fes=true&mdl=PSLX250H
Follow this procedure to install the belt on the turntable.
  1. Lift up on the dust cover [FIG. 1] and remove it from the turntable base [FIG. 1].
  2. Remove the rubber mat [FIG. 1] from the platter [FIG. 1].
  3. Lift the platter straight up off the spindle [FIG. 1].
  4. Slip the drive belt around the under side of the platter [FIG. 2]. IMPORTANT: Line up the ribbon that is attached to the belt with the square opening near the edge of the platter .
  5. Place the platter back on the spindle .
  6. Spin the platter so the square opening on the platter is over the motor pulley [FIG. 1].
  7. Stretch the drive belt [FIG. 3] over the motor pulley by pulling the attached ribbon [FIG. 3].
  8. Remove the ribbon from the drive belt .
  9. Reinstall the rubber mat and the dust cover .
Jan 29, 2011 | Sony PS-LX250H Turntable
My turn tabel isnt spinning
The drive belt has come off. Open the lid. Remove the rubber mat on the platter. Remove the C-shaped clip from the center of the turntable. Lift the platter up and off. Find the flat rubber band that connects platter and the motor. Plug it in and verify that the motor turns when you press power, then standby, then phono.If the motor spins, unplug power and place the drive belt on the underside of the platter. This is not easy, but it can be done with patience. Then put the C-clip back on and replace the mat. Congrats!.
Oct 10, 2009 | Philco 841205 Turntable
Belt location
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Jul 18, 2009 | Audio Technica USB Turntable
Ion turntable
7) That's it.
- OPTiC
MasterTech
May 09, 2009 | Technics SL-1200MK2 Turntable
Teac turntable belt came off.. help!
Through the 2 holes on the platter, lift the platter up. Take the belt, flip the platter over, and stretch it around the center ring. Flip the platter back over and turn to so one of the holes is over the spinning motor. With your finger or with a blackstick, stretch it back onto the motor head.
Also check the belt for wear....that should do it.
Keep me posted.
Dec 05, 2007 | Teac P-A688 Turntable
Belt off
Lift the platter. PLace the belt under the platter on the inside ring. PLace it back on the turntable, and you can stretch it back onto the motor with your finger or black stick through one of the holes on the platter, while the platter is positioned where it is accessible. if you need a replacement, try...
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES-Drive_Belts/c271_272_278_398/index.html
the technics belt #2 seems to be universal. The staff there is top notch and can get you the correct belt. Call them with your model.
Keep me posted.
Nov 03, 2007 | Pioneer PL-990 Turntable
Technics SL-BD20D Turntable Logo
362 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
