Question about Acer Aspire 5100-5033 Notebook
Acer orbicam is not operative althouch i have intalled the driver but not its utillity bar(it is a Bison cam) which i can not find!! and when i want to take a picture i have a blue screen problem!
Model5742 web cam not working
The Acer OrbiCam is a built-in 1.3 megapixel webcam mounted at the top of certain Acer laptops. The webcam can record video clips and integrate with instant messaging software. If you are trying to use your Acer OrbiCam but it won't connect, the driver--a small software file that tells the webcam what to do--may be outdated. Acer provides webcam driver update pages for the Aspire 9300 and Aspire 5570 versions.
1.Go to the Acer 5570 or Acer 9300 Driver Download page (see Resources).
2.Click "MS Windows XP" or "MS Windows Vista" on the drop-down menu, depending on your operating system.
3.Select "Acer OrbiCam Bison Driver" from the menu.
4.Click "Save File > OK" and wait for it to download.
5.Double-click on the downloaded setup files to install the driver.
6.Go back to the Acer Downloads page, and select "Acer OrbiCam Driver Bison Utility 1.0.0.13" from the drop-down menu.
7.Click on "Save File > OK" and wait for it to download. Double-click on the downloaded setup files to install the driver.
8.Restart the computer.
I hope you find it very helpful. Thank you for using fixya
Aug 18, 2011 | Acer Aspire 5610-4648 Notebook
Acer OrbiCam not working (acer aspiral9412zwsmi)
Has it worked in the past, on this computer?
Have you recently upgraded to Vista?
Here is a suggestion:
There are two software entities involved – the camera Drivers and the OrbiCam application itself
The new driver and a new version of webcam application (below)
The correct files to download are:
Acer Orbicam driver (Bison)
Acer Orbicam Bison utility 1.0.0.13
These can be found here under the MS Windows Vista drop down menu:
http://support.acer-euro.com/drivers/notebook/as_9300.html
You need to download and install them both.
Mar 27, 2008 | Acer Aspire 5100 Notebook
Acer orbicam
There are two software entities involved – the camera Drivers and the OrbiCam application itself – and BOTH need replacing/updating to fix this problem.
The new driver and a new version of webcam application (below) seem to fix the issue.
In order to fix the problem, you must download and install them both to make the Orbicam work correctly.
FOLLOW THE INSTRUCTIONS BELOW IN THE SAME ORDER:
1. remove the installed OrbiCam application and reboot if required;
2. install the new driver (preferably with the “driver update” wizard from Device Manager)
3. update the Orbicam application 1.0.0.13
After this, the webcam should function properly, even if the original Orbicam icon disappears.
To check everything is working OK run LiveCa07.exe or BisonM07.exe that are located in the c:\windows\bisonxxx\ folder or simply run Messenger
Feb 19, 2008 | Acer Aspire 5101WLMi Notebook
Accer orbicam problem
do you have ur recovery disc made for the laptop... if u have it use it.... or else visit the laptop manufacturers site and search for the driver.... i got my cam driver from my laptop manufacturers site only....
Jan 31, 2008 | Acer Aspire 5101WLMi Notebook
Ace orbicam
when i try to turn on my acer orbicam it says that because of a problem it stopped working. it is built in.
Jan 29, 2008 | Acer Aspire 5100 Notebook
Orbicam not showing images
did you back up your drivers before installing? If so put backup cd in and reinstall drivers pointing it to the cd for driver files
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 26, 2007 | Acer Aspire 5610-4648 Notebook
Acer oribicam not working
you should be able to get the drivers and application from acer.
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html
select notebook, aspire 5100, and scroll down to acer orbicam
you will need to go into the control panel, system, device manager, and check under imaging for acer orbicam, double click it and it should tell you the manufacturer (bison, logitech, suyin)
grab the appropriate driver and camera applications
remove the installed orbicam application via add/remove programs and reboot if necessary prior to installing the new drivers and application.
if this doesn't fix the issue, please post a follwup and i will see what i can find out.
hope this helps,
trin
Nov 17, 2007 | Acer Aspire 5100-5033 Notebook
Orbicam?
because the cam is built in its not as versatile as a mobile cam, but you can turn the cam over 225 degrees to film from the back of the notebook. If using Vista, open the cam software click the right arrow next to record video button and set your personal settings, click record and then any recording will be saved to my videos. You then can import it into windows movie maker and then add any effects to your movie. if you have XP or XP media centre you can use windows movie maker2 and make your video from within the programme itself using the orbicam, without using the orbicam software.
Sep 30, 2007 | Acer Aspire 5100 Notebook
Acer aspire 5600 travelmate
There are two types of driver for the orbicam, Bison and Logitech, so ensure you have the correct one installed, especially if you are running Vista as it's a different driver again, and it's installed a seperate peice of hardware although it's built into the notebook. There are no listing for 5600 drivers so try 5610 they should be the same http://support.acer-euro.com/drivers/notebook/tm_5610.html
Sep 21, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100-5033 Notebook Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
