Question about Mitsubishi VS-45607 45" Rear Projection Television
I am getting error code 23 on my Mitsu 46607 TV. What is that?
  • 668 Answers
It means you have a Horizontal or vertical deflection problem. A common cause are intermittent solder connections on the yoke plug connectors on the yoke themselves. Best thing to do is to solder them all. Do not attempt this if you have no or limited knowledge of High Voltage circuits of TVs.
Hope this helps,
skyassoc
Posted on Jun 29, 2009
I have a mitsubishi hd 1080 65315 model and the code is 23 what is the problem.
Mitsubishi TV Shutdown Troubleshooting - Stereo & Video ...
www.stereoandvideorepairco.com/.../MitsubishiShutdownTroubleshootin...
For example, the sequence: blink-blink, pause, blink-blink-blink, indicates an error codeof 23. This sequence repeats 5 times, so you can figure out if you are ...
Mitsubishi VS 50705 error code 23 - Service manual, repair and ...
forum.eserviceinfo.com/viewtopic.php?t=81051
Oct 24, 2010 - 10 posts - ‎4 authors Tv is old about 10 years. Shows error code 2-3 horizontal deflection failure. A few years back had a leaking crt, replaced the caps recomended ...
Oct 19, 2015 | Mitsubishi Televison & Video
What does it mean when green power light turns yellow and blinks on and off. tv will not come on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 03, 2014 | Televison & Video
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
AFTER TURNING ON TV ,THE GREEN LIGHT COMES ,SOUND STARTS AND THEN TV TURNS OFF ASAP
after tv shuts off press and hold menu and input buttons on tv at same time for about 8 second. power led will start to blink error code 12 ok 22 dead short 23 deflection failore 24 vertical failore. after you know error code have electronic technition repair for you. J.D.W.
Jun 24, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Have wd62525 mitsu status light flashes tv wont
The status light flashing usually indicates the lamp cover door or the side air vent door are open or the switchs are not working.
Mar 16, 2010 | Televison & Video
Mitsu wt42313 error 22 any ideas?
error 22 "short protect circuit"
Bad convergence IC, also replace 5A picofuse.
Dec 29, 2009 | Mitsubishi WT-42313 42" Rear Projection...
Error code p0421
taken from: http://forums.evolutionm.net/lancer-troubleshooting/349095-code-p0421-call-mitsu-before-you-do-anything.html
Code P0421- Call Mitsu before you do anything!
Icalled my nearest dealership today and for those who dont know, if yourcheck engine light is on and its showing fault code P0421 this may befrom a factory recall on the warm-up converter and a PCM reflash.MILEAGE OF THE CAR DOES NOT EFFECT THIS RECALL. Anyone whos had problemwith a dealership not doing the repairs because of mileage needs tocontact another dealer or the owner of the dealership. This is what theservice manager told me today so though I'd share. Getting mine fixedtomorrow at 10am, I cant wait.
For more information about this code Google "Fault Code P0421" You'll get tons of information Last edited by Swankzer; Jun 2, 2008 at 12:31 PM.
Nov 15, 2009 | 2002 Mitsubishi Lancer
I get a error code 30:23 on my HDR HC3 and it won't play or
Sony is pretty secretive about the :23 code. It can't be found anywhere. Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 120 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
Nov 12, 2009 | Sony Handycam HDR-HC3 HDV Digital...
Getting error code 12 on mitsu wd 62525 dlp tv. any help would be great.
12 means no error detected. What are the symptoms of the set? If its the blinking led thats the DM caps which have failed.
Jun 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsu. VS-50707 problems
12 = No error detected, check power supply.
check all your voltage coming out of the power supply and check the fuses.
Dec 10, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
