Question about Bernina Artista 180
I have not sewn for awhile on my 180e so cleaned it etc. Rethreaded and now my bobbin thread makes this big loopy mess. I have done everything I know so need help. Do I need to take it to be serviced? Also what is the best thread for sewing on the machine?
  • 202 Answers
Loopy mess same as above answer but you also may have put the bobbin in the bobbincase upside down.
Posted on Jul 16, 2009
  • 111 Answers
Loopy mess = upper tension/threading is wrong
Posted on Jul 08, 2009
When embroidering the underside is very loopy. I have changed the bobbin, cleaned bobbin case, checked the top threading and tightened the tension and its still loopy underneath
Not knowing your machine make/model, this is a guess. Be sure to Always Raise the presser foot when threading the top thread. This makes sure the thread is fully seated in the tension disk.
Aug 30, 2017 | Sewing Machines
My brother pe770 is allowing bobbin thread to show on top sporadically which makes the stitching look like it is speckled with white. I have adjusted tension..cleaned and changed everything.
Shelia,
when sewing these parts of the design, (small stitches? ) load your bobbin with the same top thread. Just match the top thread color, and done! No more white bobbin thread in the topside of your designs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Brother PE770 Computerized Sewing Machine
Whta is the answer to the curvy's thread/bobbin problems. super infuriating
If by "bobbin thread is usually too loose." you mean that you are seeing loopy stuff on top of your seam... then first you need to make sure your bobbin is un-spooling in the correct direction.
Also make sure that the tension spring on your bobbin case is not missing it's screw. Don't mess with the tension there yet... loosen your top tension first... sew on scrap fabric of the same type as your project. Loosen the top tension until you stop seeing loops on top of your seam. If you have loosened it enough to see loops on the bottom... tighten it a bit.
If all else fails make sure you re-thread the top thread with the pressure foot up position so you make sure you are getting the top thread in the tension discs and try test sewing again.
Jul 26, 2012 | Singer Curvy 8770 Electronic Sewing...
There is something wrong with the bobbin. When I sew it catches somewhere and bunches thread up underneath
Does this only happen when you begin sewing????? Make sure your upper and lower threads are long enough for you to hold them.......lower your pressure foot and don't release the threads until you have sewn several stitches into the seam. If you don't hold the threads when starting a seam...both threads often get pulled down into the bobbin area and cause a big tangled mess. Hope this helps.
Dec 20, 2010 | Kenmore 756A-30BH Mechanical Sewing...
I have a Bernina 130, the thread from the bobbin is coming out with huge loops, the top thread looks great, but turn over the fabric and you have a mess. Any advice is welcome.
Usually if your bobbin thread is loopy it's because the TOP thread is not threaded right. Try threading it again with the presser foot UP and make sure to get the thread between the upper tension discs. It's just the opposite of what you would think.....if the bobbin thread is loopy, the top thread is threaded wrong, if the top thread is loopy, the bobbin is threaded wrong. Good luck!
Aug 20, 2010 | Bernina Activa 130
The bottom thread is all tangled. I have
Hi! This is the machine I use (mostly) and I've found it really doesn't like lint. I brush out lint every few hours and it has made a huge difference in how my machine sews. I suspect your machine may be as sensitive to lint as my is, so give her a really good cleaning. Then, rethread (yes, I know you've done that already, but do it again, for grins.) everything. Pay careful attention to the way the bobbin thread comes off the bobbin (from left to right) when you rethread. If you usually use the automatic bobbin pickup, don't. Pick up the bobbin thread the regular way, and, holding the top thread and bobbin thread securely in your left hand, start to sew.
I sure hope this helps!
Please let me know if this works, ok?
Robbie
Jan 28, 2010 | Brother CS-8060 Computerized Sewing...
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Jan 23, 2009 | Husqvarna Viking 1
I have a Singer Inspiration 4220 Sewing Machine. I was working on a quilting project last night, and everything was going fine, until I noticed that the thread on the underside of the fabric was very loose...
It's possible that there is foreign debris in the top tension assembly ,thread the machine and lower the presser foot and ensure that there is tension on the top thread
Jul 28, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
229 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
