Question about Epson Stylus CX9400Fax InkJet Photo Printer
When I select 'print', number of copies: one, I get four copies. If I select 'print test page' I get one copy. How do I get just one copy. (that's what selected when the printer pop-up appears)
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Click Print, look at the # of copies. Change as needed.
Posted on Jun 29, 2009
I have a MFC7860DW, How do I set it to collate copies?
You can download the manual from here: Reference page 24: "Collate With the Collate check box selected, one complete copy of your document will be printed and then repeated for the number of copies you selected. If the Collate check box is not selected, then each page will be printed for all the copies selected before the next page of the document is printed."
Mar 02, 2015 | Brother MFC-7860DW Compact Wireless...
My printer prints multiple pages even though number of copies in setting shows 1
Try looking here: open your printers fax folder. Your printer should be listed here, right click on it and select properties. Now click on the advance tab. There should be a printer defaults button, click on it. Make sure your copies number is set to 1. Then click ok on each window and close.
Hope this helps
Feb 13, 2012 | Dell 1320c Laser Printer
How to recover fax in memory
Your fax can print a list of documents stored in memory, along with the transaction number (TX/RX NO.) of each document. Once you know the transaction number of a document in memory, you can print it or delete it.
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select , then press [Start/Copy].
? Printing a Document in Memory
1 Press [Menu].
4 Use [up] or [down] to select the transaction number (TX/RX NO.) of the document you want to print, then press [Start/Copy]. The LCD toggles between and .
If you are unsure of the transaction number (TX/RX NO.), print a list of documents in memory (see page 34).
5 Press [*] to print the first page only, or press [#] to print all pages of the document.
The fax prints the document.
Jan 18, 2011 | Canon FAX-JX200
How do I print several copies of a page on my HP 3015 printer
when you click on print, you should normally get a print window where you can indicate the page to be printer and the number of copies before you proceed with the print job.
Dec 31, 2010 | HP LaserJet 3015 All-In-One Printer
I HAVE A RICOH AFICIO SPC 811 DN HOW CAN I SEE HOW MANY COPIES I HAVE PRINTED THANKS
Hi, you can view the number of pages printed by printing out a configuration page. To do that, press the Menu button, then find the menu labeled List/Test Print and select it. There will be an option for Config Page -- select that and the configuration page will print out. The number of prints you've made (both for black & white and color) will appear toward the top of the page.
Hope that helps!
Oct 18, 2010 | Ricoh 8200DN Laser Printer
Canon Image Runner 7200 prints twice instead of once. When I ask for two copies I get four copies.
If you are using Windows, you will want to check the drivers of the printer to make sure you are not selected on 2 copies.
Go to Control Panel\Printers and faxes
Right click on the printer driver and select "printing preferences".
Make sure the "Copies" is set to 1.
You can also try a wtest page by going to "properties" and select "print test page".
Mar 25, 2010 | Canon imageRUNNER 7200 Copier
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon jx200 fax machine
The fax automatically turns off Auto Print and stores faxes in memory when either ink or paper is low. The memory will store up to 30 transmissions or 60 pages maximum, so it is important not to leave this too long if you have heavy transmission volume.
Faxes can be retrieved as follows.
If you want to choose only certain faxes to print:
1. Print a list of documents in memory for reference:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Doc Memory List, and again press Start/Copy.
2. Print a document from memory (using the list printed in #1):
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print Document, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to print, and press Start/Copy. The LCD will then toggle between "1st page only?" and "Yes=(*) No=(#)". Press * to print only the first page, or # to print all pages.
3. Delete selected document(s) from memory:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Doc, and again press Start/Copy. The LCD will show the first number in memory (e.g., TX/RX NO. 0001).
Use the arrows to choose the document you want to delete, and press Start/Copy. [Note - if the arrows do not result in another number displaying, there is only one document in memory.] The LCD will show "Yes=(*) No=(#)". Press * to delete the document. Continue to select documents until each document you want to delete has been handled.
If you want to print all unprinted documents in memory:
1. If you want to have a list of documents in memory for reference before performing this procedure, to be sure you have them all, follow step 1 from the above procedure for printing selected documents.]
2. Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Print All New RX, and again press Start/Copy.
3. Delete all printed docs from memory:
Immediately after printing all documents, you will have the choice of deleting all documents. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory.
To delete all documents at a later time:
Press Menu. Use arrows (up & down) to select Memory Reference, then press Start/Copy. Use the arrows to select Delete Printed RX, and again press Start/Copy. The LCD will display "Yes=(*) No=(#)". Press * delete all, or # to retain in memory. To finish then, press Stop.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 06, 2008 | Canon FAX-JX200
Printer problem
The error means waste ink absober is full, you must have been doing alot of printing,
Every Canon Pixma has a certain number of pages and/or cleaning cycles it can go through before the waste ink pads are considered to be full.
I have not been able to find the number of pages to fill the waste pad anywhere, it might be in the users manual.
An actual number of pages printed would be more helpful, how many reams of paper have you run through it?
If that machine has a self test page it might include a page count. try the follow steps:
Turn on your MP110.
After that press: Menu - Scan - Copy - Scan.
It will enter in Service Mode.
Here I don't know exactly the procedure but may be something like that for mpc190/200 that follow:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-Scan-Copy-Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Vote for me if this answer is approriate
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Epson Stylus CX9400Fax InkJet Photo Printer Logo
50 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
