Question about Kenmore 24032\24036 Top Load Washer
How do I remove the top of a Kenmore 110-24422300 in order to replace the lid switch assembly?
  • 5,911 Answers
This advice is for just about all Kenmore and Whirlpool model TOP LOADING washing machines. This is an easy repair that anyone with a little know-how and determination can perform.
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
If you have questions,, please let me know. I hope this helps you.
Posted on Jun 28, 2009
How do i change door switch
Replacing the lid switch is not complicated, but you must take care in removing the console.
First slide a putty knife between the console and the top on both the left and right side. What you are trying to do is push a metal clip back so that the console can be lifted from the front and tilted up. This is the part to be careful so that you don't bread the plastic clips in the back.
After you have the console up, disconnect the lid switch harness to the top and there are two metal clips holding the top to the back panel. With a flat-head screw driver remove the clips.
The entire cabinet is ready to be lifted off the chassis. Just lift and pull forward to remove cabinet. You then can replace the lid switch. Just re-assemble in the reverse order.
good luck
Jun 16, 2014 | Kenmore 24032\24036 Top Load Washer
Trying to take off the back and top control panel of my Kenmore Elite top load washing machine so I can replace the lid switch and timer, any help would be appreciated.
It is rare that a lid switch and timer both need replacing.
The 2 ends caps on the control panel will snap off.
Once they are removed,take out the 2 screws on the right and left front sides of the control panel that holds the panel to the top.
Fold the control panel to the rear of the machine.
Unplug the lid switch wire.
Remove the 2 S clips holding the rear panel to the cabinet.
Pull the cabinet forward to remove it.
The lid switch is then accessible inside the cabinet.
Reverse this procedure to re-assemble.
Jul 17, 2011 | Kenmore Washing Machines
Kenmore 22432 top load washer - how do i remove top to replace the lid switch
what are the 3 numerical digits before the period as in ( XXX.XXXXXXXX) the first 3 numbers tell you who produced it for kenmore,then i can tell you how its dis-assembled to replaced the lid switch
Mar 05, 2011 | Kenmore 24042 Top Load Washer
Broken lid switch on washer
you must take the cabinet off by removeing the screws from the consloe and flip it back and remove the 2 clamp,s and remove the cabinet and replace lid switch
May 02, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore washer 80 series model 110.23832100 won't spin. I think that is the switch lid. How can i replace it
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23832100
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is an illustrated guide for how to access the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=5f1af8349a77f9dc5632b02160e0d6c6
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If the washer will drain but not spin the problem points to the Neutral Drain Assembly in the transmission.
The Whirlpool PDF has a very good explanation of how the assembly works.
Ours had the same problem, no draining or spinning unless the washer was stopped and restarted.
We replaced the neutral Drain Assembly for about $15 vs. $170 for a transmission.
If the Lid Switch is OK, please re-post a request for how to replace the neutral assembly.
Nov 19, 2009 | Kenmore 24032\24036 Top Load Washer
I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Oct 02, 2008 | Washing Machines
Kenmore lid switch
The following link explains how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
Now, unless someone has modified the original lid switch, there is NO soldering required. The defective switch just has a couple of mounting screws holding it in place, along with a ground wire attached to the casing. The entire assembly unplugs from the timer and comes out.
As far as a replacement is concerned, you can order them on line at searspartsdirect.com. Just type in your complete model number (located around the wash tub opening) and the lid switch is usually listed under the "Top and Cabinet" heading. If your lid switch is activated by a lid strike, which is mounted on the washer lid, make sure it is also intact and not broken. The strike is also listed under the same heading. If you do not wish to wait on shipment, take the part numbers listed on the Sears website and go to your nearest appliance parts retailer. These are standard parts that can commonly be found there.
I hope you find this information helpful. Let me know if you require additional assistance.
Sep 28, 2008 | Kenmore 24032\24036 Top Load Washer
Replace a lid switch
To access the lid switch:
1.Remove the trim on either side by prying off from the top. Grasp the trim at the top and pull forward to expose to expose a screw.
2. You will find a lid switch connector (white in color). Unplug the switch from the connector.
3. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
4. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
If you need further assistance, let me know
Regards,
reg501
The FixYa Team
Jun 24, 2008 | Kenmore 22422 Top Load Washer
Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Jun 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
777 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
