Question about Freezers
Older model, motor funs, but does not cool the chest
How can I find out how old freezer is? Bought used from a friend who has used it for years. Now the motor runs, but it does not freeze. It was laid on its back for moving. Is this worth calling the repairman ($65 to walk in the door--ok, but want an idea what might be wrong.)
  • auntreta Jun 28, 2009
    thanks for the reply, renaldo. I have already looked for any information on the model/mfg date/serial date plate on the back of unit--nothing helpful. Also, there is no listing of freon type. So, probably this means the unit is pretty old and that was not required then. As for what is running, can't tell. I ran the freezer for 24 hours when I first got it and it did not run continuously. It would shut off after awhile. I think it is probably not worth getting fixed if it is over 20 years old. Your comment? (I definitely will accept your solution so you will get paid.)
  • 1,056 Answers
Well one way to find out is to look on the back. It shows all the info including what kind of freon to use. Usually the manufacturing date is on there. If not see if it uses 134 for refrigerant. This would at least indicate it is not really old. 134 was introduced in the late 90s. replacing R12. If you meant the compressor run but do not freeze, unplug it because the compressor can be damaged if it run without refrigerant for long period of time. If you meant the fan in the freezer was running, the compressor might not be running at all thats why it is not getting cold. This could be caused by the breaker switch on it not resetting anymore. It may have a leak it too, and all the refrigerant has leaked out. If it operates on 134, you can buy a line tap, 134 adapter availabe in auto parts store or walmart. Buy you some freon in the can. A propane torch, solder, and some flux. If you have a friend who is handy, or a mechanic. They can do it for you much cheaper. One does not need refrigeration license to work on refrigerators. Only the know how. I can give them instructions. Last note. a fridge usually take 1/2 to 3/4 can of 134.
Posted on Jun 28, 2009
My whirlpool chest freezer not freezing at all
it not freezing because it cooling system must be damaged,you bought another cooling machine it has mini size and it fixed at the point of older cooling placce.
Mar 22, 2013 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
Kenmore 6.9 cu. ft. chest freezer stopped working
It looks like a bad ignition switch or capacitor. This is not that expensive. Probably not the compressor. Unfortunately, one small part stops the whole show.have a friend who is a tech look at it.
Jan 24, 2013 | Freezers
My Magic Chef chest freezer stopped cooling, slowly, over two weeks. I emptied, unplugged, defrosted, cleaned coils, and powered up again. Red light is on, won't cool. Guessing freon or compressor...
Sounds like slow Freon leak. You might get an estimate over the phone before calling a technician, but I would think a 3-year old box is worth repairing. If the estimate is close to the replacement cost, that might not be the case.
Feb 25, 2018 | Magic Chef Chest Freezer MCCF5WBX
Fridge does not cool down
dear sir,
if your freezer,s compressor is running the i think its low gas problem please contect to your service technician for refilling refrigarant .
hope answer the question
thank you
please vote!
Jul 01, 2010 | Engel MT45FU1 Chest Freezer
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Just bought a used GE chest freezer model FH5DSAWH from friends. Brought it home plugged it in and it doesn't get cold. Can hear it running and the compressor gets hot. Any ideas? Was told it worked great....
your ptc overload relay on the compressor is bad,unplug it off the compressor and get a replacement at an appliance parts store,plug in the replacement and this will solve your problem
Apr 27, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Kenmore chest freezer wont cool
Hi.
Here is a tip that will help you...
There are also more tips at the bottom of this one...
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
heatman101
Feb 26, 2010 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Frigidaire uprite freezer won't cool
it's scrap
they use steel lines inside the cabinet and when you unplugged it the lines rusted through
Jul 30, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Chest Freezer not cooling
Please don't rate this solution, as anything but FixYa brings my rating down, but here's what you've got:
You have a refrigerant leak (commonly referred to a Freon, but these days usually R134A refrigerant). Some refrigerant has leaked, so you are still getting some cooling, but there is not enough refrigerant left to cool throughout the entire evaporator coils. This is NOT a repairable condition, as the coils are foamed in place and not accessable for leak repair. If this unit is under 5 years old (typical sealed system warranty) the manufacturer will most likely replace your freezer with a new one. If over 5 years, you are out of luck. Buy a replacement freezer.
Oct 12, 2008 | Whirlpool 10 cu. ft. / 283 liter Chest...
Freezers Logo
113 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
