Question about Toro Lawn Mower With Toro Power Tools
Toro 13-38xl no brakes,I have adjusted. Is it some kind of small brake pad? What part do I need? Model 71185 Serial6903314
3 Suggested Answers
  • 6 Answers
SOURCE: TORO Wheel Horse Lubrication
this is like a snapper drive it has a rubber plug that you pull out and fill with 0 grease lube meaning 0 is the weight of the grease that comes in a tube. you can get it at any little small engine repair or automotive shop.
Posted on Jun 13, 2009
  • 85 Answers
SOURCE: BROKEN BRAKE PAD UNDER FLYWHEEL ON TORO LAWN MOWER
If you had replaced the flywheel key & did not engage the saftey bail it would brake the brake. Make sure the bail is engaged befor installing the flywheel.
Posted on Sep 24, 2009
Toro Lawn Tractor Won't Start - Wheel Horse 13-38 XL 71185
well if it turns over with solinoind jumped out and not with the key id say yes your on the right track as it's something in the safe to start circuit could those wires you found posibly be near the seat maybe if so I'll bet they fit in a seat switch that may have got unhooked for something
Nov 12, 2013 | Toro Garden
I have a Toro 16hp 38 in hxl with the parking brake stuck, is there a trick to this i dont know.
The snapping sound by the starter is either a bad cable connection or a bad starter. Check the cable at the starter to make sure it is tight and not corroded. If that is ok then test the starter. As for the parking brake, most mowers have a small disk with two brake pads like a disk brake on a car that is controlled by the brake/clutch pedal. Release the brake and check to see if the mechanism on the transmission is releasing. If it isn't it may need an adjustment
Jan 18, 2013 | Toro Garden
Front brakes aren't releasing properly. How can I fix this problem? Is it a matter of bleeding the brakes?
Lets start with some simple things since you just put on new pads, I assume the brakes worked properly prior.
First, what kind of pads to you install? Some abrasive pads will make a grinding noise till they wear in. You can help this by filing a small beveled edge all the way around the pad surface.
Second, did you adjust the brake fluid level in the master cylinder after installing the new pads? After pushing the caliper piston in to install the new pads there may be too much fluid in the resevoir now causing a constant pressure in the lines. Place a towel around the master cylinder and remove the top. If fluid runs over the top you may have found your problem. Use a baster or syringe to **** out any excess fluid.
Oct 22, 2012 | 2011 Suzuki Boulevard M109R
How can i compress the caliper piston back of audi a6 2000 2.8l awd what kind of tools i need . Vise grip is not working.
For front brake pads replacement you need only usually wrench set, inclusive 7 mm allen key also.
But for rear brake pads replacement you need obligatory a special caliper piston pressing tool, in order to press back rear caliper piston with parking brake automatic adjustment!!!
For front brake pads. You should buy the brake pads (with wear sensor). For change front brake pads you must raise vehicle, remove wheels, extract the retaining spring of the caliper, and remove the caliper as follow:
1. Do not disconnect the brake hose from the caliper, and do not allow the caliper to hang by the brake hose!
2. Remove top and bottom caps (on back side of the caliper) for access to guide pins, then unbolt and remove them from the brake carrier. Remove the caliper.
3. Now you must thoroughly clean the brake calipers (free of grease).
4. Remove outer brake pad from brake carrier.
5. Pull inner brake pad out of brake caliper piston.
6. Check up the brake fluid level on the reservor, and emptying if neccessary!
7. Push piston back into brake caliper housing.
8. Install inner brake pad (with expanding spring) in brake caliper piston. (Arrow marked on pad - if exist, must point in direction of brake disc rotation when vehicle is moving forward).
9. Install outer brake pad into brake carrier.
10. Bolt brake caliper housing to brake carrier using two guide pins. Tightening torque is 25 Nm.
11. Install both caps.
12. Insert retaining spring into brake caliper housing. Important: Depress the brake pedal firmly several times while the car is stationary so that the brake pads adjust to their normal operating positions!!!
Check brake fluid level and top up if neccessary!!!
Oct 26, 2011 | 2000 Audi A6
Brakes need to be tighten
The wound steel cable that connects your brake lever to the brake pads can be adjusted via a screw or nut at the top of the brake pad assembly. Simply loosen the assembly and gently tug the wire end toward the front of the bike tire to tighten brake grip; tug it backward to loosen. Tighten the screw partially to hold the cable in place, test the brakes with the brake lever, and adjust again if necessary before fully tightening. It may help to put the bike on a stand or hold it so that you can spin the wheel, check that the brakes are adjusted so that the pads do not rub the wheel. You can do the same thing with the rear brakes. You will need a small tool to loosen and tighten the brake pad assembly; your household toolbox should have something :)
While you are adjusting the brake tension you should also check the brake pads for signs of wear. If your bicycle brakes squeal, show uneven wear or are perfectly smooth, go to a shop and get a new set! Regular brake maintenance is very important for bike safety.
May 19, 2011 | Cycling
Looking for a diagram of a belt configuration on a toro model 71185 lawn tractor
this link will help you http://www.manualsonline.com/https://www.shoptoro.com/Comergent/en/US/adirect/Toro?cmd=ToroOnlineModelLookup
May 13, 2011 | Toro Garden
I replaced my rear brakes. Does the emergency brake automatically adjust itself?
Yes.....and no. Emergency brake should have been checked during brake pad replacement.
Most do adjust to new pads...ie: return to factory adjustment setting due to new pads .
The E brake lever should be applying braking to the wheels after three clicks are heard during application of the Emergency brake.
Lift rear of car and apply emergency brake to the third click. Now both rear wheels should drag equally but not be locked up.
If not, adjustment required.
However, late model cars need a scanner to pull back the pistons and install pads.
Jan 12, 2011 | Toyota Corolla Cars & Trucks
How do i change brake pads on a 2003 dodge
You have air in the brake system and you will have to bleed the brakes.This will take time but if you keep your eye on the fluid level and then open the bleeder screw on one caliper at a time and let about 1 to 2 cups of fluid come out of each side you should get the air out of the system to regain your brakes.
Feb 18, 2010 | 2003 Dodge Stratus
BROKEN BRAKE PAD UNDER FLYWHEEL ON TORO LAWN MOWER THE ENGINE IS A TECUMSEH MODEL lev120 SPEC 361541b 195cc
Sep 23, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
135 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
