Question about Intel Motherboard
Connecting wires to a pc motherboard
My son pulled the power source wires from the motherboard where and how can I reconnect them?
    President:
  • 942 Answers
You just install the power supply in your CPU casing after that, you just choke the 24pin power in you motherboard no other slot that can fix it, after that, just put power in the Hard disk, then choke also the 4pins, the yellow and black color, it is done
Posted on Jun 29, 2009
Hummingbird 898 gps receiver wire repair...
yes you can. However you must see if the power cables is o.k and everything is good.try again.
God bless you
Jul 13, 2013 | GPS
Dell dimension e510 flashing amber light USB front panel
If you are comfortable around computers, you could try the following to test the power supply. Unplug the cord from the power supply, hold the power button in for about 15/20 seconds, open the case, unplug the 24-pin power connector from the motherboard and jump the Green wire to one of the Black wires, reconnect the power cord and power the system on and if power supply fan and hard drive run, then the PSU should be good. Note: Do not remove any wires from the plug, use a small piece of wire or a paper clip as a jumper. Power supply checks out and the system still does not work, again remove the power cord, hold power button in for several seconds to discharge the residue power, reconnect the 24-pin connector to the motherboard. Remove all the PCI cards, the video card [if applicable], memory, all peripherals, disconnect the data and power cables to all the drives, check that the front panel cable is connected to motherboard, with nothing else connected to the system, reconnect the power cable and power the system on. If you do not get any beep codes or diagnostic lights on the front panel, then it would appear that motherboard has died.
Aug 07, 2012 | Computers & Internet
My computer randomly will not power on. It doesnt work more than it does work. It will power on but will not fully boot up, monitor screen is blank and mouse does not power on. Light on front of tower...
Open the cpu cabinet cover then clean motherboard and parts. Reconnect RAM memory.Pull cmos cell from motherboard for 10 minutes then put it back reconnect both connection to harddrive.Make sure motherboard is not ground with cabinet cover. Reconnect pci card if any. Let me know if you need further assistance. Thanks for using FixYa.
Sep 01, 2011 | Gateway DX4200-UB001A Desktop Computer
Wires disconnected from power supply need wiring order
Theres no specific order for power supply wires. Just make sure it is disconnected from a power source and connect the Motherboard and optical drive cables to their respective plugs(plugs are standard for most motherboards).
Feb 27, 2011 | eMachines T3604 PC Desktop
My computer will not turn on at all after changing out my fan. I made sure everything was connected and when I rey to turn it on, I get nothing.
Okay, let's review, and let me ask some questions.
A) Did you follow Anti-Static Precautions? Used an ESD wrist strap, and connected the alligator clip to a good ground source?
B) Did you reconnect the Power Button Board?
C) Fan/Heatsink Assembly;
1) Did you reconnect the fan cable to the motherboard?
2) Did you scrape the top of the Processor clean, and the bottom of the heatsink plate on the cooling tube, and apply fresh, new thermal paste properly?
3) Did you tighten the heatsink plate screws in a criss-cross fashion, and did not over-tighten?
D) Did youi reconnect the RTC battery cable back to the motherboard? (RTC = Real Time Clock.
RTC Battery, another name for CMOS battery) You did disconnect the RTC battery, correct?
E) Reconnected the Power Connector Cable?
We'll start from here.
(Do you have the CQ50 series Notebook PC's Service Manual?)
Nov 21, 2010 | HP Compaq Presario CQ50-140US NoteBook
Pulled off front cover. three sets of wires came off. need to know where to reconnect. white/red wire HDD LED, white/green wire POWER LED, white/black wire POWER SW
Hi. You may want to check your motherboard for this wires to connect to, First, check your motherboards manual and look where the FRONT PANEL is located, then on the front panel or in the manual itself it will tell you where are those wires should be connected to. If you dont have the manual for your motherboard search it on google and do the same, and if still you coudnt find it over the internet then just look closely on your motherboard and look for the words HDD LED, POWER LED and POWER SW, usually those words or the FRONT PANEL is located on the left side bottom part of your motherboard. Hope This Helps
Jun 09, 2010 | E-Machines T3302 PC Desktop
Reset/power/led etc..lead connections
on most motherboard it is possible to read there to set the wires.
hope this helped a little.
May 15, 2008 | Compaq Presario 5000 PC Desktop
Mouse will not respond at all. Have completely disconnected and then reconnected. Tried reboot. Tried hard shut down from power source. Let sit for over an hour. WILL not respond. Is it dead?
connect your mouse to another computer and if the mouse works the problem is with the motherboard take the motherboard to te chip level technition the packet resistance and capacitor is open need to replace them
May 05, 2008 | Computers & Internet
hi bob i need to know the motherboard's serial number then shouldn't be a problem finding the service manual for it with all the information you require some motherboards got that information imprinted near the pins if you look close enough
Aug 05, 2007 | EliteGroup P4M800PRO-M Motherboard
Intel Motherboard Logo
52 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
