Question about Refrigerators
Magic Chef CTF1920AR Leaking Oil
Just had the compressor replaced in a ''fix-it'' shop - it worked for a couple weeks with no problems. Now, there is a black oil leaking - not sure where it's originating but it's accumulating on the floor next to the right side of the door. I have a feeling the compressor is going out already (probably scabbed from some other fridge that was old - argh!!!).
HVACRH20
  • 237 Answers
SOURCE: Fridge Leaking water from front right hand corner
Most likely you're correct, the defrost cycle produces water that is supposed to be captured in a holding tray, pan, etc. If the pan is cracked it would leak out or if the drip tube (pipe) is not in place it would miss the pan. It may be easier to remove the contents of the small frige and tip it over some to see what you can down there. I assume this small unit doesn't have any water souce to it (no ice maker or water). Check the tubing for damage and see if you can find the holding pan to inspect for crackes, etc.
Posted on Nov 10, 2006
HVACRH20
  • 237 Answers
SOURCE: Fridge leaking oil on the bottom right side
OK, usually if you see an oily substance that you are sure is not from the fridge contents it's oil from the sealed system. When a leak in the sealed system happens the refrigerant gas leaks out and the lubricating oil also leaks out. I'm afraid you may be in this situation. As the refrigerant leaks out the cooling efficientcy drops off quickly and eventually there is no cooling at all. You would have to use a refrigerant leak detector "sniffer" to locate the leak and then have a certified company repair the unit. Sadly, the cost to do a compressor replacement and leak repair is 2/3's or more the cost of a new fridge...
Posted on Jan 15, 2007
SOURCE: SIDE BY SIDE MAGIC CHEF REFRIG
your drain line is frozen. you nee to put hot water down it
Posted on Mar 13, 2008
SOURCE: Kneading Blade for Magic Chef CBM 250-2
Go to e bay. They have a couple of stores that sell nothing but parts for bread machines.
Posted on Jul 03, 2008
I found a compatible belt!!! It's a Dayco # 15260, which you can order from partstore.com!!
Posted on Nov 25, 2008
Magic Chef Fridge & freezer not cold-both fans running-Compressor hot- cleaned drain tube-outside of fridg cold
Is compressor running continuously or is it clicking on and off every couple minutes? Is there any frost buildup on inside back wall of freezer?
Sep 26, 2017 | Magic Chef Refrigerators
We have a Magic Chef MCWC52B
The light may be old, and need repairing, I would try contacting somebody local rather than buying a new one.
Nov 30, 2007 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic Chef refrigerator Model # MCBR360S stopped working. Any help would be great.
Compressor Overload and relay may be bad. Those are the parts that plug into side of compressor. If not that, then most likely compressor is bad.
Sep 03, 2017 | Magic Chef Refrigerators
Stops periodically
possible compressor or fan overheating and shutting off
Dec 08, 2017 | Magic Chef MCBR445S1 Stainless Steel...
I was out of power for a couple hours, everything turned on again but my magic chef refrigerator is not working properly
If your compressor is coming on, then check the main board. If it isn't coming on then it is probably either the start relay or start capacitor which are located at the input of the compressor. If they have power and are good then check the PCB board.
Jan 18, 2012 | Magic Chef Refrigerators
My 3.6 cuft Magic Chef frig quit over a weekend. When I plug it in, the compressor is not running and is getting very warm. Is there any quick/inexpensive fix?
there's a small compressor starter that can be replaced. i had similar problem and it seemed to work. the bad starter could be a result of an underlying compressor problem though. for $40 i took a chance and all seems fine so far. the starter simply plugs in and is found under the electrical cover on the compressor. my pt# was P6R8MC, and the starter was black in color. be sure your unplugged first.
Nov 04, 2010 | Magic Chef MCBR440 Compact Refrigerator
How can I download a electrical diagram for a
I believe this what you were asking for=> APPLIANCE REPAIR PARTS GLOBAL click on diagram to enlarge, If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze Sea Breeze
Feb 02, 2010 | Refrigerators
The magic chef wine cooler was clicking now will not get cool .
its your ptc relay.its a very simple fix.to the left of the compressor is a plastic cover with 1 screw.take it off.youll see a small box on top with 1 wire going to it.wiggle it off.pulls straight out left of compressor.go to repairclinic.com..type in part #1206838.its about a $27.00 fix. mines been running fine since.hope this helps
Jan 17, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Jun 29, 2009 | Magic Chef MCWC16MCG Wine Cooler
Magic chef fridge RB193A
Which fan is working or are all fans working, condenser clean, hear compressor running ? Let me know.
Apr 22, 2009 | Magic Chef Refrigerators
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
