Question about Watches
Phillipe stark PH-1056 instructions
I have lost the instruction manual for my phillipe starck PH-1056 watch and i dont know whether i am able to get an alarm for my watch, can you help me experts?
bestdarngood
  • 3037 Answers
SOURCE: philippe starck with fossil ph-2006
Fossil Contact Information Main support number 1-800-842-8621
Email support webguy@fossil.com
hope this helps
Posted on Mar 25, 2008
SOURCE: How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
Posted on Aug 09, 2008
  • 4 Answers
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
Posted on Dec 02, 2008
escapement
  • 2334 Answers
SOURCE: Can't set the time or adjust the ******** crystal Starck PH-1100
Take a VERY close look at yor watch and you should notice a few tiny buttons. One of them should correspond to MODE, another to SET and so on- depends on how many your watch has.
Use a pin or a needle to push them and find out the settings procedure.
If you cant find buttons on the case sides, examine case back. They can be hidden between the lugs, so, the strap should be taken off.
Remember- there are no watches in existance without adjustment features. Even atomic clock needs to be adjusted after a few million years of work:))
Good luck.
Arthur
Posted on Dec 17, 2008
SOURCE: how to change the greeting
press the mode button twice. that will change to date mode. during the date mode display ,hold set for 5 seconds. mission accomplished!
Posted on Dec 30, 2010
I need a manual for a philippe starck ph 1065 watch.
You can get instructions for your watch from the Fossil web site.
Go to "fossil.com", go to the bottom of the page and you will see a
menu, click on "customer care", and then look under "Product Info" on
the left and you will see "watch instructions"
Click on this and a list of diagrams and watch descriptions will appear. Put
your cursor over any of the descriptions and a diagram of the watch face will
appear. Search the list until yours appears and download.
May 16, 2011 | Fossil Philippe Starck PH1035 Wrist Watch
Philippe starck with fossil ph-2006
hope this helps
Mar 25, 2008 | Fossil Philippe Starck PH1026 Wrist Watch
How to adjust band on starck ph5031
the left and you will see "watch instructions". Click in this and then scroll down until you see Stark watch instructions.
There are two sets of band instructions, hopefully one of them is is relevant to your watch.
Apr 20, 2011 | Fossil Watches
Instructions for Starck digital ph1028 watch
Fossil make Stark watches but they do not give instructions under model numbers but give a set of generic list which leaves you to choose the one that looks like yous.
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html and choose the one that matches your model.
Jan 08, 2011 | Watches
My chronograph men's watch came without a manual. Where do I find a manual that discusses setting time, cleaning the watch, setting teh date, etc?
Philleo Stark are made by Fossil.<br /> <br /> Go to <a href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</a> and you will see "watch instructions", ckick on this for download of the instructions. They are generic instructions, so you need to scroll down to find the one that looks like yours and download the file.
Aug 26, 2010 | Fossil Philippe Starck PH1035 Wrist Watch
No Manual. How do I set the time and other functions?
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html and you will find a list of generic instructions in which you should be able to find a set that suit your watch.
May 04, 2010 | Fossil Philippe Starck PH1035 Wrist Watch
How do I set the time?
You can get instructions by copying "http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html" into your search engine and scrolling down the page to find Stark watches.
Choose the one that matches your watch and download.
Mar 19, 2010 | Fossil Philippe Starck PH1035 Wrist Watch
I cant set the time, I would like to set the correct time, know how to set the alarm and be able to view the day date and time, I think it can show all of that....It was working and now, nothing :(
Perhaps you have operated a number of options that have confused the poor thing! I suggest that you obtain a copy of the user instructions and to do this you should go to the Fossil web site (fossil.com) and enter "Phillipe Stark" in the search box.
Got to the bottom of the screen and there is a menu of alternatives; choose "customer care".
The next page has a menu on the left, choose "watch instructions"
Select the illustration that matches your watch and choose the instructions by the model number.
If you cannot get the watch to operate satisfactorily even when you have followed the instructions, then you can only contact the manufacturer and aask for help.
Jan 13, 2010 | Fossil Philippe Starck PH1034 Wrist Watch
Aug 08, 2008 | Fossil Philippe Starck PH1035 Wrist Watch
Watches Logo
70 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
