Question about Toro Electric Trimmer
Line spool won't come off Toro Model 1100
I can't get the spool off. There is a tab on each side of the spool and I think you're supposed to push them in, but I tried that and it won't come off.
5 Suggested Answers
radar001
  • 1051 Answers
SOURCE: How do you remove the line spool cap on a toro
There are 2 tabs, 1 on each side of the cap. You need to press these in at the same time to pull the cap off.
Posted on Apr 06, 2010
radar001
  • 1051 Answers
SOURCE: refill line on spool of toro electric model 910
Onve you remove the cover the spool should pull straight out. Be careful, there's a spring under the spool that can fly out and get lost. You need that spring to re-assemble.
Posted on Apr 12, 2010
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
Posted on Mar 30, 2011
Toro tb65ss upper string head removal
  1. Pull the spark plug wire from the top of the spark plug. Bend the wire to the side to prevent accidental starting.
  2. Place trimmer on its side with the trimmer spool head facing you. Press the two tabs on the side of the spool head with your fingers.
  1. Hold side of the head and slowly allow the head cover to push away from the inside of the spool head. There is a spring between the spool head housing and the spool that pushes out when releasing the cover.
  1. Pll the knob and spool out of the spool head. The spring should come out on the back of the spool.
    Electric Trimmer
  1. 1 --> Unplug the Toro trimmer power cord from the electrical outlet.
  2. 2 --> Lay the trimmer on its side. Hold the spool housing tight in one hand and twist the cap counterclockwise with your fingers. If necessary, use a pair of large slip joint pliers to start turning the cap. The cap is the center piece of the spool.
  3. 3 --> Pull the cap off the spool and remove the spool from the housing.
Apr 26, 2014 | Garden
I have an 1100 TORO Weedeater with the "push tabs" to remove the spool. Thru use/mis-use, the "tabs" are all the way in and the spool will not release. There is still line on the reel...
All I know to help you would be parts replacement as plastic parts are wear items and have to be replaced. Here is a parts w/diagrams breakdown of the 1981 model year Toro 1100 trimmer. I hope this can be of help. You can order parts here to replace your "worn out" string head and spool.
http://www.partstree.com/parts/?lc=toro_consumer&mn=51300%2C+1100+Electric+Trimmer%2C+1981+%28SN+1000001-1999999%29
May 12, 2011 | Toro Electric Trimmer
I have 11" Toro Trimmer and cannot turn spool counterclockwise to replace line. I am a woman and do not know what to do. Used strap wrench large open end wrench and cannot budge this spool.trimmer is less...
With most trimmers, you may have to push the spool casing inward and then turn. It should unlock fairly easy. You may also want to spray the divider crease on the spool casing with some kind of lubricant like WD-40 or Tri-Flow to facilitate the process of detaching the spool casing from the body. Good luck. I hope this helps.
Jun 29, 2010 | Toro Electric Trimmer
How to replace pull cord
You didn't give a specific model, but on most briggs & stratton engines (which most toro mowers use) the recoil starter is in an assembly which is spot welded onto a metal cover. You may have to first remove a plastic shroud (which might include the gas tank - which should have a shut-off valve). Then you should be able to remove the metal cover that includes the recoil starter. When you get that off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
Jun 01, 2010 | Toro Lawn Mower With Toro Power Tools
Refill line on spool of toro electric model 910
Apr 11, 2010 | Toro& Electric String Trimmer
How do you remove the line spool cap on a toro electric trimmer?
Apr 06, 2010 | Toro Electric Trimmer
Do not know how to correctly string so string will come out as it is supposed to on my poulan pro weedeater, do not have directions
There are five ways to change trimmer line depending upon the style of trimmer head on your unit.
The first style has a locking tab on the side of the trimmer head that must be depressed while the lock ring is turned counter-clockwise. This will remove the cover and give access to the spool which can then be pulled out, rewound with the line (winding in the direction of the arrows on the spool), and re-installed.
The second style requires lining up the marks on the bottom of the spool tap/button assembly and firmly pulling straight out on the tap button. This pulls the spool assembly out so it can be re-wound and inserted back into the hub assembly.
The third style requires pushing in and down on the two locking tabs on the side of the trimmer head. This will remove the cover and give you access to the spool.
The fourth style of trimmer head is the Centrex. Remove the cap on the bottom of the head by unscrewing it. Remove the guide ring and remove the spool from the unit. Cut a 25ft length of line and insert one end into the center cavity of the empty spool. Feed the line into the spool, leaving 4-6 inches unwound from the center of the spool. Reinstall the spool, guide and cap, making sure the notch in the guide is facing away from the spool and the line is in the notch.
The fifth style is the fixed line cutting head. This style cutting head uses a pre-cut piece of cutting line. After removing the worn line from the cutting head, insert the precut piece into the positioning tunnel leaving an equal amount out each side of the tunnel. The ends of the line can then be inserted through the exit tunnels.
Oct 25, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
It has come apart and I would like to refill the line on my toro heavy duty electric trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 23, 2009 | Toro Garden
Jun 03, 2009 | Toro Electric Trimmer
May 26, 2009 | Toro Electric Trimmer
Toro Electric Trimmer Logo
126 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
