Hi there I have a Panosonic TH42PWD6 that is five years old. Over night an error has occured. No problems until today. Now, when you switch it on it goes green for four seconds then the screen flashes about a third of the screen with vertical stripes then it switches off again and then a red light flashes in a flash - flash - hold, flash - flash - hold pattern ie. two flashes and then holds. Any ideas Thanks Matthew
  • 1 more comment
  • mrmarvel1 Jun 28, 2009
    Hi there
    I am new to this and not sure how it works! Did you get my last answer re resetting it?
    thanks
    Matthew
    Is there anyone out there that can help me. I'm not sure how long it takes to get a response
    Thanks
    MAtthew
    Hi there
    I need an answer to my original question.
  • 508 Answers
    Brigadier General:
  • 8,619 Answers
Hi
Please follow the following procedure to enter the service menu and reset the TV --
Important !
After you get to the item that needs adjusting. Write down the original setting just in case you have to go back.
1. While TV is turned on.
2. Select 'Setup' icon.
3. Select 'Cable' mode.
4. Select 'Timer' icon and set 'Sleep timer' for 30 minutes.
5. Press 'Action' twice to exit menus.
6. Tune to Channel '124'.
7. Adjust 'Volume' to zero (0).
8. Press 'Volume down' On TV a red CHK appears in upper corner.
You are now in the Adjustment mode. You will be presented with a category choices--
B Picture
C Cut off
D Deflection
P PIP
S Options
X Comb Filter
9. Use the 'Power' on the Remote to select which category.
10. Use the 'Channel up or down' to select the item.
11. Write down the old value of the item before changing.
12. Use the 'Volume up or down' to change the data.
13. When you have made all the adjustments you want press 'Power' and 'Action' On TV for 3
seconds.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 28, 2009
    Sergeant:
  • 326 Answers
Have u tryed resetting it
  • SABARI ANAND
    SABARI ANAND Jun 28, 2009
    cspac.net/Equipment/TH42PWD6UY.pdf
Win will FNAF 3 come out
When will "Five Nights At Freddy's 3" be released, there's been lots of speculation on the matter. Some people believe that the "only one left" phrase may mean that "Five Nights At Freddy's 3" is potentially due one year from when the statement was originally posted. This suggests that "Five Nights At Freddy's 3" might release on Dec. 6 of 2015. That being said, Scott doesn't have a solid history of holding to release plans. All indications previously said "Five Nights At Freddy's 2" wouldn't arrive until 2015. As fans all know, it's been available since long before then. In this case, more vague release windows might actually be more accurate. If gamers consider that a little more than three months separated the release of "Five Nights At Freddy's'" and "Five Nights At Freddy's 2," there's decent reason to believe "Five Nights At Freddy's 3" would take about the same time to develop. Most fans agree that an early 2015 arrival is likely, possibly by February or March.
Jan 23, 2015 | Computers & Internet
A bypass to well no longer occurs,; instead the bucket keeps filling up...also can't pull the filter out for cleaning purposes... In addition are we defeat ing the purpose of the dehumidifier by placi
well if the unit has never been taken apart and cleaned well inside, and it's five years in service , Id say thats your problem, anything thats got room air blowing thru it for five years ,It's gonna need to be tottaly cleaned in all areas
Dec 23, 2014 | Danby DDR6009REE 60 Pints Energy Star...
Why does the video dissapear 2 seconds after power up on my Westinghouse 32in w/dvd?
It sounds more like a backlight tube or inverter board. Five years is about the maximum lifespan of these devices. That's the reason why new set are LED backlit instead of fluorescent.
Sep 05, 2014 | Westinghouse Televison & Video
Hi, I have a Samsung WDJ1255C Washer Dryer. I recently moved and had the machine unplugged for about a week. I turned it back on today and it's giving me an E13 error message. Can you please help?! Ghana...
unplug for 5 minutes or switch off the breaker switch for five minutes. if the five minute reset doesn't restore the machine your MCB could be stuffed
Nov 11, 2013 | Washing Machines
Lg front loader wd-8050fh door wont lock
Hi just read your posting.Sounds like the door lock switch is faulty.Do you get any error codes on the display?Check the door latch that is attached to the door.It is the little hook that latches into the door lock switch.The tension on the hook should be quite firm.Please reply with answers to the question and the condition of the door latch.Looking forward to your reply.
Jul 14, 2012 | LG Washing Machines
I bought a 2005 Ford Five Hundred last May.... I had no problem until when it started getting really cold and it started snowing. It wont start everytime I get in my car when its really cold or snowing ...
Since you bought it, what has been done in the way of
preventative maintenance
I would have layed it up for two weeks, and gone through the
entire vehicle,changing all fluids,spark plugs,checked fuel
pressure and on and on.
You probably bought a vehicle that is 5 or more years old,
that other than,oil changes, is the same as when it came off the
train and car hauler, on the way to a dealer
That won't work on todays high tech vehicles
Snow and cold, has little to do with todays electronic wonders
You do realize, your asking a question, when as I said, we have no vehicle
history
I don't think you understand the technology,not anyone can work on todays
vehicles. You need a 2 or 4 year college degree, if your just starting out
I will help you when you give me something technical to work with
Dec 01, 2010 | 2005 Ford Five Hundred
Error 800105F
This is a known issue with the PSN Network today which might be due to system maintenance and upgradation. Users all over the world are facing similar issues.
Sony is working on the problem and the problem will be rectified soon. Kindly wait for further announcements from Sony
Please be assured that the problem is not with your unit and your system should work normally when the issue is fixed.
For details and status updates, click here
Thanks for using FixYa
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
A problem occurs when trying to render a web page. How do I reset it?
heyyy my blackberry is messsed up beause off some summer storm like n 2006 this old man stole it and yeah you no the usual he bronge it back 2 years later with a baby girl name latorya she was about 13 mouths old so yeah we took her in and we still have her today she is a 3 year old girl latorya maire jackson axys oxay stevens and i have so many pic of her on my blackberryh and i would really like to get hem off but my phone said jum error 513 ...... and i would really like them off so if you can plzz hepl me get them offf thanks shyler stevens
Jul 12, 2009 | RIM BlackBerry Pearl 8100
TH42PWD6 7 blink shutdwon
Hi, I have a Panasonic TH42PWD6 Plasma Display and it has started to shutdown after about 2 seconds.It blinks 6 short then one long - Do you know what this code is for please?
Aug 18, 2008 | Televison & Video
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
