Question about RIM BlackBerry Pearl 8130 Cellular Phone
When I try to type numbers...letters pop up.
I need to know what keys to push to deactivitate letters from showing when I want numbers.
  • 541 Answers
Press alt or arrow key and select the number key .........repeat the same when u want the number to get displayed in place of letters
Posted on Jul 09, 2009
Cannot switch between letter and number pads. no whenever I am typing instead the letters some numbers are show up. I need to know how to switch back. Please help
just push the FN key and Nmlock key at the same time. the FN key is located at the bottom left and the Nmlock is usually the same key as the delete key located at the top right
Jun 26, 2011 | Lenovo 3000 Y410 Notebook
The letter "C" popped off
Hi Madelaine_an,
I'm sure that when the letter popped off, two white plastics also came off beneath the letter. Now if you kept them and did not throw them away, you have to first fix both of them, one facing up, the other facing down. There are two insertion points on the missing space on your key board where they are to fit into. These white plastics have edges on them, and can be a little bit depressed to fit into their insertion points, where they expand to fill it after fitting. They are designed such that when you see them you would know which goes into what direction. If you try it one way and it doesnt fit in, then you are trying it wrongly. Reverse the directions. After you have done that, get your letter 'C', and press it into the white plastic. If you fixed the white plastic well, the key should lock into it, but be flexible, ie move up and down.
I hopoe that was able to solve your problem? I would appreciate a rating.
Have a nice day.
Jun 26, 2011 | Dell 0Y3740 Keyboard
Need instructions for keyboard toshiba satellite laptop , need to know what keys to push when using the numbers in the keyboard that are also letters
No need for the instruction manual. When your going to use the numbers that are inside of the letters, hold down the the FN key and then push the number that you want to be displayed. For example holding down the FN key and then pressing the L key produces the number 3 for me. Try your keys out and see what you get.
Jun 02, 2010 | Toshiba Satellite L45-S7409 Notebook PC
On my Toshiba Satellite Pro M15-S405, i would push a certain letter on the keyboard and instead of typing that letter, it would make a window pop up. Is there some kind of setting that i can change to...
Your windows key (the one with the flag) appears to be blocked. Try pressing them both (or 1, if you only have 1) once, see if the keys work again. If not, try taking the keys off the keyboard (just put somthing under them and pull) and put them bac on. If that doesn't help either, you will have to have your keyboard replaced.
Dec 10, 2009 | Toshiba Satellite Pro M15-S405 Notebook
Simply change my keyboard from typing numbers instead of letters..I.e. I'm trying to type yonkers and it gives me y6...I know it is a simple F6 or F2 function but I forget. Its been a while since I u
You need to press the NUM Lock key.
The NUM lock key is usually the same key as the ScrLk key but to select the NUM lock you need to press and hold down the Shift key and then press the NumLk/ScrLk key. A LED light will light up to indicate the number keypad is on.
Apr 26, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
NEC Dterm 80 display
It took me forever to find out, but heres what you do.
with the phone hung up:
1) "Feature" then press "1"
2) then press "#", "*", "#"
3) lift the phone, then hang up
4) press "Speaker"
5) dial "700"
6) press "hold"
7) enter the name (I'm still trying to find out how to leave a space, or use aother character that the same number key has... ugh"
8) press "hold" then "Speaker"
then make sure it saves it in the directory
Jul 30, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Keyboard
Okay, if I am reading this right, you type but get numbers where there should be some letters? There should be a NUM LK key or such on your laptop keyboard. It may be sharing a key. Check around, its there (or something very very similar). Once you find it, you will have to hold down your "fn" key and then tap the NUM LK key. Now type a sentence that includes the letters that show up as numbers and see if there is a change. It could be that your Number Lock key is on. Let me know if this does not work so we can try something else.
May 24, 2008 | Compaq Presario 2100U Notebook
Swintec 7040
Look for a slide showing 10,12,and 15 select 10. to bold hold down the code key and press the bold key. to capatlize hold down the shift key.
Jan 10, 2008 | Swintec 7040 Typewriter
RIM BlackBerry Pearl 8130 Cellular Phone Logo
197 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
