FixYa.com
Tags:
Quasar VV-1302 13 in. TV/VCR Combo
Hooking up a DVD player to a Quasar TV/VCR Combo (by 3 users)
posted by Thersites on Nov 07, 2007
My TV is a 25 in. but I have the same problem. The DVD player has three connectors (yellow, red, white); however, the TV only has two input options (video and audio) located on the front of the TV. How do I connect my DVD player to the TV? Do I need to purchase an adapter?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on May 22, 2008
I Have a admiral TV/VCR combo and want to hook up a DVD player to it.
What do I need?
Comment by spoony g, posted on Feb 12, 2008
I have a Zenith TV/VCR combo (with ComCast cable) that I am trying to hook a Phillips DVD player to. I believe that everything is hooked up correctly, do I need some type of Radio Shack conversion box?
Solution #1
posted on Nov 22, 2007
Not Rated (0)
Lil Tan
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have a already existing dvd/vcr combo brand name is govideo..I bought another dvd player that is regional free code dvd player..How do I hook the regional free code to the other vcr/dvd combo
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 07, 2007
Not Rated (0)
Benimur
Rank:Guru Guru
Rating: 87%, 2241 votes
Yes, for a workaround. The adapter would be 2 RCA female to 1 RCA male. You have to connect both the red and white to the female RCAs and use the male to connect to the TV's Audio INput. The yellow goes to the video. There should be no negative technical effect other than lost of stereo quality. The audio output of the DVD is line level and could normally tolerate this condition.
The correct method is to use a simple line level audio mixer and mix the L& R audio signal to produce a mono signal or to use a stereo amplifier for the sound output.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Can you Help with these TV Combos problems?
Blue Screen
Hey, I just moved in to college... Answer This...
lost remote.
i lost the remote to my 8213.... Answer This...
Manual Adjustment on TV
Lost my remote for a Quasar... Answer This...
Quasar vv-1301 tv / vcr
Can I use a universal remote... Answer This...
Changing language
We need to change the chosen... Answer This...
Repair Service
Find TV Combo Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
