Kenmore 71055 Air Conditioner
Problem for Kenmore 71055 Air Conditioner
Warm air
By complexmeasu on Jun 28, 2009
Unit is no longer blowing cold air. Is there a way to replace freon in this unit? Or what other problems may this be?
Clarification Request
Posted by daddyo742001 on Jun 28, 2009
My be stuck or bad compressor. plugged out door coil may need washed out. Tech will need to figure out if compressor is running or out of freon.Burnt wire can also cause no cooling plus bad intermal valves in compressor.
Posted by dtlong887 on Jun 28, 2009
Are the compressor and fan running?
Solution #1
posted on Jun 28, 2009
Not Rated)
thetim
Rank: Guide
Rating: 96%, 12 votes
If it is a window unit, you can clean the filter turn power off before so.
That is most likely the problem try that before replacing it.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 71055 Air Conditioner
Questions and Unsolved Problems for Kenmore 71055 Air Conditioner
Do you recommend Kenmore 71055 Air Conditioner?
Answer
Answer
I got an air conditioning and I don't know its voltage. Also, I don't have its manual. The air... (More)
Answer
My outside unit cotinues to run after the air handler cuts off. I have to trip the breaker to get it... (More)
Answer
malfunction of censor remote control
Answer
charging fion
Answer
LG Nano Plasma Air Con MODEL lsn364h-4 has a 5 flash fault
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air... Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
