Question about Black & Decker 19" Electric Lawnhog Mulching Mower
Can i convert a 12v cordless black and decker mower to electric
I want to convert my mower from cordless to electric if possible
  • 3 Answers
I converted mine simply by swapping the motor from another "freebie". Up and running in about 30-45 minutes.
Posted on Oct 02, 2013
    New Friend:
  • 3 Answers
I will be converting a 24 volt cordless lawnmower to 120 volt cord input when I get some electronics parts. I found a Craftsman 20" lawnmower at the curb that requires new batteries that the original owner didn't want to buy as they would cost $120. This lawnmower uses 2 12 volt, 20 amp hour gel cells. I plan to get an electronic component called a bridge rectifier rated at 25 amps which converts the AC to DC and connect it to a step down transformer to change the 120 volt house line voltage to something slightly above 24 volts. I will mount this in the empty battery holder bracket in the lawnmower and use any necessary terminal strips and marrette connectors to secure the wiring and possibly house it in a plastic electronics project box. The thing to remember when doing this kind of modification is to make all connections neatly and in a safe manner such as using heat shrink insulation and possibly some kind of fuse or circuit breaker in the circuit so if there is a current overload the transformer doesn't burn out. This is what I will try but if you or anyone else is unsure about working with electricity do this at your own risk.
Posted on May 27, 2013
    Problem Solver:
  • 14 Answers
I assume you mean convert it to corded, connected to the mains; cordless is electric as well.
It is possible but there are conversion losses as compared to using a 'native' AC corded mower motor.
It also depends on why you want to convert it. If you find the battery unit underpowered, adding a 12v power supply and cord will not solve that, it will just extend the run-time to continuous, assuming the motor does not overheat, as it is probably designed to match the battery run length for on/off cycle times.
You could consider trading, or selling yours and buying a corded mower.
Posted on Jul 08, 2009
Can I convert an electric Lawn mower to cordless
Are you serious! It will be impossible to get a mains powered lawn mower to run with battery power!!
Aug 26, 2014 | Abranet Mirka Abranet/Black and...
Black and decker electric mower wont start
Check and see if the battery is actually charged. If the battery sits run down all winter they have a habit of not holding a charge. and needs replacing.
May 22, 2013 | Black and Decker USA Black & Decker 36V...
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
Short battery charge
The B & D MM575 mower is not battery operated nor is it cordless. CMM1200 CMM1936 CMM1836 are the currently available cordless mowers. You can buy a battery from B &D, they list it here:
http://blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=22989
tom
May 10, 2010 | Black & Decker Black and Decker Mm575 18"...
I need the large cordless battery for the black and decker cordless mower, and also need the power charging board in the mower.
the largest is the 24v CMM1000. now the circuit board for the said model are hard to get. but upgrade are available & convert it to CMM1200 model. convertion kit includes instruction how to, a wiring assy & a charger.
Jul 03, 2008 | Black & Decker 19" Electric Lawnhog...
Melted electric brake
check out www.toolpartsdirect.com for diagram & cost. if the board are burnt. it is hard to get the board. i suggest covert the unit to CMM1200. you need convertion kit includes instruction how to install, wiring assy & charger. see webstie i mension & look for cmm1000 type 4. item 82
Jun 28, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower Logo
1,528 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
