Question about Dometic RM2852 Refrigerator
My Dometic RM 2852 not getting cold after defrost
We live in the fifth wheel full time, our model 2852 is a 2 way, 110v and gas. I noticed a plastic part clipped to the cooling fins in refer and what appears to be a thermocouple that was loose. Outside air temp is about 101 - 102 but fridge has worked fine in hotter temps. I can't find and thermostat adjustment in or on the fridge. I just reattached thermocouple? to plastic clip on cooling fins and hope thet works. Thanks for any help. Danny Phillips
SOURCE: dometic frig 2852
There was a recall on the frig by Dometic.
Posted on Aug 28, 2008
  • 68 Answers
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Posted on Mar 18, 2009
  • 68 Answers
SOURCE: Dometic refrigerator inconsistent temperature
Yes the clearances on gas absorption frig is critical. Not to say there is not another problem. Is the thermister attached to the frig fins?
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
Posted on Jul 06, 2009
SOURCE: Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Posted on Jul 24, 2009
Our refrigerator works on AC. When switched to lp gas it sometimes come on and works and then goes off. Then we can't get it to work again. Then it will work if we turn on the hot water hea
It seems like a gas pressure problem. Possible blockage or kinked pipe or faulty regulator on the gas bottle. If the fridge runs ok only when you use the gas hot water, that would change the gas flow / pressure. LP gas products are normally around 1.5 to 2.75 kpa pressure. If you have access to a manometer, the gas pressure can be checked. (NB/ You should hold a gas service licence to do this)
Sep 29, 2014 | Dometic RM2852 Refrigerator
Dm 2852 dometic
check seals if bad will frost up
Aug 09, 2014 | Dometic Refrigerators
I got a RM 2852 IN A 5TH WHEEL. It will work fine on gas,but 110v does not work,Any suggestions? Thanks,David
We were told that its a faulty control board on most Rm2852 units. a factory defect.
Ours did the same thing first the gas would not stay on to cool but the unti worked fine on electric...now the electric is not working...the heater gets hot and burner comes on but does not stay on..they system shuts down..and will not cool. .
Jan 29, 2011 | Dometic RM2852 Refrigerator
Freezing in the refrigerator
you probably have a damper control that is sticking open letting the cold air in fromthe reezer but not closing the small door when the freezer is to tempreture check this first
Apr 30, 2010 | Dometic RM2852 Refrigerator
Dometic 2852 freezer gets cold but refridge does not
If your freezer is getting down close to zero degrees (F) then I doubt that your refrigerant is low. The most common cause of the refrigerator section not getting cool (approximately 40 degrees (f)) is a fan that pulls the coils in the freezer into the refrigerator has failed. A very common failure of a cheep little fan motor. Normally that fan is behind a panel in the freezer section at the bottom. Determine where the cold air in the refrigerator section normally enters and the fan will be above there.
Aug 11, 2009 | Dometic RM2652 Refrigerator
Dometic frig 2852
Aug 28, 2008 | Refrigerators
Dometic RM2852 Refrigerator Logo
162 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
