Question about GE 25931 Trio Cordless Phone
Display screen is losing pixels, not even legible anymore
I have three of these phones, and all three have displays that are becoming illegible as they lose pixels. Apparently GE has lowered the quality on their products. Looks like it's time to buy from some other manufacturer.
2 of my 3 have done the same thing. It seemed to have happened after our power went out, although they werer all plugged into surge protectors. Now over time since thne they barely have any display at ALL. Cheap junk, say I.
Posted on Apr 28, 2010
Acer monitor has green lines on the scren
Liquid Crystal Display (LCD) screens use less energy and display a clearer picture than the Cathode Ray Tube (CRT) displays that preceded them. These new LCD screens now dominate the computer monitor market. From time to time, however, pixels can become stuck and a green line can display on the screen. Removing this line is sometimes possible without sending the screen to the manufacturer for expensive repair.
Locate the pixels that are stuck on the screen. Download a free screen repair software program, such as UD Pixel or JScreenFix. Run the software and allow it to find and attempt to repair the stuck pixels. Turn off the LCD monitor. Apply the damp cloth directly over the stuck pixels and use a gentle pressure to spread the liquid within the screen.
Things You'll Need Pixel repair software Damp cloth LCD screen 5 Ways To Fix A Stuck Pixel On Your Screen
http://www.makeuseof.com/tag/best-software-solutions-to-fix-a-stuck-pixel-on-your-lcd-monitor/
Feb 22, 2013 | Acer Computers & Internet
Calculator screen is out
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Sep 26, 2012 | Texas Instruments TI-84 Plus Silver...
Display screen is losing pixels, not even legible anymore?
I'm sorry but there is no economical fix for this type of problem. The LCD screen is simply failing.
If the phone is still under warranty, you can certainly return it to your place of purchase for a refund or exchange.
Otherwise you simply have to live with it as it is, or go out and buy a whole new phone handset.
Good luck.
Aug 11, 2011 | GE 25931 Trio Cordless Phone
Just put new batteries in and there is a very faint display.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it becomes very faint or even appears as if the calculator isn't turning on at all. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Sep 08, 2010 | Texas Instruments TI-84 Plus Calculator
Display freaks out
There is probably a false or intermittent contact at the display end. If the problem were in the generated signals, the whole display would be affected. A problem always in the same area of a LCD display usually means either the Berg strip or (if you're lucky) the driver cable has come slightly loose.
Since you've already opened the thing, I guess warranty considerations no longer apply. In the case of the Berg strip, perhaps the best home-made remedy is to get a strip of soft silicon foam or adhesive soundproofing, and place it against the strip so the non-adhesive area, once the screen has been reassembled, presses DELICATELY the strip against the display, preventing it from losing contact again.
Another, sadder possibility is that the driver lines inside the monitor went awry (this would explay why the screen reacts to power surges). In such a case there's unfortunately no solution, not even the "display massage" that sometimes fixes "stuck" pixels.
I'd rule out the external mouse as a coincidence.
Oct 04, 2009 | Toshiba Tecra S1 Notebook
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Fix ressolution on aspire to fit 720 pixel tv
Connect the laptop to the TV and use the keyboard toggle to switch screens.
Once the display is shown on the the TV go to the control panel and select display, set the screen resolution to 1024x768 and your display should be fine.
If you need anymore help or advice please post back.
Regards.
Aug 01, 2009 | Acer Computers & Internet
N72 screen goes blank
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-5 or 6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is the solution! Please vote!
May 17, 2009 | Nokia N72 Cellular Phone
Screen display not working properly
not a PERFECT solution, but it's a slight one
i have the same problem. i go through it everyday.
but when my phone does it. i either hold down the joystick, or the delete button, and it puts away the lines for a slight bit. be careful when sliding it down though, sliding it down hard can also cause the lines to show up.
Nov 13, 2008 | AT&T LG CU720 Cell Phone - Silver
GE 25931 Trio Cordless Phone Logo
251 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
