You may have a burr from an errant needle strike on your bobbin case or even on the bobbin itself. Check to see if there are any rough spots on or around the bobbin.
If you don't find anything, you may want to remove the bobbin assembly and clean the lint out from the lower assembly. Sometimes the smallest amount of lint or pieces of thread can cause problems with the bobbin.
You didn't mention if the tangled thread happens on the top or the bottom of the fabric. If it is on top, then it is a bobbin issue. If it is on the bottom, then it is an upper tension/thread issue.
Try removing the bobbin, thread, and needle. Rethread the entire machine using a different bobbin and a new needle. This may solve your problem. Good luck!
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
SOURCE: My wife is frustrated with her sewing machine and
I have a simple and I have better luck when I use a SA156 metal bobbin. Another thing, has she watched the cd that came with the machine? This machine is a little touchy as far as threading goes, I have been sewing 50+ years. Usually, it is in the top threading that causes the problem. If, she has a question, she should call Singer at 1-800-4singer and they will walk her through all of the threading and other troubleshooting strategies. Good luck. Hope this helps you.
SOURCE: Hi! I have a singer simple 3116 sewing machine
It is the top threading that is giving you the problem not the bobbin thread. Try this, totally rethread, the machine. A new needle will not hurt either. Now with the presser foot up, pull on the top thread, it should feed smoothly, now lower the presser foot, pull the thread again, it should barely move. This usually will seat the thread in the tension discs.
Good luck and Merry Christmas
SOURCE: I have a singer simple
Insert a new needle, (flat side facing rear of machine), now totally rethread. Try this, with presser foot up, pull top thread, it should pull smoothly, now lower presser foot, the thread should barely move. This should seat the thread in the tension discs. If that doesn't work, call Singer at 1-800-4singer.
