Question about Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat
I've removed the maxi cosi cabriofix cover to wash it and misplaced the round grey button that adjusts the shoulder straps can i replace this
  • Anonymous Mar 15, 2014
    i have completely taken my maxi cosi cabriofix carseat apart for washing now i cannot get the adjust strap to connect to the gripers!!
  • 419 Answers
Yes you can, this is called a Quick Adjuster I think and costs very little.
Contact www.maxi-cosi.com who will advise you.
I hope this helps.
Posted on Sep 15, 2009
Can I get replacement straps for the maxi cosi cabriofix?
Your Maxi Cosi CabrioFix can be fitted with new straps.
Since this is directly affecting the safety of the seat the procedure is only available from a Maxi Cosi service center.Please visit a Maxi Cosi dealer to have your seat sent to a service center.
I hope this helps.
Erwin de Raadwww.babycare.nl
Sep 01, 2011 | Maxi-Cosi Cabrio Red Flame Reflection...
I recently removed the cover of my maxi cosi priori car seat to wash it. Now I cannot work out how to put it back on. Basically I have unhooked both shoulder straps that I think were previously threaded...
Good Afternoon
Go to www.maxi-cosi.com and select the CabrioFix carseat to download a replacement instruction manual for details of how to replace the fabric.
The harness should not have been completely removed from the carseat in order to remove the fabric. If the harness has been completely removed we cannot advise that you re-thread it due to the safety implications of it being incorrectly done. In this instance please contact the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss the carseat being sent to our engineers for them to re-thread the harness.
Aug 16, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Hi i have got a maxi cosi cabriofix car baby car seat and cannot seem to remove the cover at the bottom where the grey circle is how do i do this and can i was the cover in the washing machine once...
Good Morning
The grey tensioner strap appears to be stitched in place but it isn't. Follow it around under the bottom of the carseat and the strap is in a piece of plastic catch shaped like an H on it's side. Wiggle one way then the other to unhook from this catch, and the carseat fabric can be removed (where the grey circle part is the fabric is tucked underneath slightly, once you've unhooked the tensioner strap you'll be able to get the fabric off easily).
Hand washing is recommended, but if you have delicate or handwash cycle on machine this is also suitable. Use a mild detergent and maximum temp 30 degrees for washing. Do not tumble dry: Do not leave in direct sunlight to dry. Ensure fabric is completely dry before putting it back on for use as damp fabrics may result in mould or mildew growth.
Remember never remove the harness straps from the carseat, the fabrics can be completely removed while the harness remains in place!
Aug 04, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Where can I order a two spare shoulder pad for the straps to my maxi cosi black car seat?
Good Afternoon
If you are a UK customer, replacement harness pads for the Maxi Cosi CabrioFix can be ordered via your local authorised retailer or direct with the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. The harness pads are available in plain Black only, as a set of three, and are RRP £15 (with £3.99 p+p if ordered direct).
If you're in another country, go to www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab to ask if they're available in your country to order.
May 31, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Cant remove the cover off the straps at the bottom of the cabrio fix car seat i have removed it off the seat but can not remove the straps at the bottom to remove the cover
Had the same problem where you are left with the cover trapped by the quick adjust part for the shoulder straps located near the foot of the seat. The solution, the strap does detach at the front of the seat. The loop that is stiched round what feels like a solid plastic part of the base, turns out that there is a gap in the plastic so push the strap to either side and pull it out through the gap. With this removed you should now be able to remove the cover completly and bung it in the washing machine on a hand wash.
Feb 16, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
Can't take off maxi cosi carseat cover, because grey strap at the bottom doesn't come loose.
Slack off the straps as far as possible and recline the seat. Open the strap guard door on the rear of the bit of the seat that reclines (Item 3 on diagram http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/PrioriFix.pdf). The shoulder straps can be released from the metal clasp which is in here.You can now pull the straps through the back of the seatand release the cover.
Oct 20, 2009 | Maxi-Cosi Priori
How do i remove maxi cosi car seat cover for washing please
hi bodsierpa..hope this helps..good luck!!!
• First remove the belt pads.
• Open the rim at the sun canopy as far as possible
• Remove the cover from the hooks
• Remove the cover then from under the hooks and quick adjuster button
• Pull the buckle tongue sections and adjustment strap through the openings.
May 15, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi cosi cabriofix infant car seat
If you follow the link at the bottom it will take you to the cabriofix insruction manual on the maxi cosi website. (Their uk website can be found at www.maxi-cosi.com/maxicosi/default.aspx)
Link...
http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/CabrioFix.pdf
Good luck,
T
Jan 22, 2008 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi cosi car seat cabriofix
What seems to be a sewn-up loop, is actually easy to unattach, but the trick is not explained in the manual.
Where the end of the strap seems to be holding to the seat's plastic shell, the plastic is not completely connected, there is a break in the plastic. Just move the strap left/right a bit and you will see that you can unattach it there. Then you can unthread the loose end of the strap and completely remove the cover.
Credits for this go to my wife who figured it out after I already thought we should return the seat to the shop. :p
Jan 08, 2008 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
1,192 people viewed this question
Top Maxi-Cosi Baby Gear Experts
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
