Question about Mitsubishi WD52527 52" Projection HDTV
When accessing the Device Menu, the TV turns off
Whenever I press the device button on my Mitsubishi WD-52527 or with the remote, it goes into "protection mode" and turns itself off. Most of the other commands seem available, and when I use the picture in picture function, I can view the other devices (DVD, SAT, etc.). However, I can't get it off Antenna due to the TV reset every time I press device.
  • 668 Answers
I would contact Mitsubishi and see if there is s software upgrade for this model. You can contact them at 1-800-332-2119.
Hope this helps,
Skyassoc
Posted on Jun 29, 2009
  • Michael Werdman Jan 06, 2011
    It sounds to me that you might have connection issues. You might want to retrace all your cables. Might be one that is either come loose or hooked in incorrectly. I hope this helps!
Green light turns on for 1 or 2 seconds and then goes off. tv won't turn on, no picture.
Have you tried accessing the self diagnosis feature by pressing the menu and device buttons both together and holding for for 5 seconds? If not try that and let me know the error code. It will be a two digit blink sequence which will repeat a few times. Let me know what the blink sequence is.
Jun 07, 2011 | Mitsubishi Diamond WD-65831 65" Projection...
Device button is freezing my t.v.
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Let me know if this works
Jun 26, 2010 | Mitsubishi WD-62725 62" Rear Projection...
When I push the device button on the remote, I
I had this same exact problem with my WD-62627. I got mine to work by re-initialing the tv. I could not believe this worked. Try this, 1) turn on the TV
2) press MENU 2,4,7,0 then ENTER
3) the TV should INITIALIZE
4) Press the front reset button on the front of the TV.
5) should work again....if so.....
6) email me at Larry1965@hotmail.com to thank me. :)
Dec 30, 2009 | Mitsubishi WD62628 62" Projection HDTV
Mitsubishi WD-62827 shuts down after pushing the device button.
With the remote press menu 2470 enter then do a system reset after the set has reinitialized this should fix your problem, you will have to reprogram your channel settings afterwards though.
Oct 17, 2009 | Mitsubishi Televison & Video
Mitsubishi WD 72737
Try this:
1) turn on the TV
Jun 23, 2009 | Avanti WDR71
WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Jan 05, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Device Menu not working
Could have a stuck button or a corrupt e-prom, but lets try kicking this set in the head, Now these reset codes are model dependent so this code will not work for every set out there but this reset is for the WD-62525. with the set on and with the original TV remote hit the keys in this sequence, MENU-2-4-7-0 this will bring up a service menu, the cruiser should already be on "Initialize" so simply hit enter. this will reset the TV to factory defaults and may fix your problem
Sep 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD52527 52" Projection HDTV Logo
209 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
