Question about HP Computers & Internet
At boot time appears message 'Device Monitor Appliaction (mispell
Every time I boot up my PC I get, when my
Desktop screen appears, the message 'Device Monitor application has
encountered a problem and needs to close etc etc.' I had this problem after I installed my wireless Lexmark Printer model Z1480 about 2 weeks ago. I unistalled and reinstalled the lexmark software (cd) but could not get rid of this boot time error message '' Device Monitor Appliaction (word is mispelled) has encountered a problem and needs to close:.
Lexmark printer
    President:
  • 627 Answers
Try this:
1. download combofix and follow his steps (don not agree with recovery console)
link is here : http://www.combofixdownload.com/
notify me if problem is resolved
Posted on Jun 29, 2009
My sansui pc/tv monitor isn't working properly when I connect it to my desktop.
Windows is likely crashing while loading recently upgraded device drivers. The most common culprits for this scenario are video drivers.
The next time you boot, as soon as you see the Dell splash screen, start tapping the F8-key about once every second until you see a white on black menu. If you see the Windows logo, you missed it (try again, this time start tapping the F8-key a little before the Dell splash screen).
This menu will allow you to boot Windows in "Safe Mode", which will bypass any non-essential drivers and applications that could be causing the crashing. Select "Safe Mode with networking".
Assuming the computer booted fine in Safe Mode, you will be able to remove the troublesome drivers. You will see an informational message about Safe Mode, which you may close at any time. Right-click "My Computer" and select "Manage". Wait a moment for the Computer Management window to appear. Then, click on "Device Manager". If Windows was able to identify the faulty driver, it will appear in the list with a bright-yellow triangle. If this is the case, right-click and "uninstall" it. If it did not show up, first click the tiny white triangle next to "Display Adapters" and "Monitors" to open those categories. Then, right-click and "uninstall" everything listed within the two categories. Your computer will probably boot normally after doing this. But, try and find the proper driver for you video adapter before rebooting if possible. I recommend also re-installing the chipset drivers which may be related to the problem.
To attain drivers for your specific Dimension B110, visit the following link and enter the service tag code on the back or side of your machine: Dell Drivers
Oct 28, 2012 | Sansui HDLCD1912 19in LCD HDTV 720p
How to format my computer
insert operating software DVD in your DVD drive
restart your Pc
press Del key (.)
select boot menu
select 1st boot device
black screen appears with "CD/DVD"
at that time press enter
screen appears with :DVD CD Boot...."
at that time select enter
software installation
custom install
Jun 05, 2011 | Fujitsu Siemens SCENIC P300 PC Desktop
I have installed a new monitor on my desktop (windows xp) but the message appears 'Reboot and select proper boot device, or insert Boot Media' .. I have tried out the new moitor on my laptop and is working...
First check that all your CD/DVD and Floppy drives are empty. If there's a disk in one of them, take it out and reboot.
If there isn't a disk in one of the drives, switch on as normal and watch the screen, at the bottom you'll get a a message saying something like "Press F2 for boot options or "DEL" for setup".
Then it'll disappear quick as lightning before you get chance to do anything.
So re-boot again, this time pressing the boot options button repeatedly, so you don't miss your chance.
When successful a screen will say choose where you want to boot from. Choose HDD 0 (Your first hard drive) and press enter.
If you want to you can press the DEL key and go into the bios and set up your boot options.
I would suggest you set the boot order to
1) HDD
2) CD
3) Floppy Drive.
May 03, 2010 | Computers & Internet
Reboot and select proper boot device or insert boot media
its basically telling you that your master hard drive with O/S installation cannot be found in the booting system...Check if your master HD is not corrupted and see if your O/S still exist or maybe wiped out..
Mar 31, 2010 | Computers & Internet
GX520 screen display message: cannot display this video mode
This means that the windows setting you have set can not display on your current monitor. There are two ways to fix this, one is to boot the computer in safe mode by pressing f8 after the POST screen and change the resolution and the other is to plug the computer into a different monitor to see if supports that resolution and then change the resolution in windows to a lower setting.
In case you don't know how to change the resolution in windows, follow below.
Right click on the desktop
Properties
Settings at the top
Move the slider to 1024x768
Click ok
Try rebooting. If that still doesn't work, try another resolution.
Oct 19, 2009 | Dell OptiPlex GX520 PC Desktop
I have an HP desktop. Sorry for the lack of
Hi
when your r restarting the system hit the F8 key several times till you see the windows advance option and select safemode with networking and log in to your account and then updat the drivers by right click on my computer >> properties>>hardware tab>> device manager>> under display adapter>> right click on the drivers and click on update and it will look on the net for the right drivers..
Aug 28, 2009 | HP Pavillion ZV6000 Notebook
It will boot up to the windows screen and freezes.
If your computer was able to boot up but unable to load the Windows, the most common cause would be the recently intstalled software or Windows update.
To remove this, follow these steps. Skip Step 1 if it is not relevant.
Step 1: Removing recently added hardware
Use the steps in this section to disconnect any recently added hardware and test for the error.
NOTE: If a new internal device (sound card, hard drive, or other) was added to the computer before the error message started to occur, you have to remove it before continuing.
  1. Turn off the PC and unplug the power cord.
  2. Disconnect the mouse, and any other peripherals attached (Printer, scanner, webcam, zip drive, phone cord, network cable and other devices). Leave only the keyboard and monitor cable attached.
  3. Press and hold the power button on the front of the PC. Release after 10 seconds.
  4. Plug the power cord back in.
  5. Turn on the computer.
  6. The computer displays the We apologize for the inconvenience... message. Allow the timer to count down from 30 to 0.
  7. If the computer successfully starts to the Windows desktop and does not restart to the error message, connect one device and wait until Windows recognizes it.
  8. To find if a device is causing the error, continue connecting the devices, one at a time, restarting the computer each time, until the device that is causing the error is found.
NOTE: If this does not solve the issue try to do a system restore BUT it will delete all your files and programs you install by yourself after the system. You will be able to use the pc as a new pc.
Jan 25, 2009 | HP Compaq Presario SR2011WM PC Desktop
My pc showing yellow screen
monitor gone bad, check your computer on other monitor
Nov 08, 2008 | Acer Aspire™ T180 PC Desktop
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
Out of Range message on monitor after T5300 finished booting. No Image.
The out of range refers to the screen resolution size of your pc as apposed to the monitor. It is unable to operate at the set refresh rate and screen res.
Jan 31, 2007 | HP T5300 (dc643a#abu) Network Terminal
Open Questions:
Computers & Internet Logo
207 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
