HIGH HYDRO CARBON EDELBROCK 1406 PERFORM 1500 MAN TRAN FAILD EMISS HIGH RPM ONLY
High HC counts are due to a rich mixture, too much fuel. How does the truck run normally? To adjust the fuel mixture at the carburetor, make sure the truck is at operating temperature. Turn the idle mixture screw clockwise until the engine starts to lag then turn the screw back just until it runs smooth. Also make sure you have fresh oil as this could cause high HC's as well since fuel gets into the oil and make sure your PCV valve is operating correctly. If you can't get it adjusted correctly, you may have to pay a shop to hook it up to the emissions machine to get the mixture correct, unfortunately.
Hope this helps. Good luck!
