Question about Video Cameras
My camcorder is not showing the image on the screen or in the view finder audio is recording
    Novelist:
  • 103 Answers
Sounds like the Iris control motor is not opening the Iris.....it might be stuck closed or no power to the Iris control motor. when you switch to camera mode, look into the lens assembly, you can actually see if the Iris is opening...if you don't see any movement, then your problem is the Iris, if you do see the iris opening, then your problem might be more severe such as the camera module itself....what ever the case, your camera needs to be opened up for service.
good luck
silvio
Posted on Jun 28, 2009
2 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: No image when recording
What you probably have is some kind of condensation issue. This usually happens when the camera is used in places where there's high humidity, low temperature etc., Since you are able to view the pictures that are already taken, I would assume that this is just some kind of sensor issue. Most of the times this can be fixed by leaving the camera ON for about 1hr. This will get the condensation senor to sense everything is back to normal and will power up the viewfinder again.Let me know if it worked so that we can look at other possibilities.
Thanks,
Sai.
Posted on Jan 12, 2009
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
How do I get the sony handycam dcr-hc30ntsc to show me a pictuer wale recording or any thing
If camcorder does not show live view in view finder and lcd screen but shows good picture in play back of old recorded tapes then ccd imager chip is defective in camcorder and need to be replaced.
It is not user level repair as soldering work is needed to replace ccd imager chip.
Let me know if you have additional question.
Thanks.
Oct 18, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
My camcorder whon't record image only sound?
If camcorder does not show live view in camera mode then most probably its ccd imager chip failure problem that part need to be replaced to get live image in lcd/ view finder to get it record on tape.
Let me know exact model number of your camcorder to provide you more info.
Thanks.
Apr 04, 2010 | Sony Hi8 CCD-TRV138 Camcorder
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
No image thru view finder,and lcd monitor
My camcorder does not show a picture when trying to record a video and when I look throught the eye port is is scrambled also. the only picture that is normal is when I watch a previously recorded video. Can you help me?
Oct 11, 2009 | JVC GR-SXM260U Camcorder
When I turn my camera on and try to record, nothing shows up on the screen.
Make sure lens cover is open, if still camcorder does not show live view then it is bad ccd imager chip problem that will be replaced.
Let me know exact model of your Sony camcorder to provide you part number info of ccd imager chip.
Thanks.
Sep 24, 2009 | Sony Handycam DCR-HC20 Mini DV Digital...
There is no picure in my view finder or LCD screen. I have all of my display menu's and such, but no picture, and yes the lense cover is down. There is a small eye looking icon in the screen, and I can...
Its known issue of bad CCD imager in DCR-HC30 and CCD imager will be replaced.
Sony will repair your handycam free of cost as per announced scheme of CCD problems.
Click on Sony CCD Support for details.
Jan 12, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
I have a Samsung VP-D20 The camcorder switches on ok, all the information appears in the view finder or on the LCD but there is no recording image on the screen or in the view finder, the recording light...
Yes I have solved the problem with this camcorder. I had a scrap unit which had a liguid spillage. Thanks to your help I stripped both units down and changed the lens assembly complete with the electronics, the camcorder now works fine.
I am waiting for help with a samsung D 363.
Regards James.
Mar 30, 2008 | Samsung Cameras
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
Viewfinder screwing up play back
Is it only in the Viewfinder, or also on the LCD, or also transfers to the recording?
Jun 22, 2006 | Sony Handycam DCR-TRV740 Digital Camcorder
Video Cameras Logo
255 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
