Question about E-Machines (308714) Motherboard
Identical problem I have exactly similar problems with my G620. You myst wait about 10 minutes to be able to reboot the computer after shutdown. If the external power supply is not in use power button light only flashes once and booting process will not go on. If the external power supply is switched to the computer booting process goes on so far thet you can sign in to BIOS: Seems to me that this has some correlation to the temperature of the computer...
I replaced my BLKEN router with a TP-LINK-AC70 and my iPhone and iPad works good but my laptop screen is blank I'm new to computers and don't know what to do do i need to reboot my laptop if i do how
Hi Paul,
Since you can't get to your desktop for a normal shutdown, you will have to do a hard shutdown. Just press and hold the laptop power button for 10 to 15 seconds until you see the screen is off. Wait about 10 seconds and press the laptop power button normally to turn it on. If you see an option to boot in safe mode or normal, choose normal.
Good luck.
May 05, 2017 | Computers & Internet
Computer frozen does not respond cannot reboot
Laptop or Desktop? Try disconecting all power wait about 30min the repower, Also hold the power button (while unpluged/no battery) for about 30 sec. Then try putting the power cords back in and power up as normal. Hope this may help some, once in scan the system from virus or malware issues. Good luck
Jun 25, 2014 | Microsoft Windows XP Home Edition
Does an exact fit used ECU need to be reprogrammed on my 1998 s70 volvo
You can try a Hard Reboot, remove the battery cables from the battery, wait 20 minutes then make contact with the + an - cables together for at least 10 seconds. Normally you would want to run a diagnostic on the new computer if it cam out of another car just to erase the codes from the other car.
Sep 06, 2012 | 1998 Volvo S70
My computer won't connect to the internet - it says limited or no connectivity. The router and cords do work with a different computer. I have already checked for the IP address. What's next?
unplug your modem for abotu 10 seconds, wait a minute and see if it connects.
Still a problem - unplug the router (assuming you have one), and wait a minute while it reboots and aquires/assigns IP's.
Feb 20, 2010 | Dell Dimension E310 PC Desktop
1996 Oldsmobile Achieva: Security light flashes upon startup
Here is what you do, but only when the SECURITY light flashes - if it is always ON or OFF it's no use.
Turn the key in the ignition to ON.
Wait for exactly 10 minutes ( SECURITY light will flash for 10 minutes and then stay on SOLID)
Turn the key to OFF
Wait 5 seconds.
Wait for exactly 10 minutes.
Turn the key to OFF
Wait 5 seconds.
Turn the ignition OFF.
Start the car normally.
It has relearnt the keycode and you're good to go.
NOTICE - it takes 30 minutes to relearn, that's THREE cycles of ON - 10 minutes - OFF.
Good luck.
Jul 11, 2009 | 1996 Oldsmobile Achieva
Wont sync to my computer and the computer will not recunize it how do i fix this
Go into the control panel, click on system, then device manager and then search the list and see if any red or yellow exclamation marks are present. If none are than unplug all your USB cables going to the computer. Next open up Universal Serial Controllers and uninstall all the devices listed, close the open windows and shutdown the computer, wait 10 seconds after complete shutdown and turn computer back on. Let windows boot completly up and it will reinstall all the USB drivers again and probaly have you reboot the system. After it boots back up install your software to your player, after installed than plug your player in and it should work. If it works OK than plug the USB devices you unplugged earlier back up 1 at a time, windows will detect it and load the required drivers again for each device you plug in. After all your devices are re-installed do a shutdown, wait 10 seconds and reboot. Everything should work normally now.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_c087e4b7d13c0163
Jul 04, 2009 | Coby MPC895 MP3 Player
Gateway laptop dvd drive does not start
http://support.microsoft.com/kb/314060/EN-US/
Dec 25, 2008 | Gateway (5500652) (  5500652)...
Dell optiplex g620
Check your BIOS. If it rebooted chances are it might work if you change the way the BIOS sees and boots the devices. Try rebooting without the flash drive in. What happens?
Please remember to rate my solution!
May 07, 2008 | Dell OptiPlex GX620 PC Desktop
Freezes up
This error can be caused by one or more of the below possibilities:
HDD
Power suply
Ram
Cooler dont work propertly
Or you are infected with virus
But most of those problem happent when HDD is damanged!
Oct 30, 2007 | IBM ThinkPad T20 2647 Notebook
Samsung scx4100
Check for any paused or failed print jobs. 1)Cancel or delete them. 2)Reboot computer. 3)Shutdown the printer for a few minutes. 4)Turn-off printer and computer, wait 5 minutes, turn on printer|turn on computer. Let me know more information if you can. Thanks Tim
Mar 13, 2007 | Samsung SCX-4100 All-In-One Laser Printer
E-Machines (308714) Motherboard Logo
62 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
