Question about Olympus Stylus 770 SW Digital Camera
Olympus 770 Stuck On "one moment"
I've got the same problem, the camera recognizes that it's been plugged into a computer, but when I select the highlighted PC button it goes to the blue screen that says "one moment" and stays there. My computer says that a faulty USB device has been plugged in. It used to work fine, and I've tried a few different computers so I know it's not the computer that's the problem.
mcomijohns
  • 477 Answers
SOURCE: Won't connect to computer
Try setting your camera to preview option and plug it in then look under my computer for a extra drive letter.
Posted on Apr 07, 2008
  • 73 Answers
SOURCE: Computer won't recognize Olympus FE-340 when USB is plugged in
some computers just seem to do that, it happened on me before. if you have a card reader just put the card into that and read the pictures from that.or just try a differant port if you havent allready
Posted on Mar 24, 2009
  • 11967 Answers
SOURCE: my Olympus Stylus 1050SW will not connect to my pc
Do what the pros do...use a card reader instead of your camera.
Posted on Mar 27, 2010
seofelite
  • 114 Answers
SOURCE: Camedia software does not recognize connection to
Did you install all software that came with your camera? If so, you should've seen a balloon on the bottom right corner of the computer screen saying the software was "successfully installed and ready to use" at the time of installation. Try this, then turn on the camera and connect it to the computer. The message doesn't go away because it's constantly looking for a connection to your computer, which your computer isn't detecting and is most likely that the proper drivers (which are in the CD) were not installed.
Posted on Jun 30, 2010
  • 102366 Answers
SOURCE: olympus stylus 770 cable has
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Apr 08, 2011
How to transfer the pictures of my Olympus microtouch camera to my computer ?
make sure that there is a driver for the camera in the computer or the computer will not recognize the camera
Oct 09, 2015 | Olympus Cameras
How to make Windows7 recognize Olympus FE-170... At this moment I don't have a card reader. I've tried so many times by dl the proper software, but still it won't recognise it. Isn't there...
The easiest solution is a cheap $5 card reader available online or from a local walmart. If you don't want to do that, you can check the olympus website's download section to see if they've issued new software or driver's for your model and Window's 7.
Sep 09, 2011 | Olympus FE-170 Digital Camera
I have an Olympus FE-330 camera. When I try to transfer using the Olympus Master 2 (recently installed) it says 'software unable to locate an Olympus Digital Camera connected to a USB port' I...
Check the LCD screen of the camera. You should get a message when you first plug it in to select the usb type. highlight PC and press ok. The screen should display one moment please then go off. Then the camera should be recognized by the computer.
Jun 15, 2011 | Olympus FE-330 Digital Camera
I have plugged it in and it my computer will not recognize that the USB is even plugged in, but it does charge the camera.
Try all the different USB Ports on your computer, sometimes certain ports can 'glitch' and not recognize the device that you've plugged in. If you've tried plugging it in all the ports and your computer still hasn't recognized the camera, re-install the driver software for the Olympus SP800UZ.
If all else fails, you can also contact Olympus customer service, they're quite prompt and helpful.
May 17, 2011 | Olympus SP800UZ Digital Camera
Olympus stylus 770 cable has problem transferring photos to computer. This only started month ago. Once connected to computer, camera screens reads 'one moment' but never actually connects to computer....
Oct 24, 2010 | Olympus Stylus 770 SW Digital Camera
Camedia software does not recognize connection to C-770 via usb cable what could be the cause of this? the cable is connected to the pc and camera and the camera is on. When the menu comes up on the...
Jun 30, 2010 | Olympus Camedia C-770 Digital Camera
Can I get a book to use my olympus camedia c-770 ultra zoom
Go to the support section of the Olympus web site to download a copy to your computer.
Sep 05, 2009 | Olympus Camedia C-770 Digital Camera
On what site can i get the drivers for my Olympus camera FE170
The camera is an autoconnect camera. There are no drivers needed if you are running Windows XP or Windows Vista. The camera should immediately be recognized when connected to the computer. If you need photo editing software then you can go to www.olympusamerica.com and click on software downloads and download the free version of Olympus Master 2.
Jan 22, 2009 | Olympus Camedia C-770 Digital Camera
Won't upload pics to PC via USB
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 15, 2007 | Olympus Camedia C-770 Digital Camera
Olympus Stylus 770 SW Digital Camera Logo
268 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
